All in one key fob...
Discussion in 'General Tundra Discussion' started by excalis, Aug 30, 2017.
  1. Aug 30, 2017 at 7:19 AM
    excalis
    excalis [OP] Cool Dude
    2017 4x4 Crewmax 5.7L Tundra
    Hello, a buddy of mine had mentioned to me that the 2018 Tundra will have the all in one key fob, have any of you heard of it possibly working with previous year models (3rd gen at least)?
    I had messaged Roman about it and he doubts it could, would be nice to have that option.
    Thanks!
  2. Aug 30, 2017 at 11:09 AM
    sanangelo
    sanangelo New Member
    I have called a few different parts counters and it seems they are not sure. Most don't even know the 2018 have this yet.
  3. Aug 30, 2017 at 1:43 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    what do you mean by all in one key fob? As in like key and buttons on one? Pretty sure 18 Tundra has smart key.
    I can probably check if you want me to...
  4. Aug 30, 2017 at 1:54 PM
    sanangelo
    I don't think it's a smart key as there is not a push to start that I can see. I am assuming they finally made the fob and key 1 item like other Toyota models.
    If you can check on your side that would be great.
  5. Aug 30, 2017 at 1:57 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
    No smart key. It's just the key and fob in one part.
    Darth Tundra and Law323 like this.
  6. Aug 30, 2017 at 1:59 PM
    sanangelo
    Will it work on a 2017 or is to early to know ?
  7. Aug 30, 2017 at 2:00 PM
    Roman
    Roman
    Franklin, TN
    Only way to find out is to try and program one to an older model and see if it will work.
  8. Aug 30, 2017 at 2:04 PM
    sanangelo
    Do we know the cost of the key yet?
  9. Aug 30, 2017 at 2:06 PM
    excalis
    TRD-tv likes this.
  10. Aug 30, 2017 at 2:12 PM
    Roman
    Roman
    Franklin, TN
  11. Aug 30, 2017 at 2:34 PM
    excalis
    That is about what I expected on it's cost. Not to bad if it works on my 2017 :)
  12. Aug 30, 2017 at 2:54 PM
    sanangelo
  13. Aug 30, 2017 at 2:56 PM
    Roman
    Roman
    Franklin, TN
    I do not, but I can order one in and check. It is only used on the 2018 Tundra, which is why we don't have any in stock.
  14. Aug 30, 2017 at 3:41 PM
    sanangelo
    If you can that would be very helpful. Now all we need is to find a Technician that can see if the techstream app can program it. If it does work I would think a large amount of the new keys could be sold.
    Roman[QUOTED] likes this.
  15. Aug 30, 2017 at 3:47 PM
    Baconator
    Baconator New Member
    Keith
    2016 White Crewmax 5.7l SR5
    It's such a nice thing, the all in one. Had it on the Camry and Corolla.
  16. Aug 30, 2017 at 3:51 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    That's what I was going to ask as well. My 2nd Gen has a G key code.
    I'm not sure I'd want to "upgrade" to this though. It seems like if you added other keys on a ring with this, it would be awkward/uncomfortable in your pocket.:notsure:
  17. Aug 30, 2017 at 4:00 PM
    sanangelo
    You just use a larger loop for your key ring. It's much nicer not having to have the extra fob.
    Filthy13 and Baconator like this.
  18. Sep 1, 2017 at 1:47 PM
    Roman
    Roman
    Franklin, TN
    Here's a picture of the new key. It has an "H" on the key.
    Ely010606 and Baconator like this.
  19. Sep 1, 2017 at 1:52 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    :confused: Woe! Finally got past the 80's and right into the 90's!
    BuckWallace, Law323, mdavis and 2 others like this.
  20. Sep 1, 2017 at 1:56 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    My other car is a 4Runner and has the all in one key/fob. It's really not bad to have in your pocket. Less bulk than we have now.
  21. Sep 1, 2017 at 2:17 PM
    sanangelo
    I am assuming that it won't work in a 17 as the 17 and earlier have a G on the key. Thanks for the pic...
  22. Sep 1, 2017 at 2:22 PM
    excalis
    Well damn...
  23. Sep 1, 2017 at 2:23 PM
    Roman
    Roman
    Franklin, TN
    More than likely correct.
  24. Sep 1, 2017 at 2:55 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Maybe in 5 years, the tundra will have keyless w/ Push Start... can only wish...
    GODZILLA and joonbug[QUOTED] like this.
  25. Sep 1, 2017 at 3:19 PM
    Roman
    Roman
    Franklin, TN
    I will say this about the key:
    00-06 $7
    07-17 $29 + programming
    18+ $168 + programming
    Typical smart key $252 + $94 laser cut key + programming
    But hey, at least you can push a button to start your truck. :D
  26. Sep 1, 2017 at 5:31 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    I've had the all in one for over two years now. Bought it on eBay and had the dealer program it.
    TRD-tv, trdprobped17, nk1794 and 4 others like this.
  27. Sep 1, 2017 at 6:45 PM
    Lo1dakota
    Lo1dakota Ermagherd
    Brandon
    Washington
    2017 Inferno CM TRD Off-Road
    18" TRD Wheels - BFG 35" Tires - OME Lift - N Fab Steps - TRD Sway Bar
    How much did the dealer charge to program it?
  28. Sep 1, 2017 at 8:06 PM
    mdavis
    Michael
    Rock Hill, SC
    I want to say $60 but not 100% on that. Been awhile.
  29. Sep 1, 2017 at 8:31 PM
    Lo1dakota
    Lo1dakota Ermagherd
    Brandon
    Washington
    Thanks for the info. I've seen posts about the program that we can use to modify all the different options on our trucks (key coding included) on another forum.. but I'm not that tech savvy.
    There's a few options for keys I've seen such as the older VW style flip out. I thought that may be a neat one too.
    edwin729 likes this.
  30. Sep 1, 2017 at 8:45 PM
    sanangelo
    Is that a OEM key? Does it have any letters stamped on the key?
