joonbug's build
Discussion in '2.5 Gen Builds (2014-2021)' started by joonbug, Nov 29, 2016.
  1. Feb 19, 2019 at 3:14 PM
    #1321
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    85 SAS?
  2. Feb 19, 2019 at 3:26 PM
    #1322
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I'm just going to put a giant piece of cardboard between my sliders and truck and go to town. I have so much more to do on my truck right now that I might not even sand the rust off and just spray right over it. :anonymous:
  3. Feb 19, 2019 at 4:05 PM
    #1323
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Just get a can of Por 15. It’s meant to go over rust. No prep required. That is what I plan on touching mine up with.
  4. Feb 19, 2019 at 4:07 PM
    #1324
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    They got brush on too
    Erichudgins, 831Tun, Sunnier and 3 others like this.
  5. Feb 19, 2019 at 4:14 PM
    #1325
    InfernoPRO
    Scott
    Sacramento
    Yeah I have like 5 cans of these laying around. Open one, get paint on rim, close can... never able to open again. :mad:
  6. Feb 19, 2019 at 4:16 PM
    #1326
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Hmmmm….. Brush on does sound easier than shoving a giant piece of cardboard between my truck and sliders.
    BestGen, Watt maker, 831Tun and 3 others like this.
  7. Feb 19, 2019 at 4:16 PM
    #1327
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Lol I feel ya!! I ended up stabbing a hole to salvage the rest. I got the half gallon too.. never again.
  8. Feb 19, 2019 at 6:21 PM
    #1328
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    POR 15 is gnarly stuff. I put it on a steel boat trailer that lives at the harbor and has a salty boat loaded onto it once a week. The paint is still holding up 8 yrs later. Just be sure not to get it on anything unintentionally.
  9. Feb 19, 2019 at 6:27 PM
    #1329
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    I just did my diff with POR 15. Was actually really easy to use.
  10. Feb 19, 2019 at 6:29 PM
    #1330
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    I'm gonna coat my entire undercarriage with that stuff once this winter is over
  11. Feb 19, 2019 at 6:31 PM
    #1331
    Jimes
    Jimes New Member
    I plan on doing the same to the frame and LCAs. The diff was the tester piece just in case it came out like shit since I am putting the diff skid over it.
  12. Feb 19, 2019 at 6:32 PM
    #1332
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    I’ve used Rustoleum rust converter gel spray to good effect. Spray it on, let it set for about 30 minutes, then rinse n wipe. Good to go!
  13. Feb 19, 2019 at 6:38 PM
    #1333
    BestGen
    BestGen New Member
    Paul
    It’s an 88. Unfortunately not quite yet. Gathering the parts but the tundra and sandrail get in the way. :(
  14. Feb 19, 2019 at 6:39 PM
    #1334
    Sunnier
    Sunny
    San Diego, CA
    California no longer allows whatever magic cancer-inducing coating I use to coat mine the first time. But these at working for me now:IMG_6134.jpg IMG_6135.jpg IMG_6136.jpg
    des2mtn, BestGen, joonbug[OP] and 2 others like this.
  15. Feb 19, 2019 at 6:39 PM
    #1335
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    All good. Still the best gen imo. 22re got some punch for a 4banger.
  16. Feb 19, 2019 at 6:44 PM
    #1336
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Nosing around various trip reports and I have to say yours are probably the best. Just the right amount of detail and plenty of pics and videos.
    :thumbsup:
  17. Feb 19, 2019 at 8:33 PM
    #1337
    jc153
    jc153 Speed-ish Glamper
    San Diego
    2009 Tundra Ltd CM 4x4
    TC Front Long Travel, ADV Glass Fenders & Bedsides, TC Spindle Gussets & King LT Coilovers, RCV Axles, DuroBumps, CB Steering & Carrier Bearing Drop Kit, SDHQ ABS Sensor Shields, Rear 3.0 ADS Triple Bypasses w/MCM Fab Under Bed Shock Mount Relocation, SUA Deaver I96HD Springs & TC Shackles, MCM Fab Rear Hydro Bumpstop Kit, Solid Offroad Engine Mounts, 17" Method Standards, 37/12.5/17 Toyo RT's, Nitro 488 Gears w/Auburn LSD, Evil Off Road Bumpers, RCI Skid Plates, White Knuckle Sliders, Dirty Deeds Ind. BAMuffler 8" Catback, Baja Designs Lighting, SwitchPros Controller, Custom PS Cooler Relocation Kit, Custom Dual Battery Setup
    That looks good! Did you use the spray on or brush on por 15?
    Rica25, joonbug[OP] and 831Tun like this.
  18. Feb 19, 2019 at 9:02 PM
    #1338
    BestGen
    BestGen New Member
    Paul
    IMG_2726.jpg ^That's the stuff! Sunnier knows what's up!
  19. Feb 19, 2019 at 9:06 PM
    #1339
    BestGen
    BestGen New Member
    Paul
    I believe it is! Hence my handle. :thumbsup:
    The 22RE is an amazing little motor. The hundred hp wonder! 4.88s and 32" tires help.
  20. Feb 19, 2019 at 9:39 PM
    #1340
    Jimes
    Jimes New Member
  21. Feb 20, 2019 at 1:03 PM
    #1341
    Baja1000
    Baja1000 New Member
    Andy
    SOCAL
    2018 TRD 4X4 Cement CM
    Where did you get your antenna?
    thanks
  22. Feb 20, 2019 at 1:47 PM
    #1342
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    It's the flexible 13" from Antenna X.
    831Tun, dcsleeper408 and GodlessPro like this.
  23. Feb 21, 2019 at 3:06 PM
    #1343
    Baja1000
    Baja1000 New Member
    Andy
    SOCAL
    Thanks
    joonbug[OP] likes this.
  24. Feb 23, 2019 at 4:48 PM
    #1344
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Bastrds at BAMF
  25. Feb 23, 2019 at 6:22 PM
    #1345
    KevinK
    Tundras to Sedona
    Any good scores for the crew?
  26. Feb 23, 2019 at 6:31 PM
    #1346
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I heard the white truck picked up some gently used ADS coilovers...:rolleyes:
  27. Feb 23, 2019 at 7:00 PM
    #1347
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    Does a t-shirt and sticker count as a score?
  28. Feb 23, 2019 at 7:07 PM
    #1348
    KevinK
    Tundras to Sedona
    Nice!
    Did they come with a handjob?
    Rica25, joonbug[OP], theraven and 4 others like this.
  29. Feb 23, 2019 at 7:54 PM
    #1349
    GodlessPro
    Matthew
    NorCal
    Sadly no
  30. Feb 23, 2019 at 8:16 PM
    #1350
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Got home from BAMF and started on the cam tabs on the passenger side. Got all 4 stock tabs off. Two were flattened.
    And the mount where the flattened ones were is bent to shit.
    Need to bend it back this much but it will not budge. Going to try a bigger effin’ hammer tomorrow.
    Spolar, geno0506, ColoradoTJ and 5 others like this.
