James Taylor Infinity Amp/Sub Group Buy Install Help Needed
Discussion in 'Audio & Video' started by 2chains, Feb 11, 2020.
  1. Feb 11, 2020 at 3:53 PM
    2chains
    2chains [OP] New Member
    Southern Ablerta
    Has anyone completed their install? I'm a noob to audio and I can't figure a few things out. I've searched some threads but didn't find the exact question answered.
    I have non JBL 2019 Tundra purchased the Infinity Kappa Five amp/sub/Hertz Uno speaker kit and keeping the factory head unit.
    The speakers connect to the amp as per the manual but where is the ideal location to connect the wire at the new speaker? Do I cut the factory wire and splice somewhere?
    Can anyone outline how the Kappa Five amp ties in with Axxess ax-mloc740? The Axxess has two left/two right cable connectors but i don’t see how they connect. The other end of the LOC is white 12pin, where does that connect to?
    I have one white 5pin connector, Can anyone tell me where does that goes?
    Here is a pic of what I'm talking about. Any help would be great!
  2. Feb 11, 2020 at 4:03 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Call James. He will walk you through everything!
  3. Feb 11, 2020 at 7:10 PM
    2chains
    Southern Ablerta
    I emailed him similar questions and he indicated all solutions were on his facebook page. I couldn't follow anything there as I'm not familiar with facebook.
  4. Feb 11, 2020 at 7:21 PM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Have you pulled the factory amp from under the passenger seat yet?
    Do you have RCAs?
  5. Feb 11, 2020 at 7:22 PM
    2chains
    Southern Ablerta
    I pulled the cover off and then chickened out! Do I need to have a closer look? my garage lighting is the pits.
  6. Feb 11, 2020 at 7:25 PM
    LogCabins
    'Merica
    2017 TRD Pro
    Is there not connectors plugged into your factory amp?
  7. Feb 11, 2020 at 7:27 PM
    LogCabins
    'Merica
    2017 TRD Pro
    The LOC would connect to the amp with RCAs
  8. Feb 11, 2020 at 7:27 PM
    2chains
    Southern Ablerta
    I do have connectors but wondering where the loc goes in at the new amp.
  9. Feb 11, 2020 at 7:31 PM
    2chains
    Southern Ablerta
    I appreciate the help, RCA's ok I see, so there are six rca's hookups in new amp..sub/rear/front so the four from loc go to the four in the amp leaving the sub pair empty?
    LogCabins likes this.
  10. Feb 11, 2020 at 7:31 PM
    AZBoatHauler
    So.Arizona
    RCAs
  11. Feb 11, 2020 at 7:36 PM
    LogCabins
    'Merica
    2017 TRD Pro
    Yes you should have one set going front L rear L and second set going front R rear R
  12. Feb 11, 2020 at 7:39 PM
    2chains
    Southern Ablerta
    thanks for the help I was confused by the six connects on the amp and four on the loc didn't make sense when i first started...going to check the wire amp kit for RCA's
  13. Feb 11, 2020 at 7:43 PM
    LogCabins
    'Merica
    2017 TRD Pro
    So to break it down, our stock Non-JBL doesn’t have a sub....the connector with the LOC James sent will connect to the stock connector off the factory amp and that will give the ability for your new amp to run to your door speakers. The speakers in your dash run off the factory HU.
  14. Feb 11, 2020 at 7:48 PM
    LogCabins
    'Merica
    2017 TRD Pro
    trying to figure out what you are asking here?
  15. Feb 11, 2020 at 7:51 PM
    2chains
    Southern Ablerta
    the manual says to run new wires from speakers to the amp...do I need to run new speaker wire from the new speakers to the amp? I thought with the harness I wouldn't need to do that.
  16. Feb 11, 2020 at 7:52 PM
    LogCabins
    'Merica
    2017 TRD Pro
    No do not run new wires...that is why you have the connector with the LOC
    2chains[QUOTED][OP] likes this.
  17. Feb 11, 2020 at 7:54 PM
    2chains
    Southern Ablerta
    ok that's what I was thinking but then I read the manual... my kit came with 50ft of 14g wire and wasn't sure where that fit in
  18. Feb 11, 2020 at 7:57 PM
    LogCabins
    'Merica
    2017 TRD Pro
    I would imagine if you got a sub...you are going to need to wire that to your amp.
  19. Feb 11, 2020 at 7:59 PM
    LogCabins
    'Merica
    2017 TRD Pro
    Did you run the power wire from your battery to the amp location? That will probably be the most “difficult” part....getting that 4ga wire through the grommet in the firewall
  20. Feb 11, 2020 at 8:02 PM
    LogCabins
    'Merica
    2017 TRD Pro
    Also if you got new Hertz door speakers you will have connectors for those from James that connect to the factory speaker connectors....be careful connecting them to the posts on the new Hertz speakers they are tight/hard to push on, you don’t want to break a post...also you will need some posi taps or t-taps to connect your tweeters
  21. Feb 11, 2020 at 8:07 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Really? This gives me zero confidence since I don't have that option. I'm guessing I'll have to add on to this thread once I start digging into my system that just got delivered, but that won't be until it warms up since I have to do it outside.
  22. Feb 11, 2020 at 8:55 PM
    2chains
    Southern Ablerta
    Got the sub but that distance to the amp is short so I was wondering about all that wire that was included...in short I was over thinking it.
    I feel good with that as I've installed a couple light bars and an auxiliary Blue Sea fuse block in my 4runner. (looking to do same with my Tundra) The one thing I'm wondering is which side to run it. I'm thinking passenger as I may only have to tip the seat back and not remove it? I like the idea of running the wire along the back of the engine bay.
    Thanks for the tip on the connectors, I'd typically rush something like that. I have used positaps on my 4runner and really like them!
    LogCabins[QUOTED] likes this.
  23. Feb 11, 2020 at 9:03 PM
    2chains
    Southern Ablerta
    sounds great @LogCabins advice will really help guide you when you get going on this if you're a noob like me. I have a tendency to over think any electrical projects i do so there's that as well..
  24. Feb 12, 2020 at 5:02 AM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    I did this over the weekend. Hit me up if you have any specific questions.
    If you haven’t put the wire through the firewall grommet yet, consider getting an olfa-type knife because you can slide the blade into the grommet hole to make a couple cuts which loosens the sphincter.
  25. Feb 12, 2020 at 5:31 AM
    LogCabins
    'Merica
    2017 TRD Pro
    I think you could help this guy out immensely if you could take a few picks of the amp hooked up, so he could see the connectors (5pin and 12pin) and where the RCAs from the LOC go
  26. Feb 12, 2020 at 5:53 AM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    I’ll see what kind of pic I can get with the seat in. He’s probably doing what I did with overthinking it. James makes it so we don’t have to think so when we do we get confused!
    2chains[OP] and LogCabins like this.
  27. Feb 12, 2020 at 5:57 AM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    How does the sub get hooked up without rcas. I put rca splitters and it’s fef not correct. It works but
  28. Feb 12, 2020 at 5:59 AM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    @2chains did James send you the installation instructions? Page 13 has a pic of the back of the kappa amp with the wires inserted.
  29. Feb 12, 2020 at 6:04 AM
    Alexstundra
    Northeast PA
    2016 MGM DC Trd
    Yeah the only two pics are 62D6C9B4-ED78-400F-80A3-DF9336085A0E.jpg37E9878C-8D32-4E82-ADEB-5A62C51CDFC9.jpgI have it setup in the first picture. Sub did not work. And the second picture is a different amp and it shows three sets of rcas. I only got two. And he said I only need two. He said I hAd something turned off but when I did the rca splitter it worked
  30. Feb 12, 2020 at 6:19 AM
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    @Alexstundra do you have the infinity kappa 5 amp? If so, settings are on page 16.
