Leafs to lift rear on BDS 7 inch lift?
Discussion in 'Suspension' started by tmart, Sep 1, 2018.
  1. Sep 1, 2018 at 3:56 PM
    tmart
    tmart [OP] New Member
    Travis
    Is there a leaf pack I can buy that will eliminate my blocks in the rear with the 7 inch bds lift and still keep the same height? Or can I call Deaver and get something custom made? I love the ride heighth right now and I want it to stay the same but get rid of the block and it’s also time for new leafs so might as well do both...thanks for the help
  2. Sep 1, 2018 at 4:12 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    ICON RTX it’s adjustable and should be able to replace the block! I have the same bds setup and just got the new leaf pack! Waiting for installer to get it installed
  3. Sep 1, 2018 at 4:13 PM
    ZPMAN
    Minnesota
  4. Sep 1, 2018 at 4:19 PM
    tmart
    Travis
    Let me know how that goes!
    And I’ll check out that website, thank you!
  5. Sep 1, 2018 at 4:19 PM
    anthonygan
    2017 Cement TRD PRO
    Yeah welcome they get installed Wednesday I have done the before measurements excited to do the after !
  6. Sep 1, 2018 at 4:20 PM
    ZPMAN
    Minnesota
    They have been doing leaf springs for a very long time.
  7. Sep 1, 2018 at 5:45 PM
    tmart
    Travis
    But I didn’t see any on the site specifically for the 7 inch lift to not require any blocks..
  8. Sep 1, 2018 at 8:58 PM
    anthonygan
    2017 Cement TRD PRO
    I called icon and the technician said that it would work.
  9. Sep 2, 2018 at 1:13 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I did ome drakar and +3 @Coachbuilder1 shackles per David's suggestion on my pro comp 6. Did the aal from ome also. Love the ride.
    papasmurf likes this.
  10. Sep 6, 2018 at 5:27 PM
    anthonygan
    2017 Cement TRD PRO
    Just got the truck back!! And it’s awesome the icon rxt replaced the lift block!!!!
  11. Sep 6, 2018 at 6:16 PM
    tmart
    Travis
    With the 7inch lift?? Post pics man!!!
  12. Sep 6, 2018 at 6:16 PM
    tmart
    Travis
    No shackles or anything?
  13. Sep 6, 2018 at 6:18 PM
    anthonygan
    2017 Cement TRD PRO
    I will later ! And with coach builder plus 3 shackles
  14. Sep 6, 2018 at 7:02 PM
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
  15. Sep 6, 2018 at 7:16 PM
    tmart
    Travis
    Damn those are a lot of leafs, I wonder if they ride alright. But that’s wxactly what I’m looking for, I’ll look at reviews now thank you man
  16. Sep 6, 2018 at 7:48 PM
    LEKS
    Makaha
    You can call them and have them set it up however you want. I have a friend that has a topper, aftermarket bumpers and roof racks so he called thems up and had them adjust for that. Said his ride is smoother than stock now and highly recommend these guys. I’m going with their 6” leafs soon
  17. Sep 6, 2018 at 7:50 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    12463.jpg 20180906_194529.jpg 20180906_194612.jpg7" BDS, I called Deaver and told them what I wanted, didn't go smoothly at all. Other than that, I'm happy with them.
    BluFoxx82, YTThao530 and 1UPPER like this.
  18. Sep 6, 2018 at 8:12 PM
    Yotaman18
    Yotaman18 New Member
    Corey
    Houma, LA
    2018 Platinum 4x4 Bitching Blue
    your leaf springs have leaf springs
  19. Sep 6, 2018 at 8:29 PM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    a combo that worked for me was OME dakar leaf pack and Coachbuilder +3 shackles. Gave me about 5" in the rear and was level with the front.
  20. Sep 6, 2018 at 8:49 PM
    tmart
    Travis
    How does it ride trayday??
    and that sounds good smurf you liked the ride??
  21. Sep 6, 2018 at 8:55 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    worked great... rode well. no complaints
  22. Sep 6, 2018 at 11:07 PM
    anthonygan
    2017 Cement TRD PRO
    The rear is a little high right now and I believe it’s becuase the leaf pack is new! Over time the leafs will settle down and the car will be more level! I don’t mind that it’s a little high becuase with some weight in the back doesn’t squat as bad!6897AC8F-4077-46CC-9546-0588597076CE.jpg 37BE7A30-824E-4031-9C89-44AE75D1827F.jpg 901A1B36-6A4B-4B00-B9DE-8BBCFED6EA34.jpg
  23. Sep 6, 2018 at 11:45 PM
    tmart
    Travis
    Pretty noticeable rake or no? It looks good man I might go that route. Maybe with plus 2 shackles if the back is too high
  24. Sep 6, 2018 at 11:50 PM
    anthonygan
    2017 Cement TRD PRO
    Like I said it’s just this high right now becuase it’s new ! Time will tell once everything settles in how high it will be ! It’s not super noticeable but with having the rear a little higher it looks more aggressive but that’s just me
  25. Sep 7, 2018 at 1:56 AM
    YTThao530
    YTThao530 New Member
    Call Deaver and they can make what you want.. for 7” you need CB+3 too.
    I want new ICON RXT at first but called SDHQ they told me that if you set up to the higher level only good for off road but on road no good he told me customs Deaver ride better. lol
    I like my custom Deaver 3” with TC shackles about 3.5 off lift. CB+2-+3 about level to your 7”
    I haven’t try RXT yet but a lot of people like it and looking good too.
    Skyjacker has 4” lift spring too . Can’t go wrong with RXT or Deaver. Good luck
  26. Sep 7, 2018 at 7:05 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    It's progressive stack, normal driving I didn't notice much. Offroad it has a lot more flex and 13" of mainly down travel, unsure how much I had with factory leafs and blocks. I also need to have the shocks re-valved, they're valved for my old setup. I have a trailer that I hook up frequently that weighs over 4k lbs and the rear end doesn't squat much, I'm off the bumps while sitting but when towing I'm constantly hitting them. If you go this route, you'll need extended brake lines.
  27. Nov 10, 2021 at 4:02 PM
    BluFoxx82
    BluFoxx82 New Member
    2017 Blazing Blue Tundra
    7" BDS
    Do you have a specific model or something for that leafspring build that they did for you? I have the same exact lift kit as you but haven't gotten leafspring dialed in yet. Currently using the Icon RXT but not its too stiff if I go to stage 2 just to get it leveled out.
  28. May 17, 2022 at 10:03 AM
    cementsharktrd
    cementsharktrd New Member
    Demetrio
    2021 Cement Tundra TRD Off-Road
    7 inch bds coilover lift kit
    stage 3 icon rxt leafs?
  29. May 17, 2022 at 11:49 AM
    anthonygan
    2017 Cement TRD PRO
    Yes the stage 3!
  30. May 17, 2022 at 11:53 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    May wanna get you a raised bump stop
