Leaf Spring Suggestions
Discussion in 'Suspension' started by Beachcomber, Nov 12, 2021.
  1. Nov 12, 2021 at 11:16 AM
    Beachcomber
    Beachcomber [OP] New Member
    2011 Silver Sky CrewMax
    BDS 4.5" w/fox CO Lift Sequoia Grill & Headlights Prinsu Roof Rack Bullet Lined Roof Fuel Wheels/NItto Grappler Tires
    I recently had a 4.5 BDS Coil Over lift installed and in the process found I had a cracked leaf spring. I am now shopping for a replacement set. The BDS kit gives the truck a slightly lower rear.
    Any suggestions/experience with adding aftermarket leaf kits to a similar lift? I am looking to get at least a level stance but would prefer a slight rake.
    Thanks
  2. Nov 12, 2021 at 11:24 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    There has been several discussions on this, search, upper right in the suspension and towing forums here.
  3. Nov 12, 2021 at 11:33 AM
    Beachcomber
    I's searching leaf spring and BDS but not seeing much. Any specific searches I should do?
  4. Nov 12, 2021 at 3:22 PM
    frichco228
    See if any of these help below. Also Deaver and Alcan and build you leaf springs based on your needs- lift, capacity, etc. Icon, OME, have lifted leafs and I think Dobinsons and Elka offer them too. There are also add a leafs available to add to your current springs.
    https://www.tundras.com/threads/icon-rxt-tundra-leaf-system.22023/
    https://www.tundras.com/threads/adv...-permanent-heavy-ish-load.96424/#post-2456026
    https://www.tundras.com/threads/do-i-need-to-add-leaf-springs.96600/#post-2453453
    https://www.tundras.com/threads/leafs-to-lift-rear-on-bds-7-inch-lift.30964/
    https://www.tundras.com/threads/lifted-leaf-advice.40509/
  5. Nov 12, 2021 at 3:46 PM
    Punisher29073
    Punisher29073 New Member
    Ryan
    White Knoll, SC
    2019 Tundra TRD Pro
    Clearance lights, Light bar in front bumper, Ditch lights, CB Radio, AGM Battery, SLEE Sliders,
    I had Alcan build me a set. Have been happy with them.
  6. Nov 15, 2021 at 10:07 AM
    Beachcomber
    Thanks!
