LCAs won’t go back up
Discussion in 'Suspension' started by blakekircher, Jan 8, 2019.
  1. Jan 8, 2019 at 4:50 PM
    15whtrd
    15whtrd Mr. Blonde
    And this is exactly what I did. Although I didn’t do it in five minutes because it was my first time. But I think if you’re not lifting the vehicle or you’re just replacing a lifted coil over set up with another one the same height it can be done without messing with the alignment. I saw a video on it before it was pretty cool. He just had a 2x4 handy to pry down on the LCA
    Cypher and ColoradoTJ[QUOTED] like this.
  2. Jan 8, 2019 at 5:22 PM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    I had this happen lol! Just get a pry bar and bend down the ucas
  3. Jan 8, 2019 at 7:06 PM
    blakekircher
    blakekircher [OP] New Member
    Blake
    San Diego
    2018 Tundra TRD Sport 4x4
    3” level 17x8.5 Icon Rebounds 315/70/70 Cooper Discoverer Mtps
    update: i’ve finished the project. the Cv axle was out of place so i had to shove it back in. that’s why the knuckle wasn’t connecting to the uca. ill post pictures tomorrow. thank you everyone for the responses!
  4. Jan 8, 2019 at 9:11 PM
    LML 3500HD
    That’s what I thinking. Glad you got it put back together.
    Most of the good advice you will get on here is from bad choices in the past (my stupid and costly mistakes).
  5. Jan 22, 2019 at 8:04 PM
    blakekircher
    Blake
    San Diego
    project finished!
    Cypher, rv740, dpast88 and 8 others like this.
  6. Jan 22, 2019 at 8:30 PM
    Voyagermike
    Voyagermike New Member
    California
    Those wheels look sick!
    :thumbsup:
    blakekircher[OP] likes this.
  7. Jan 23, 2019 at 7:11 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Nice! I got the same Icon wheels on mine and really like them. What size and brand tires did you go with?
    Oh, and the vid ColoradoTJ posted in #29 is the exact same way I did mine. But it took me much longer than 5 minutes. Also, the LCA cam bolts on mine were really tight. I had to use a cheater bar and a steel tube over it to get enough leverage to break them free.
  8. Jan 23, 2019 at 9:58 PM
    blakekircher
    Blake
    San Diego
    They’re 315/70/17 Cooper Discoverer MTP’s. I had to do the exact same thing with the bolts
    equin[QUOTED] likes this.
  9. Oct 3, 2020 at 1:00 PM
    The Patriot 1776
    The Patriot 1776 Asskick Fabrication: Shit Is Sick!
    Great State Of TEXAS
    '16 TSS CM 4x4
    How could you tell the axle had slid out of the differential? I'm having an issue w/a lift & I can't figure out the problem. Thanks.
  10. Oct 3, 2020 at 1:14 PM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    What’s the problem? I couldn’t get my LCA and ball joint to connect to the knuckle when I did mine. I too thought I’d pulled out the CV axle but I wasn’t applying enough force on the UCA to bring it together to thread the lower ball joint bolts.
  11. Oct 3, 2020 at 2:28 PM
    The Patriot 1776
    '16 TSS CM 4x4
    I can get mine together but I’m running SPC UCA’s. My problem is I got 4.75” of front lift out of an OME 2.5” lift. I’ve checked and double checked everything and it all looks right. All I can think is maybe the axles have come out and are in a bind, preventing the suspension from compressing properly. They spin freely and 4wd works properly.
    Btw, I installed the lift the same way he initially did, by removing the ball joint from the UCA because I was replacing the UCA’s.
  12. Oct 3, 2020 at 2:30 PM
    glowblue
    VA
    Can’t say I have any answers, pics might help...
  13. Oct 3, 2020 at 2:58 PM
    The Patriot 1776
    '16 TSS CM 4x4
    They don’t feel like they’re in a bind as I can wiggle them up and down but this is my last option as to what is wrong with my scenario.
    DS then PS.
    65A707FA-B964-429D-86E2-B8C29990D4BF.jpg CD714E2F-F8ED-4E7D-8B34-1BFC530B631B.jpg 0EF51178-2EA8-459C-998E-A533B09C3446.jpg 75580EEF-2B6E-4EDB-A24F-D1E5EE0C61AB.jpg
  14. Oct 3, 2020 at 4:32 PM
    glowblue
    VA
    Can’t say I have any answers other than my problem was fixed by ratcheting the UCA to the LCA to get the bolts threaded on the knuckle. I had full articulation of the CV axle too.
  15. Feb 3, 2021 at 4:46 AM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Thanks so much!!!! That's the best step-by-step guide for the shock swap I've seen, should be a sticky.
    And this video as well, he takes it from start to finish, front and rear shocks:
    https://www.youtube.com/watch?v=xFG1pmuVv-E&feature=emb_logo
    splitfuse, 15whtrd[QUOTED] and equin like this.
  16. Feb 3, 2021 at 5:19 AM
    Maxtor
    Maxtor New Member
    Mark
    For those fighting to get the lower ball joint bolts back in something else to consider that may be helpful... I used a pair of spring compressors on each side of the CO to suck in the lower ball joint after jacking up the LCA to the point of lifting the truck. Was super easy to get the bolts back in with just a few turns on each side of the spring compressor
  17. Feb 3, 2021 at 5:49 AM
    glowblue
    VA
    Another option is to use ratchet straps - that was the trick I used - there is a video out there where I saw this. I couldn’t get the LCA bolts to engage the threads otherwise.
  18. Oct 22, 2021 at 5:21 AM
    jonclark96
    jonclark96 Not so new member
    Jon
    Maryland
    2021 Army Green SR5
    Glad I read this thread. I got my lift kit in yesterday and will be installing myself with some help from a more experienced buddy of mine.
