joonbug's build
Discussion in '2.5 Gen Builds (2014-2021)' started by joonbug, Nov 29, 2016.
  1. Apr 2, 2018 at 1:31 PM
    #841
    Marty McFly
    Morty McBoonJug
    That sucks about your truck @joonbug. I hope you get that fixed soon.
    joonbug[OP] and dcsleeper408 like this.
  2. Apr 2, 2018 at 8:15 PM
    #842
    joonbug
    joonbug [OP] °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    3-29-18 to 4-1-18
    BASTRDS AT DEATH VALLEY
    Photo dump
    65252C6F-CAAD-4BC3-A173-3F8C8303C44A.jpg DB87B8BA-BB0C-4F9F-8733-68BD112DB335.jpg
    C24AD3E4-36EE-4D1F-80DF-8D100CCB5CD3.jpg FD15C366-6E4F-406E-BC35-6674B2C0899E.jpg EBA46EB4-2E9E-404E-9C71-381897552ACE.jpg
    FCD31B63-5271-4BFE-9BF9-7AF88F3A754C.jpg 39AA1A7F-37DC-4A0F-A507-4F207D2E324B.jpg
    zcarpenter92, TRON, CM-LENNY and 12 others like this.
  3. Apr 2, 2018 at 8:26 PM
    #843
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
  4. Apr 2, 2018 at 8:45 PM
    #844
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    How was seeing Manson’s hideout?
  5. Apr 2, 2018 at 8:53 PM
    #845
    Marty McFly
    Morty McBoonJug
    Badass pics and vids Joon! bastards crew :headbang:
  6. Apr 2, 2018 at 9:52 PM
    #846
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    It was very cool to see. But wished it wasn’t so dilapidated, there wasn’t too much of it left standing.
    dcsleeper408 likes this.
  7. Apr 2, 2018 at 9:58 PM
    #847
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Well, when you live in a place called Death Valley...
  8. Apr 2, 2018 at 10:50 PM
    #848
    TheBeast The Beach
    very cool ! awesome pictures..so RTT vs pop up tent ? :)
  9. Apr 3, 2018 at 2:46 AM
    #849
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    Did you guys do steel pass?
  10. Apr 3, 2018 at 7:20 AM
    #850
    Tacotundra
    Tacotundra New Member
    Vegas
    2022 Tundra
    Bad ass!!! Looks like an awesome trip.
  11. Apr 3, 2018 at 7:44 AM
    #851
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Looks like an awesome trip!
  12. Apr 3, 2018 at 8:11 AM
    #852
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Nope. I was already leaking and the road looked pretty rough. We took the guaranteed road out.
    GodlessPro and dcsleeper408 like this.
  13. Apr 3, 2018 at 8:50 AM
    #853
    n2deep
    n2deep Pavement Princess
    I blew a whole Resi and puked all my shock oil out by the springs then did 4 more days in DV with one good rear shock and one shock with no oil or nitrogen. You would have been fine. Either the seal is leaking or you have a loose fitting on the hose. I also had a rear leak once due to the hose fitting coming a little loose from all the vibration - tightened it up and off we went.
  14. Apr 3, 2018 at 10:36 AM
    #854
    sdhq_offroad
    sdhq_offroad New Member
    GILBERT, AZ
    That's a bummer man! Unfortunately, we did have some bad luck with the RXT rears and they kind of all hit at once so we weren't able to catch it before hand for a lot of people. Sounds like @Icon_Adrian and Icon went out of the way to get you taken care of to get that fixed for you because I don't think anybody else got taken care of like you did.
    Between our shop and my personal truck, we have hundreds and possibly even thousands of dirt miles on the 3.0's and RXT set up. I know @KevinK is also running the 3.0 set up without any issues. Where your shocks are leaking are definitely out of the normal as that isn't a moving seal. It is hard to see if it is leaking from the hose fitting or the seal around the CDCV failed. Your 3.0's are actually be the first leaking set that I have seen and these have been on the market for a year now if not more. I am sure Icon will get you taken care of.
    As far the upper control arms, not all trucks need to cut the 3/16" off. It all depends on lift heights, etc. Cutting the 3/16" off the tie rod is no big deal. You aren't losing any thread engagement and I don't know why people keep bringing that up. The 3/16" is being cut off the inner so that the outer tie rod can be turned down farther to bring the toe in more. When we do the installs here, I say we probably cut 3 out of every 10 that we do. Its honestly not that big of a deal. If the instructions were read, it also does state that they may have to be cut in the tech notes.
    As far as being out performed by stock Pro and ADS suspension, what did you have your adjusters set at? Where were your bypass tubes set up? Some stuff just isn't adding up.
    Sorry we couldn't of been the ones to install it all to make sure it was 100% but if we can do anything to help, you know how to contact me. We will do as much as possible to make it right.
    itsdchz, Icon_Adrian, blue16 and 6 others like this.
  15. Apr 3, 2018 at 11:20 AM
    #855
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Thanks Joey. But I don't think you guys installing it would've made any difference. There's really nothing you could have done differently on the install to prevent the resi from leaking. And like other's have said, I think cutting the tie rod might work, but it seems like a fix that's masking the incorrect angles of the Icon arms. I don't think any other arms require cutting the ties other than maybe a bracket lift or something. And I never said it was out performed by a stock Pro and ADS suspension. I basically said they outlasted the Icons. I never even got a chance to play with the settings as the resi was leaking within the first hour or so.
    And I'm sure Icon will cover this under warranty but I still have to remove it, and possibly borrow and re-install a temporary and ship it to them and then do it all over again when I get it back. I've already installed the fronts, removed them to swap sides and installed again. Installed the rears, removed them and installed the temps to send back to fix. And then re-installed the rears again when I got them back. It might be no big deal for you guys with a shop and a lift, but for me it's a major pain in the ass. I'm basically doing this install like 4 or 5 times now. Just not what I was expecting after spending almost $7k on this suspension.
    landphil, d0zer, blue16 and 9 others like this.
  16. Apr 3, 2018 at 11:24 AM
    #856
    froggy78
    froggy78 Loco Moco Bastrd
    JP
    SF Bay Area
    1794 TRD
    Joon, you should be proud of yourself. Your shakedown was less than 100's or even 1000's less than the others and if my calculations are off like i believe they are, it took you just 40 miles. We should also work on your 3rd grade reading level.
  17. Apr 3, 2018 at 11:34 AM
    #857
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
  18. Apr 3, 2018 at 11:36 AM
    #858
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    There were a couple really narrow spots where I had to roll my window down to check my tire placement, but it wasn't as bad as I was lead to believe it would be.
  19. Apr 3, 2018 at 11:37 AM
    #859
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes. It was pretty much about 30 minutes of pluckered ass. @TRD15559 drove down the entire way grabbing the passenger side grab handle while he was driving. :rofl:
  20. Apr 3, 2018 at 11:42 AM
    #860
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Good job to you and Joon taking the lead! you guys did great! Felt good to sit in the back and watch everyone enjoying and working together to get the the next man up!
    froggy78 and joonbug[OP] like this.
  21. Apr 3, 2018 at 11:42 AM
    #861
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    yep.. my seat was a little moist after.
  22. Apr 3, 2018 at 11:44 AM
    #862
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    lmfao!!!
    next trip joon 10k elevation and sooopy is rolling!
    GodlessPro and joonbug[OP] like this.
  23. Apr 3, 2018 at 11:46 AM
    #863
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Lippincott is a 2 way road? Just wondering wtf we would've done if we hit another oncoming caravan.
  24. Apr 3, 2018 at 11:46 AM
    #864
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    we got tundras..
    push that motherfucker off, and on with the trip!
  25. Apr 3, 2018 at 11:52 AM
    #865
    GodlessPro
    Matthew
    NorCal
    Well we did have to stop for the bikers. There was no way I was going to reverse to find a pullout area, it would have been a standoff.
  26. Apr 3, 2018 at 12:07 PM
    #866
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Damn @joonbug I'm super bummed to see your issue. We've had the 3.0 on since June or July last year. Come to think of it, we're probably due for a rebuild already.
    I don't know how much fluid you lost, but it almost looks like a quick turn of a wrench on the fitting might solve it? Not that it should have happened in the first place, but might be a quick fix at home without all the damn headache.
  27. Apr 3, 2018 at 12:18 PM
    #867
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Thanks Kevin. Yeah, haven't taken the resi off yet to take a look and not really sure how the resi is built, but the top cover of the resi where the elbow comes out is loose and the whole top is twisting in place.
  28. Apr 3, 2018 at 12:31 PM
    #868
    KevinK
    Tundras to Sedona
    Well fuck - that ain't good. I hope it's something you can take care of without it being a major ordeal. Keep us posted on how it goes buddy.
  29. Apr 3, 2018 at 12:34 PM
    #869
    sdhq_offroad
    GILBERT, AZ
    It is because you lost oil and/or nitrogen pressure now there is a void. So it will be almost free floating.
  30. Apr 3, 2018 at 4:46 PM
    #870
    joonbug
    Joon
    NorCal - Dublin
    2020 LT DC
    Adrian from Icon just called. They’re going to ship out new 3.0’s to swap mine out. Said it might take a couple of weeks. At least I won’t have to install twice now. Although I’ve been a little unlucky with this setup, gotta say the customer service at Icon is top notch.
