Keys
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pwtaylor2113, May 19, 2018.
  1. May 19, 2018 at 4:30 PM
    Pwtaylor2113
    Pwtaylor2113 [OP] New Member
    i saw somewhere that you may be able to get a key and key fob integrated. My 2016 4Runner had and would like to have my 2015 Tundra key and key fob integrated.
    JH5370 and JoshuaA like this.
  2. May 19, 2018 at 6:05 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Damn i would like that too!!
  3. May 19, 2018 at 7:19 PM
    trainracer
    trainracer New Member
    Berdine and 4x4_Angel like this.
  4. May 20, 2018 at 5:41 AM
    RaginCajuns
    RaginCajuns New Member
    Prairieville, LA
    2017 Super White Tundra Platinum 4X4
    Can you program this key in your link to also lock and unlock the doors.
  5. May 20, 2018 at 5:51 AM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    I'm interested in this also
  6. May 20, 2018 at 7:47 AM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    I have that key and it works great.
  7. May 20, 2018 at 8:18 AM
    Berdine
    Binghamton, NY
    Did you program it?
  8. May 20, 2018 at 9:25 AM
    4Runner
    4Runner New Member
    Columbia, SC
    Locksmith did. Everything works just like stock keys...including remote start.
  9. May 20, 2018 at 9:54 AM
    4x4_Angel
    Bree
    Funky Town, Texas
    How much dud it run to program it?
    Berdine likes this.
  10. May 20, 2018 at 10:02 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Look at the back of your keyfob and match the FCC ID.
    Does HomeDepot or local hardware cut vehicle keys like this?
    Berdine likes this.
  11. May 20, 2018 at 1:16 PM
    TundraCoast
    TundraCoast Member In Good Standing
    Ian
    California
    1794 4x4
    1794 on the inside - PRO on the outside
    I just had my switch-blade key programmed. Received a nice high-quality key with Toyota logo feels heavy and well built. Same seller as the ebay link above. Confirm the number on the back side of your OEM key before you order. Had a lock smith cut the key $6 and my local Toyota dealer programmed it for $60. As others have said, key works perfect.
    Pic of both keys, oem key with AJT fob cover
    atrinh15, blizz86, 4x4_Angel and 2 others like this.
  12. May 20, 2018 at 1:29 PM
    4Runner
    4Runner New Member
    Columbia, SC
    Mine was $80 to cut and program.
    BTBAKER likes this.
  13. May 20, 2018 at 2:50 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    I would like one for a sister since i don't have a spare AT ALL
  14. May 21, 2018 at 3:38 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Looks like the "switchblade" key that I had for my Audi A4. Will it work for a 2018?
  15. May 21, 2018 at 6:28 AM
    Eric104
    Eric104 New Member
    Eric
    2018 Crewmax
    I haven't found one yet for the 2018's with the H code yet.
    BTBAKER likes this.
  16. May 21, 2018 at 7:31 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    Pwtaylor2113[OP] likes this.
  17. May 23, 2018 at 10:37 AM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    How does this pull apart to program? Just straight out?
  18. May 23, 2018 at 11:08 AM
    TundraCoast
    Ian
    California
    1794 4x4
    Not sure what you're referring to, are you talking about AJT key fob and putting that shell on?
  19. May 23, 2018 at 11:09 AM
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    The new flip key
  20. May 23, 2018 at 11:15 AM
    TundraCoast
    Ian
    California
    1794 4x4
    The flip key is programmed at a Toyota Dealer or qualified Locksmith with the proper software. I had my flip-key programmed at my toyota dealer cost $60. You will also need to have the key blade cut as well.
  21. May 23, 2018 at 11:23 AM
    War Machine
    War Machine SSEM # 5 3MW
    That’s the same AJT one I have. Do the buttons on yours stick occasionally?
  22. May 23, 2018 at 11:37 AM
    TundraCoast
    Ian
    California
    1794 4x4
    So you're saying you have the best AJT case? ;)
    Havent had the buttons stick, when I took apart my oem fob, I cleaned the buttons good and ran a tiny bead of silicone on a q-tip around the edges of the buttons then assembled it. No issues only been a month. I'd pull it apart on yours and give it a once over clean.
  23. May 23, 2018 at 11:38 AM
    War Machine
    I figured that was the case. It just has a click to it on occasion. I was planning on pulling it apart and seeing what the issue was.
  24. May 23, 2018 at 1:21 PM
    mlucas555
    mlucas555 New Member
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Still rocking the stock height.
    Question about the flip key. Since I have both keys and remotes now, if I get a flip key, will I loose one of the other sets? I think I remember reading something about only being able to have two remotes programmed for the truck, or can you have three? Thanks! If I can have three, I may have to look into a flip key.
  25. May 23, 2018 at 3:02 PM
    TundraCoast
    Ian
    California
    1794 4x4
    I'll have to check, I recall reading somewhere that you could have a total of 3 keys programmed. I have both my oem key/fobs and my switch blade. I'll report back
    mlucas555[QUOTED] likes this.
  26. May 23, 2018 at 7:54 PM
    TundraCoast
    Ian
    California
    1794 4x4
    All 3 of my keys work
  27. May 24, 2018 at 5:05 AM
    mlucas555
    Mark
    San Antonio, Tx
    2016 MGM Double Cab
    Thanks! I will have to look into getting a flip get for myself!
  28. May 24, 2018 at 5:46 AM
    Buse
    Buse New Member
    Chad
    Happy Valley, Oregon
    2017 Tundra SR5 QS
    Zone T5 Lift, Black Rhino Wheels, N-Fab bars, Blackout kit, Tint
    Ebay buyer's beware...... I bought an "OEM" Toyota key fob with key all in one(not flip). Toyota Logo and all, looked great. It also worked great for the first few weeks until I went to turn the ignition and the whole thing fell apart. :(
    Similar to this one.
  29. May 24, 2018 at 7:03 AM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    Can you explain what you mean by fell apart? Did the key break and you couldn’t use it to start the truck?
  30. May 24, 2018 at 7:12 AM
    Buse
    Buse New Member
    Chad
    2017 Tundra SR5 QS
    Basically the plastic housing broke off when I turned the key. I suppose it may have still worked to start the truck but let's just say super glue didn't help to make it usable. I'll see if I can find it when I get home later.
