James Taylor Infinity Amp/Sub Group Buy Install Help Needed
Discussion in 'Audio & Video' started by 2chains, Feb 11, 2020.
  1. Feb 15, 2020 at 12:08 PM
    #61
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    When I put the power to it the radio stays powered on when I take keys out
  2. Feb 15, 2020 at 12:09 PM
    #62
    AZBoatHauler
    So.Arizona
    That’s because you have the small red wire in the wrong location. The way you have it in the picture it is the same as having the small wire directly connected to the battery because it is in the power slot.
  3. Feb 15, 2020 at 12:11 PM
    #63
    AZBoatHauler
    So.Arizona
    Unhook your battery and fix the wiring.
  4. Feb 15, 2020 at 12:11 PM
    #64
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Ok I just did that now headunit and system won’t turn on at all?
  5. Feb 15, 2020 at 12:13 PM
    #65
    AZBoatHauler
    So.Arizona
    You’ll probably need to check fuses. You had power going the wrong way through the small red wire.
  6. Feb 15, 2020 at 12:44 PM
    #66
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    It works if I have it hooked up to power still. Just no rem. It stays on when truck is off
  7. Feb 15, 2020 at 12:45 PM
    #67
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    What fuse would it have been probably ?
  8. Feb 15, 2020 at 12:58 PM
    #68
    AZBoatHauler
    So.Arizona
    take a pic of how you rewired it.
  9. Feb 15, 2020 at 1:01 PM
    #69
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    I had it just like the previous pic. Then I have it so the red wire goes directly into the rem slot and now it doesn’t work at all
  10. Feb 15, 2020 at 1:03 PM
    #70
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
  11. Feb 15, 2020 at 1:07 PM
    #71
    AZBoatHauler
    So.Arizona
    It sounds like you may have blown the fuse upstream from the small red wire on the plug and play harness. When you connect it to power slot, it feeds backwards bypassing the blown fuse.
  12. Feb 15, 2020 at 1:12 PM
    #72
    AZBoatHauler
    So.Arizona
    If you want to be sure, take out the small red wire, turn the key on and see if you have voltage.
  13. Feb 15, 2020 at 1:30 PM
    #73
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    I must have a blown fuse. Do u have any idea which fuse is for headunit stereo
  14. Feb 15, 2020 at 1:43 PM
    #74
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Got it it was the acc fuse under steering wheel. I hooked up that wire bc the pic in the instructions looked like it went there. Thank you so much @AZBoatHauler
    AZBoatHauler likes this.
  15. Feb 15, 2020 at 1:44 PM
    #75
    AZBoatHauler
    So.Arizona
    You’re welcome. Glad you found it.
  16. Feb 15, 2020 at 1:55 PM
    #76
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Also I have a remote start and I bumped the add a fuse for my ignition and after all that the truck wouldn’t start for ten mins until I found what happened. That ten minutes probably took a year off of my life. Def not quitting my day job
  17. Feb 15, 2020 at 7:16 PM
    #77
    2chains
    2chains [OP] New Member
    Southern Ablerta
    amp and connectors1.jpg amp2.jpg thicker red wire in separate small harness goes to REM
  18. May 11, 2020 at 6:25 PM
    #78
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Reviving this thread to ask a question since I finally got to this installation - is there a trick to getting the ring terminals on the power wires? I tried pliers for clamping, I tried hammering them down, I tried soldering them in place - nothing would stick, they'd all slip off like I didn't clamp them at all.
    I've destroyed all the terminals already so have to go buy new ones, hoping I can find screw tightening ones. The rest of the install went so easily, even sliding the wires through the grommets only took a few seconds (hardest part was getting the nub cut off) yet I'm pulling my hair out with what sounded like the easiest part.
  19. May 12, 2020 at 5:10 AM
    #79
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    This is also what James told me but when I use a SMD DD-1 the signal distorts at a gain of ½ for the sub and ¼ for the F/R outputs. Now...I also set the these by first measuring distortion of the stock JBL headunit (signal distorted at a volume 57 out of 60). So if I use these settings does that just mean I will get the same performance just at a lower volume?
    Also, should the sub be set to Int or Ext with the stock JBL HU?
  20. May 12, 2020 at 6:25 AM
    #80
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Crimping pliers. Beefy ones. Not the all in one electrical plier type thing. Hardware store will have them. Channelock makes a good one.
    ETA... The kit has 4 gauge terminals and4 gauge wire. You can step down to 6 gauge terminals to make them a little easier to crimp by hand.
  21. May 12, 2020 at 7:38 AM
    #81
    belanger9
    Edmonton, AB
    A bunch
    Thanks, I'll get a few of those to try. I'm hoping the audio store will have some of the screw tightening ones too. The butcher block on my toolbox took a beating yesterday trying to hammer the 4 gauge ones that came with the kit.
