JBA Rant. Back to the drawing board with Headers (Kooks, ARH, AFE)
Discussion in 'Performance and Tuning' started by swank501, Apr 2, 2019.
  1. May 28, 2019 at 6:42 AM
    #61
    UTTundra
    UTTundra New Member
    Lou
    Utah
    Good choice. The Kooks do looks nice, too. I imagine they are very similar to the ARH in design and quality.
  2. May 28, 2019 at 7:28 AM
    #62
    Jonlee124
    Jonlee124 New Member
    Jonathan
    Houston
    2014 Tundra white 5.7L
  3. May 28, 2019 at 9:26 AM
    #63
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    I also just installed ARH LT exhaust with 1 3/4 primaries. Install wasn't too bad. It was definitely a chore to get to all of the studs but when I got them all tightened down I had zero issues with leaks.
    Sas and Myhobbes25 like this.
  4. May 28, 2019 at 9:54 AM
    #64
    sundance
    sundance New Member
    Do you feel like you're getting the stated HP gains? I assume you're using a DAP tune?
    Just asking. Thinking about options. Thanks!
  5. May 28, 2019 at 10:03 AM
    #65
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    Yes to both. I have a DAP tune. And yes, there were noticeable gains. I haven't put it on a actual dyno, but the butt dyno says there is a very noticeable difference.
    Rex Kramer and sundance like this.
  6. May 28, 2019 at 10:25 AM
    #66
    sundance
    sundance New Member
    Thank you!
  7. May 28, 2019 at 11:14 AM
    #67
    swank501
    swank501 [OP] New Member
    2007 single cab 4x4
    TRD S/C Crewmax window conversion Auburn LSD Custom interior
    WHat catback did you use with their system?
  8. May 28, 2019 at 12:40 PM
    #68
    MIM
    MIM New Member
    SLC, UT
    2015 CM Ltd MGM
    I have the ARH cat back. I installed the full ARH system.
    https://americanracingheaders.com/collections/toyota/products/toyota-tundra-2006-up-full-system
    In terms of sound, it is definitely a bit deeper and more aggressive than the stock exhaust. It makes a nice growl on a cold start but then is pretty quiet and mellow while cruising but definitely makes a nice deep growl when under WOT. I used to have a BAM 8" standard muffler with the stock tailpipe. I didn't ever install the resonator on the BAM so the BAM was a bit louder while cruising but pretty similar under WOT.
  9. May 29, 2019 at 5:09 AM
    #69
    swank501
    2007 single cab 4x4
  10. May 29, 2019 at 6:37 PM
    #70
    Myhobbes25
    Myhobbes25 New Member
    Jeffery
    Western Washington
    2014 Toyota Tundra Platinum
    Rigid fog Lights, 35x12.50x20 BF Goodrich KO2 Tires, 20x9 Fuel Trophy Wheels, Pro Comp Stage 2 Full Suspension Lift 6 inches, K&N Intake, Magnaflow Muffler, Husky X Contour Floor mats, Pina Colada Scented Tree
    Sell me the trd and you're well on your way!
