Kings or Icon?
Discussion in 'Suspension' started by Acrotalus, Oct 15, 2018.
  1. Oct 15, 2018 at 12:44 PM
    Acrotalus
    Acrotalus [OP] New Member
    TX
    2016 Quicksand TRD Pro Tundra
    Fab Fours Elite Bumpers Total Chaos Shackle TRD front and rear sway bar Westin R7 Running boards
    @TunderStorm id probably have to get new wheels or spacers as well.. I got about 1/8” clearance from my UCA with these 295’s
  2. Oct 15, 2018 at 12:50 PM
    Levidale08
    Levidale08 New Member
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Homemade bed rack with extra spare with Rhino rack,two jerry cans mounted in the bed
    I’d also get some sliders. You could get one of those steps hung up on something.
    15whtrd likes this.
  3. Oct 15, 2018 at 12:57 PM
    Acrotalus
    TX
    Haven’t had too many clearance issues, but a great point. I’m hoping the lift from suspension will spare me.
  4. Oct 15, 2018 at 12:58 PM
    15whtrd
    15whtrd Mr. Blonde
    Sounds like you need a sick long travel suspension! No matter what you get it’s going to wear out with all those miles. A buddy of mine got the eco-diesel ram at work. That thing is lame.
    trayday and papasmurf like this.
  5. Oct 15, 2018 at 1:00 PM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    The sliders are great. Yeah I’m thinking with going with the kings when my shocks are done. 2.5 with adjusters
  6. Oct 15, 2018 at 1:01 PM
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    50lb's is a lot for an "empty" truck. Empty you should be running them around the door sticker psi. I run my truck at 35 PSI.
    Kilos, 5.7TRDProm, papasmurf and 4 others like this.
  7. Oct 15, 2018 at 1:03 PM
    Levidale08
    Kevin
    Gardendale,Tx
    2015 TRD PRO
    Yes I run mine at 40
    Rica25 and Sunnier like this.
  8. Oct 15, 2018 at 1:08 PM
    15whtrd
    15whtrd Mr. Blonde
    Right? Your tires are part of your suspension. I would imagine that psi would shorten the life of your shocks if your tires are too stiff.
    Sunnier and 831Tun like this.
  9. Oct 15, 2018 at 1:11 PM
    Acrotalus
    TX
    Thanks dude. Will adjust today. Running 295/70r18 Ridge Grapp’s
    Rica25 likes this.
  10. Oct 15, 2018 at 1:12 PM
    sdhq_offroad
    GILBERT, AZ
    It will make your shocks work much harder as the tire isn't going to be soaking up anything
  11. Oct 15, 2018 at 1:17 PM
    Acrotalus
    TX
    Any rec’s on a suspension lift?
  12. Oct 15, 2018 at 1:24 PM
    sdhq_offroad
    GILBERT, AZ
    Icon will handle the washboard better but you can't go wrong with either over what is there currently. I would recommend a 700lb coil on the coilovers to help accommodate the weight that you have up front.
  13. Oct 15, 2018 at 1:25 PM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    id go with the kings 3.0 with their standard 700lb coil. icon 3.0's dont offer 700lb springs. only standard 600lbs last i check. especially with that front weight of yours.
  14. Oct 15, 2018 at 1:28 PM
    Acrotalus
    TX
    Thanks guys
  15. Oct 15, 2018 at 1:30 PM
    anthonygan
    anthonygan New Member
    2017 Cement TRD PRO
    7in BDS lift, Spyder Smoked Taillights,
    F4FD58EC-6A06-4642-899B-6AABE7352E62.jpg This is on a BDS 7in Lift!
    Otaku4life69 and signalbobby like this.
  16. Oct 15, 2018 at 1:31 PM
    sdhq_offroad
    GILBERT, AZ
    King's standard coil rate for that truck is 600lbs. As like Icon, they do not offer a 700lb spring option.
  17. Oct 15, 2018 at 1:32 PM
    signalbobby
    Robert
    AZ
    I have an email from Mike@King saying the 3.0's are 700lb coils.... Could be an error on his part.
    papasmurf likes this.
  18. Oct 15, 2018 at 1:41 PM
    anthonygan
    2017 Cement TRD PRO
    Filthy Motorsports is a great spot to buy Kings! Super knowledgeable people and very help!
    Otaku4life69 and 831Tun like this.
  19. Oct 15, 2018 at 2:14 PM
    #49
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    I have the 2.5 kings no clickers for a little over 2 years. 30,000 miles no problems, rides smooth with stock settings and I love them. I have also removed my front sway bar which helps with ride quality. Any of the shock brands will work I just chose King because theyve had less problems. LT is great but is very expensive, you can go 3.0’s front and rear, my plan is to pair a 2.5 bypass in the front and 3.0 kings in the rear. Good enough for what I do, I have sped through desert trails on this base and it’s very fun. Get the best suspension setup your budget can afford.
    TheBeast, TunderStorm and anthonygan like this.
  20. Oct 15, 2018 at 2:23 PM
    #50
    n2deep
    n2deep Pavement Princess
    ADS makes a 3.0 coil for the Tundra too. Not sure their spring rate @M C M
    All the coilovers listed will provide 2.5 -3in of lift up front.
    M C M and Ace402 like this.
  21. Oct 15, 2018 at 3:00 PM
    #51
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    ADS 3.0 from MCM FTW
    Sunnier, M C M and 14burrito like this.
  22. Oct 15, 2018 at 3:28 PM
    #52
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Icon 3.0s up front with 2.5 icon omegas out back rides extremely well.
    joonbug likes this.
  23. Oct 15, 2018 at 3:42 PM
    #53
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    X2. My RG’s are the same size as yours @Acrotalus, I run mine at 33 lbs.
    Sunnier likes this.
  24. Oct 15, 2018 at 3:49 PM
    #54
    2" or so??? Talk to ToyTec about this awesome BP-51 ARB Old Man Emu setup. Problem solved >>>>
    Rica25 and speckmon like this.
  25. Oct 15, 2018 at 3:58 PM
    #55
    sdhq_offroad
    GILBERT, AZ
    Yikes, no and no.
    Sunnier, signalbobby and Baja Mike like this.
  26. Oct 15, 2018 at 4:04 PM
    #56
    Yes and yes.
  27. Oct 15, 2018 at 4:29 PM
    #57
    I'm running 295/70/18 load range E at 51 psi up front and 47 out back and getting a nice ride and very good wear. If I ran at the door sticker psi for a stock tire I'd be seriously under inflated. The chalk test is a good indicator of idea/proper inflation
    831Tun likes this.
  28. Oct 15, 2018 at 4:31 PM
    #58
    n2deep
    But are you running 51psi off-road for 200 miles a day? I would run 25psi off road depending on the terrain.
    Black Wolf, Sunnier and 15whtrd like this.
  29. Oct 15, 2018 at 4:40 PM
    #59
    signalbobby
    Robert
    AZ
    i believe "kings pull bitches". somethang bout dat blue.
  30. Oct 15, 2018 at 4:44 PM
    #60
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    200 miles a day is a fuck ton of miles in the dirt.
    Kings or Foxes. I'd go with Kings because they use better quality internals. And with driving up to a thousand miles a week in the dirt, you're gonna need to rebuild those shocks frequently.
    Find me one race team the runs ADS or Old Man Emu equipment.
    Also, that bumper isn't doing you any favors for getting longevity out of your shocks. And drop the tire pressure for the dirt. I wouldn't go less than 35. The Tundra is heavy.
