Is it worth it?(long read)
Discussion in '1st Gen Tundras (2000-2006)' started by bmf4069, Sep 1, 2018.
  1. Sep 1, 2020 at 11:09 AM
    bmf4069
    bmf4069 [OP] Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
    No, more of a long winded intro, and my first repair. I've done more since this one.
  2. Sep 1, 2020 at 11:11 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  3. Sep 1, 2020 at 11:13 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Saving this to my personal meme folder.
    Thank you for this.
    Darkness and bmf4069[QUOTED][OP] like this.
  4. Sep 1, 2020 at 11:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Just in case you need another:
  5. Sep 1, 2020 at 11:15 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  6. Sep 1, 2020 at 11:16 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Tundra2[QUOTED] likes this.
  7. Sep 1, 2020 at 11:48 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Like a walk down memory lane here, when we all wondered who is this dude with valve covers in the washer?
  8. Sep 1, 2020 at 1:42 PM
    Professional Hand Model
    Hand Protectors
  9. Sep 1, 2020 at 8:12 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Holy hell, it's been 2 years today. Damn.
  10. Aug 6, 2025 at 7:22 AM
    DKC
    DKC New Member
    Dillan
    2001 Tundra v8 Limited
    Just keeping it alive
    I'm needing some help with this. Hoping you are still active? I'm wondering where you found a spot to connect the knock sensor harness to a quick connect? I had to solder mine in but still getting a code.
    01 V8 Knock sensor wiring | Toyota Tundra Forum
  11. Aug 6, 2025 at 7:43 AM
    How many years now? Holy zombie thread.
    Dude, he literally posted in your other thread :rofl: Why'd you need to resurrect this 5 year old corpse? :D
    bmf4069[QUOTED][OP] likes this.
  12. Aug 6, 2025 at 8:00 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
  13. Aug 6, 2025 at 8:06 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Still active? Sheeeet, I'm part of the scenery at this point. I didn't find anything for a harness, even on the backside of the motor. I chopped that connector off and just spliced it in, then taped the whole thing up. IIRC, you said you got some non OEM knock sensors? Any electrical sensor needs to be Denso, Hitachi, or Bosch.
    DKC[QUOTED] likes this.
  14. Aug 6, 2025 at 8:08 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Damn dude, It'll be 7 in a few weeks. Time flies....
    shifty`[QUOTED] likes this.
  15. Aug 10, 2025 at 11:39 AM
    DKC
    DKC New Member
    Dillan
    Would it not code for each bank if that was the case?
  16. Aug 23, 2025 at 3:57 PM
    Ihatecarissues
    Ihatecarissues New Member
    2001 tundra limited access cab 4WD V8
    Are you saying the fix of the knocksensors helped you shifting? my trucks doing the same thing and i have both sensors out so just wondering
  17. Aug 23, 2025 at 6:43 PM
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    I’d keep it as long as body and frame are in good shape.
    But its kind of right in line with many of vehicles I’ve had over years as they were either just bodies i acquired, or vehicles with straight bodies needing seats transmissions, engines etc for cheap, and I’d slowly fix them up.
  18. Aug 24, 2025 at 10:12 AM
    Once a knock sensor code is set in your ECU, your truck will immediately go into "limp mode" when the check engine light kicks on. While you're in limp mode, the truck will run like ass (no power), you can't shift above a certain gear (I think 3rd), and can't get your RPM above a certain level (I believe 2k RPM).
    If you currently have a knock sensor code set, this would absolutely cause the shift-limiting and rpm-limiting problems I just mentioned, and they won't go away until you either (A) clear the code with a reader, or (B) fix the problem so the code clears automatically. If you opt for (A), the code will come right back again when the ECU detects the problem, so fixing the issue - which is typically the wiring being chewed/damaged, not a knock sensor failure - you'll be struggling with driving your truck.
  19. Aug 25, 2025 at 4:33 AM
    #49
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    It was shifting pretty rough but got better after the fix. You'd know if your knock sensors or wiring were bad though. You probably just need a fluid swap.
    If this is for me, I've already put about $12k back into the truck since this post. He runs better than ever.
    Redoak[QUOTED] likes this.
