Is there a cell phone mount for the coin tray?
Discussion in '2nd Gen Tundras (2007-2013)' started by perl, Mar 4, 2020.
  1. Mar 4, 2020 at 5:01 PM
    perl
    perl [OP] New Member
    2011 White Tundra SR5 2WD 4.6
    Just asking
  2. Mar 4, 2020 at 5:28 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Yes
    GODZILLA, TXMiamiFan and TechWrench like this.
  3. Mar 4, 2020 at 5:28 PM
    Pudge
    CT
    Maybe
  4. Mar 4, 2020 at 5:29 PM
    Pudge
    CT
    Probably not
  5. Mar 5, 2020 at 7:10 AM
    greghoro
    greghoro New Member
    Greg
    2012 Sequoia Limited
    I agree with Pudge
    GODZILLA and TXMiamiFan like this.
  6. Mar 5, 2020 at 7:27 AM
    Doylfish
    Doylfish New Member
    2016 Tundra 1794 Crewmax
    Define coin tray
  7. Mar 5, 2020 at 9:22 AM
    Pomp_Cat115
    Pomp_Cat115 New Member
    Los Angeles, CA
    I'm assuming this, since this is what I have in my truck
  8. Mar 5, 2020 at 9:28 AM
    Pomp_Cat115
    Los Angeles, CA
    Or this coin tray
  9. Mar 6, 2020 at 4:48 PM
    Tipsovr
    Tipsovr New Member
    2012 RW Crewmax
    I bought one of those Weathertech "cup phone" things... works great. CupFone_360_A-IMG_00733.jpg
    surffj62, Blue Thunder and Les7311 like this.
  10. Mar 6, 2020 at 8:41 PM
    perl
    The coin holder own the dash. Your 1st photo.
  11. Mar 8, 2020 at 9:21 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    What coin holder?
  12. Mar 8, 2020 at 9:24 AM
    perl
  13. Mar 8, 2020 at 9:25 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    Not in mine.
  14. Mar 10, 2020 at 8:15 PM
    08crewmax
    08crewmax New Member
    CA
    ‘08 Pyrite Mica Crewmax Limited
    You either have 4 wheel drive knob or the coin holder in 2 wheel drives
    bleach and perl[OP] like this.
  15. Mar 11, 2020 at 9:14 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    There ya go. :thumbsup:
  16. Jun 2, 2020 at 1:52 PM
    cfe4130
    cfe4130 New Member
  17. Jun 2, 2020 at 4:09 PM
    cfe4130
    cfe4130 New Member
    I'm working on turning the coin holder into a phone holder. I removed the coin holder today and was surprised that there was an electric plug connected to it. Is this plug for the 4x4 switch?
  18. Jun 2, 2020 at 6:45 PM
    LennyFL
    LennyFL New Member
    New to me 2007 with 59,600 miles
    Keep me advised on the steps you go through, lots of photos please.
  19. Jun 3, 2020 at 5:01 PM
    cfe4130
    cfe4130 New Member
    I just got finished. I bought a Scosche Mount from Walmart and door hole filler plate and a sliding door pull. I was amazed that the sliding door hole pull was the perfect size. I drilled a hole in the Scoshe plate and stuck it on the sliding door pull. Then I drilled a hole into the pull for the screw that I had found in my garage. The screw was a bit long, but it was all I had.
    Then I used one of the filler plates which went on the back of the dash plastic. I added some washers and a nut. I tightened it up and was done.
    Chipskip, 08Tundra15, Kn4x2 and 2 others like this.
  20. Jun 3, 2020 at 5:06 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I got this but it doesn't fit the under the dash cup/coin holder hole.
  21. Jun 3, 2020 at 6:47 PM
    LennyFL
    LennyFL New Member
    Thank You, Looks like I'm headed to WalMart and Home Depot this weekend.
  22. Jun 4, 2020 at 9:17 PM
    Kn4x2
    Kn4x2 Common sense is not so common!
    3rd rock from the sun
    2010 DC 2WD
    Afe Pro Dry filter Tinted windows Coverking seat covers Traxion tailgate ladder Auto vox M1 backup camera
    How did you get the filler plate behind the dash?
  23. Jun 4, 2020 at 9:22 PM
    cfe4130
    cfe4130 New Member
    After you pull the coin holder out, it's easy to just pull that area of the dash out. My job would have been easier if I had a smaller screw, but I had enough room to get my hand behind ther
  24. Jun 5, 2020 at 8:33 PM
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    While it doesn't use the coin holder, I was in search of a phone holder that kept the phone in a usable position in a good eye-line and that didn't obscure any of my controls.
    I got one of these:
    https://www.amazon.com/gp/product/B07X4YDKTF/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
    The holder is excellent and holds the phone very well. It allows for the phone to be easily placed and removed from the holder, and it is a wireless charger. The only problem with it was that the mount is rather large, and I couldn't find a placement for it that wasn't in the way of something or didn't obstruct my view through the windshield. I don't like the air vent mounts as they can damage the vent vanes over time, and the CD player mount is not feasible.
    So I got one of these:
    https://www.amazon.com/gp/product/B009AYLYWA/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    It is a hard point with a 17mm ball that fits the mount.
    This combination allowed me to mount the phone holder/charger just about anywhere on the dash that I wanted. My placement was just above the coin holder location (or 4WD selector on my model) and still allowed me to access all of the controls as well as keep the phone at a usable eye-line.
    (This hard point is similar, but it has a measure of articulation as well as providing a small bit more clearance between the dash and the phone mount/charger. https://www.amazon.com/gp/product/B00BLSBYPK/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1 ).
  25. Oct 6, 2021 at 5:11 PM
    Julikins53
    Julikins53 New Member
    Simi Valley, CA
    2013 Red CrewMax Limited
    Remote start
    Did you have to tear up the coin holder to get it out? I managed to finagle mine out one time, to do the cell phone mount, but got tired of looking at the hole, stuck it back in, now I can’t get it out again. Should have taken a picture‍♀️
  26. Oct 14, 2021 at 4:31 AM
    cfe4130
    cfe4130 New Member
    I don't believe so. I think I just pulled it out. You will have to pull out the trim (not all the way) that it is attached to in order to install everything. Pull the trim and try to pop it out from behind.
  27. Oct 14, 2021 at 5:48 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    I just drop mine in a cup holder.......
  28. Oct 14, 2021 at 12:17 PM
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    Freakin ingenious!
  29. Oct 15, 2021 at 12:48 PM
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
  30. Oct 16, 2021 at 8:53 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Mine lives in the door pull/closing handle recess. Tho I don't play with my phone very often while driving.
