joonbug's build
Discussion in '2.5 Gen Builds (2014-2021)' started by joonbug, Nov 29, 2016.
  1. Mar 19, 2019 at 4:31 PM
    #1441
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    That’s awesome you bring your little girl with you. I bring my daughter every chance I get. She’s 13 now and loves it.
  2. Mar 19, 2019 at 4:41 PM
    #1442
    Sunnier
    Sunny
    San Diego, CA
    :mudding::thumbsup:
    :gossip: :curls: :burnrubber: :yes:
  3. Mar 22, 2019 at 7:28 AM
    #1443
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    May it is? We'll be expecting to see you then Marty! No excuses. :cheers:
  4. Mar 22, 2019 at 7:50 AM
    #1444
    Marty McFly
    Morty McBoonJug
    I wouldn’t miss the chance to wheel with the world famous bastards crew. The earlier in May the better. I’ll be on leave in May :thumbsup:
  5. Mar 25, 2019 at 8:25 PM
    #1445
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Had to redo my alignment to get my wheel away from the cab mount. It was still rubbing in reverse after a CMC. Moved the wheel forward using just the lower adjustments without having to remove the uppers to re-adjust. First time getting higher caster on the passenger side too. Ever. But I still have a slight pull to the right. Definitely better than before though. And the overall higher caster is a HUGE difference on dirt. The severe bump steer is completely gone. Almost broke a couple fingers when caster was at about 3. Just need to finish the CMC on the driver’s side now.
    BestGen, Sunnier, Watt maker and 5 others like this.
  6. Mar 26, 2019 at 8:38 AM
    #1446
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    .5* is the most I’m willing to split the caster. The pull to the right is much less than it used to be. I can live with a slight pull.
    BestGen, Watt maker and GodlessPro like this.
  7. Mar 26, 2019 at 6:24 PM
    #1447
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    If you haven’t swapped wheels from left to right try that first. Your old alignment may have messed up your tire wear.
  8. Mar 26, 2019 at 6:31 PM
    #1448
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    My truck has always pulled to the right. Ever since I lifted it. Tires don’t matter. New, old, flat, still pulls to the right. But it did get a lot better with this alignment. I’m actually pretty happy with it compared to before.
    BestGen, Sunnier and GodlessPro like this.
  9. Mar 31, 2019 at 4:19 PM
    #1449
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    3-19
    Cab Mount Chop
    Finished up the CMC today. Did the passenger side a few weeks ago but was still rubbing. So after Mojave I redid my alignment and moved the wheels forward. So I finished up the driver’s side today.
    Passenger side
    On the driver’s side, I cut the plate in half to lessen the angle and got even closer to the cab mount. Pain in the ass to make the second piece fit right, but got it pretty nice after a bunch of grinding and fitting. Got almost an inch of clearance now.
  10. Mar 31, 2019 at 4:24 PM
    #1450
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Primer first? Damn, you're a baller.:D I'm too lazy for that, straight to black.
  11. Mar 31, 2019 at 4:29 PM
    #1451
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    So the Victory LCA skid rubbed my wheel pretty good. Sanded the wheel down and hit it with some paint.
    Then chopped the corners off both skids and hit it with some paint. The other side rubbed a tiny bit too.
  12. Mar 31, 2019 at 4:44 PM
    #1452
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    And my lease ended so went in yesterday and paid off the truck. Apparently you become the second owner when you buy out the lease. WTF?
    Then last night I went to a friend’s house and drove his Bentley Continental GT. One of the prettiest cars ever made but wasn’t too impressed with the quality. I lowered the visor and the little metal piece that covers where it attaches to ceiling fell off. :D It looked like it was glued on. Then when I was getting out the car, one of the seat adjustment knobs on the side of the seat fell off. I think I hit it with my leg. My buddy was getting pissed like I was breaking everything I touched. :rofl: Other than that, it drove nice, lots of power, and I really liked the metal paddle shifters. Suspension could’ve been a little firmer. But I wouldn’t pay $240K for it though. I’ll stick to my Tundra.
  13. Mar 31, 2019 at 5:06 PM
    #1453
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Ha! If I were a baller, I would’ve used some self etching primer!
    Vizsla, 831Tun[QUOTED] and GodlessPro like this.
  14. Mar 31, 2019 at 6:24 PM
    #1454
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
  15. Apr 11, 2019 at 1:26 PM
    #1455
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Finally found a spot to mount the Switchpro. Only took about a year. Unfortunately, the Brake Controller’s gotta go. One thing I don’t do is electrical installs, so @dcsleeper408 will have to install for me this weekend.
  16. Apr 11, 2019 at 1:41 PM
    #1456
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Clean AF! :thumbsup:
    joonbug[QUOTED][OP] likes this.
  17. Apr 11, 2019 at 1:54 PM
    #1457
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
  18. Apr 11, 2019 at 2:01 PM
    #1458
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    That’s where I thought about mounting mine. Interested to see how it looks finished
  19. Apr 11, 2019 at 2:04 PM
    #1459
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Uhhh, doode, I mounted mine there..... I think you'll need to keep looking for a spot.
    Sunnier, Vizsla, dcsleeper408 and 2 others like this.
  20. Apr 11, 2019 at 2:19 PM
    #1460
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    SDHQ never came out with the sunglass holder kit, right? That's the only other spot I have on my truck and that's what I was kind of waiting for. I have the SP with the mounting tabs on the side. I was afraid I would have to drill holes through the plastic and secure with some bolts, but I cut it out pretty tight and it just snaps in and stays in. Came out better than I was expecting.
    Sunnier and dcsleeper408 like this.
  21. Apr 11, 2019 at 2:20 PM
    #1461
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    HUH? Why?
    831Tun[QUOTED] and dcsleeper408 like this.
  22. Apr 11, 2019 at 2:28 PM
    #1462
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
  23. Apr 11, 2019 at 2:28 PM
    #1463
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    It looks pretty secure the way it was setup :thumbsup:
  24. Apr 11, 2019 at 2:31 PM
    #1464
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Sorry, LAME joke.
    I wrapped the brake controller in foam, left it connected and zip tied it behind the dash.
    Did you attach to the plastic with the two little strappy bar things that come with the SP?
  25. Apr 11, 2019 at 2:37 PM
    #1465
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Everyone keeps talking about the two little strappy bar things but I don't think I have those. Don't think I need them. It snapped into the plastic and I can't get it out without bending the plastic piece. It's in there pretty good. Definitely won't be coming out by just pressing the buttons.
  26. Apr 11, 2019 at 2:40 PM
    #1466
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    he has the older model 8100 with the 2 tabs on the side to drill holes to. so those look like they are holding it from the backside sandwiching that bezel.
    joonbug[OP] and 831Tun[QUOTED] like this.
  27. Apr 11, 2019 at 2:41 PM
    #1467
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    That' awesome! Mine didn't fit that well and just wanted to pop out. I'm really happy with the switches in that location too.
  28. Apr 11, 2019 at 2:43 PM
    #1468
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Looks like it was made to fit.
  29. Apr 11, 2019 at 2:48 PM
    #1469
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    You used the trailer brake panel, huh? My SP was like 2mm wider than the trailer brake opening and the opening was too large on top and bottom. So I just used the stock panel.
    GodlessPro and dcsleeper408 like this.
  30. Apr 11, 2019 at 2:53 PM
    #1470
    BlackRiverGuy
    BlackRiverGuy New Member
    Chandler AZ
    2019 Tundra SR5 4x4 Offroad
    In Process ARE color matched Z type cap. Pro Comp 3/1 leveling kit. Nitto Grappler 295 70 R18's
    How long have you had the Coopers on? How do you like them? I just put on Cooper ST Maxx 295/70-R18, our first off road camping/fishing trip will be in 2 weeks to ultimately put them to test on basically Native American Jeep trails.
    joonbug[OP] likes this.
