LCA Ball Joint Replacement on 2007+ 2nd and 3rd Gen Tundra
Discussion in 'Suspension' started by csuviper, Apr 19, 2017.
  1. Feb 16, 2018 at 11:05 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I read alot of the same posts about Moog failures at low miles. Same with Mevotech, decent arms and bushings but the ball joints are trash.
    TexasTundra27 likes this.
  2. Feb 16, 2018 at 11:19 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    This is interesting. http://www.suspension.com/blog/where-are-moog-parts-made/ Some good info in the comments.
    I guess you could always play the moog lottery. Or, if you have a local vendor maybe go and check all the boxes.
    Really wish there was a set of aftermarket LCA's with easily replaceable and greaseable ball joints for non long travel trucks. I want to say one of the fabricators around here was thinking of making some, but felt the market was too small. I think he did say the OEM lowers were already pretty good.
    TexasTundra27[QUOTED] likes this.
  3. Feb 16, 2018 at 11:28 AM
    duece292
    Greg
    Green Bay, WI
    That is interesting! Definitely a crap shoot when buying Moog. I'm going with OEM. Fortunately, because my shop does alot of work for the local Toyota dealer, I get a pretty good discount on parts. I also don't want to have to do this PITA job again in 10,000 miles.
    mudslinger79 and TexasTundra27 like this.
  4. Feb 16, 2018 at 11:34 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    From the above link, it sounds like the current Moog LCA's with the RK model number have a higher likelihood of having lower quality parts. Based on comments, it sounds like Moog is aware of the issues the ball joints in their lower end line, and were planning on putting their higher quality "Problem Solver" ball joints into the RK product line. The problem solver joints are supposed to have grease fittings and lifetime warranty. That info was posted a year ago. Might have to give Moog a call and see what's up.
  5. Feb 24, 2018 at 7:28 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Replaced my front rotors and pads today and no more popping or clicking. The ones I took off looked fine, so not really sure what the issue was.
  6. Feb 24, 2018 at 9:35 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    And that's why I picked up a cheap set of lower control arms off Craigslist. Going to replace the lower ball joints on those and have a fresh set ready to install so I can take off the original ones swap them out and replace that ball joint and have him sitting there ready to go for the next replacement.
    UTTundra and TexasTundra27 like this.
  7. Sep 3, 2018 at 1:57 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    So for those that have done this procedure, how did you get the lower control arm bracket (item 17 in the picture below) off of the ball joint? There isn't enough of a lip on both sides for me to get my puller on it. I have a pickle fork, but it isn't quite big enough (plus, I really hate using pickle forks) - I can go rent a bigger one, but was just wondering if others who have done this have some tricks. I have tried a few different things, but I can't get it to budge so far. Thanks for any suggestions.
    UTTundra likes this.
  8. Sep 3, 2018 at 1:58 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
    I stuck it on top of the jaws of my vice and beat the shaft of the ball joint with a 2lb hammer until it popped out.
    equin and Atomic City Tundra like this.
  9. Sep 3, 2018 at 2:09 PM
    Atomic City Tundra
    Devin
    New Mexico
    You removed your whole LCA correct? I was really hoping to not have to do that. Grumble.
  10. Sep 3, 2018 at 2:17 PM
    TexasTundra27
    Mark
    Yes sir, it sucks but just mark your alignment cams first so you can get it back to close when you put it back together
  11. Sep 3, 2018 at 3:22 PM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Yea, it was a pain in the ass. Used all kinds of pickle forks, pitman arm pullers, hammer, etc. I couldn't get it. Eventually just took it in to a shop.
    The toyota repair manual mentions a special tool. I looked it up and I think it was $1k+, haha.
  12. Sep 5, 2018 at 12:26 PM
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 RCI Skidplates eBay bumpers TRD rear sway bar
    I was getting ready to change out lower ball joints on my 2010. Seems like most failures are on first gens, but I also see a lot of moogs failing and would prefer to go original regardless of cost.
    I’ve been trying to track down the OEM part #, but all I can find is the lower ball joint support bracket. Anyone else have any luck finding the OE joint???
    dcsleeper408 likes this.
  13. Sep 5, 2018 at 12:27 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    new arms come with joint installed.
    14burrito likes this.
  14. Sep 5, 2018 at 12:33 PM
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Not the entire LCA, literally just the lower ball joint bracket that bolts to the bottom of the spindle. The listing says lower ball joint, but it says #16 on the diagram. Which doesn’t seem to be a ball joint. I even searched that part number online and I get the same results.
  15. Sep 5, 2018 at 12:39 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yes that is just the bracket. not the joint itself.
  16. Sep 5, 2018 at 12:40 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Carrier doesn't house the BJ, its pressed into the LCA
  17. Sep 5, 2018 at 12:40 PM
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  18. Sep 5, 2018 at 12:47 PM
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Right, that’s what didn’t make sense because it’s advertised as the joint itself. But the diagram showed differently.
    Right I understand, but it says ball joint in every listing I’ve found, but the diagram says it only includes #16 which is the carrier/bracket.
    So basically you can’t get just the OEM ball joint itself? You have to replace the entire LCA?
    dcsleeper408[QUOTED] likes this.
  19. Sep 5, 2018 at 12:58 PM
    #49
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    i called my local parts dept and they said that's the way to go.
    moog sells separate on rock auto, best bet next to oem.
  20. Sep 5, 2018 at 1:10 PM
    #50
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Yeah it’s looking like it. That’s a bummer though. You can’t beat OEM Toyota reliability, assuming you can find the part. Thanks for helping me clear the confusion.
  21. Sep 5, 2018 at 1:11 PM
    #51
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I’ll do some more digging when I get the chance. I was surprised when I looked up part #’s
  22. Sep 5, 2018 at 1:19 PM
    #52
    Atomic City Tundra
    Devin
    New Mexico
    Moog is hit or miss these days with quality. I wouldn't go that route. There are a couple of other options. I went with Beck-Arnley.
    I am not convinced on Toyota OEM quality when it comes to ball joints. My upper ball joints were trashed at 35,000 miles. I am at 68,000 miles now and am replacing the lower ball joints. Not that impressive.
  23. Sep 5, 2018 at 1:22 PM
    #53
    14burrito
    2014 SR5 CM 4x4 5.7
    I gotta ask why your replacing.
    If its seeping/weeping - not a huge deal at all. Leaking and movement, yes big deal.
  24. Sep 5, 2018 at 1:22 PM
    #54
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    Just spoke with the local stealership. 400+ dollars for LCA assembly. And they don’t sell just the ball joint. He sounded just as surprised as I was since they sell them for 1st gens and 4runners of course. Oh well, that answers that.
  25. Sep 5, 2018 at 1:26 PM
    #55
    Atomic City Tundra
    Devin
    New Mexico
    Before I put my aftermarket UCA's on, I was noticing a popping noise when I did a slow turn. When I put on the suspension system up front, I noticed that the upper ball joints were extremely loose. They definitely needed to be replaced.
    My lowers started seeping at 50,000 miles. I started getting a different type of popping sound under left turns at around 65,000 miles. I decided to tear into it this last weekend to check them out. And while I imagine I could squeeze out another 10 to 20 thousand out of them, I can move them easily with one finger, and the seep has progressed into a full-on leak.
  26. Sep 5, 2018 at 1:27 PM
    #56
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    You’re certainly right with the hit or miss part. I wonder if Toyota makes their own or if they outsource for them? I have 125k on originals, and the only thing wrong is the boots cracking and leaking grease, still very secure. I was just thinking for preventative maintenance as I’ve seen what ball joint failure looks like. Maybe I’ll jist ride the OEM’s out a few more years:notsure:
  27. Sep 5, 2018 at 1:29 PM
    #57
    Atomic City Tundra
    Devin
    New Mexico
    I don't know, if it were me, I would replace them. At least give some aftermarket ones a shot.
  28. Sep 5, 2018 at 1:30 PM
    #58
    14burrito
    2014 SR5 CM 4x4 5.7
    More than likely outsourced.
    What suspension were you running when the uppers "failed"?
    My lowers been seeping for a while, until they are loose my service advisor won't warranty then out for me lol
  29. Sep 5, 2018 at 1:34 PM
    #59
    Atomic City Tundra
    Devin
    New Mexico
    Stock suspension. I had been running some aftermarket wheels +30 offset and slightly larger tires (275/70/18) for about 8,000 miles, though. Not a lot of extra stress, but some.
  30. Sep 5, 2018 at 1:48 PM
    #60
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    I’ve had a 9” lift and 38’s for a little over a year now and mine are still perfect other than the cracked boots. Maybe even the OEM are hit and miss.
    I have some Import Direct ball joints I bought at cost ($16) when I worked at O’Reillys. I’d be kinda scared using those, to be honest.
