01 V8 Knock sensor wiring
Discussion in '1st Gen Tundras (2000-2006)' started by DKC, Aug 4, 2025.
  1. Aug 4, 2025 at 11:39 AM
    DKC
    DKC [OP] New Member
    Dillan
    2001 Tundra v8 Limited
    Just keeping it alive
    Sat on my dad's farm too long and mice chewed up the knock sensor wiring.
    I got in and cleaned it up. Purchased new wells knock sensors and a new harness but the original had no quick connect, so I had to solder it in grey to grey and black to black
    However, brown only exists on the sub-harness so I looked at the diagram and soldered it to the shielding around the other two wires
    but after it was all put back and running it still coded on bank 1 no matter how I cleared it, code always came back. I've got it back apart and I found diagrams that indicate that the brown from the knock sensor sub-harness goes to ground point e4 but I have no clue what that looks like in real life. Is it a spot on the wiring harness? Is it a spot on the block?
  2. Aug 4, 2025 at 12:32 PM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    Honestly I can’t even tell from your photos what is happening; but if you need to ground your 3rd wire and that’s what you’re asking, just run an extra wire back behind the block and attach it to a ground or find one along the fender to attach it to; I’m not super familiar with the first gens so I can’t tell you exactly where that ground is but one of the guys here might chime in
  3. Aug 4, 2025 at 12:33 PM
    joseph_womack
    Joe
    Louisiana
    Also that shielding most likely isn’t grounded, probably shielded to prevent melting or electrical interference
  4. Aug 4, 2025 at 1:40 PM
    DKC
    DKC [OP] New Member
    Dillan
    I'm unsure why you would say you can't tell what is happening but I'll try to clear it up. This is what an '01 v8 tundra looks with the intake manifold off. With the area cleaned up you can see the starter and the knock sensors. Notice that bank 1 knock sensor is not wired, it was chewed by mice (a common issue on these models). I stripped back the insulation on the wiring that the knock sensors were connected to. The blue/yellow insulation contains a grey wire with shielding around it. the blue insulation contains a black wire with shielding around it. I purchased a knock sensor sub-harness from rockauto as well as knock sensors. I replaced the knock sensors and soldered in the knock sensor sub-harness to the wires that were going to the knock sensor's previously. Grey to grey, black to black. However, brown only exists on the sub-harness so I looked at the diagram and soldered it to the shielding around the other two wires. This did not clear the code. I suspect that the brown from the knock sensor sub-harness goes to ground point e4 but I have no clue what that looks like in real life. If there is a harness I have not seen any pictures of that and it's not easily accessibl e or visble, but I will continue to search.
  5. Aug 4, 2025 at 1:47 PM
    DKC
    DKC [OP] New Member
    Dillan
  6. Aug 4, 2025 at 2:16 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    The shield is only to protect the knock sensors from electrical interference/noise. Unless it’s touching bank 1 sensor signal wire, you should be fine with your solder job.
    The P0325 means you have an open or short in that sensor signal wire back to the ECM or that new sensor is not good.
    joseph_womack and DKC[OP] like this.
  7. Aug 4, 2025 at 2:29 PM
    bfunke
    bfunke Tundra Curmudgeon
    I think Toyota sells a complete knock sensor harness.
    DKC[OP] likes this.
  8. Aug 4, 2025 at 5:27 PM
    For the earlier years, I believe this is true.
    For VVTi trucks like mine, not so true. I wish it was a thing, I really want to replace my bank 1 sensor and harness. I may just end up being my plastic connector that's squirrely.
    joseph_womack likes this.
  9. Aug 4, 2025 at 5:42 PM
    DKC
    DKC [OP] New Member
    Dillan
    How could I test the sensor?
  10. Aug 4, 2025 at 6:37 PM
    joseph_womack
    Joe
    Louisiana
    give me year make and model and there should be an ohm value for the sensor that you can test
  11. Aug 4, 2025 at 6:51 PM
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    In the FSM for the sensor they show testing with an o’scope
  12. Aug 5, 2025 at 5:55 AM
    I've seen folks on the 'Tube test function by attaching to the leads and tapping the sensor with a hammer to see if the sensor outputs. Last time I saw someone do this was on the Project Farm channel, where he was resurrecting a Honda.
    DKC[OP] likes this.
  13. Aug 5, 2025 at 6:02 AM
    MEWaters
    MEWaters New Member
    Maine
    07 2UZFE; previous 02 AC 323k
    Eibach pro suspension Nitro 4.88 with Auburn Pro LSD and PTFE diff bushings Level 8 MK6 18x9 SAIS bypass JBA cat back Scangauge 2 Diode dynamic fogs. LED heads
    I think it’s like 120-280k ohms at 68 degrees
    DKC[OP] likes this.
  14. Aug 5, 2025 at 11:45 AM
    bmf4069 Captain wtf
    I think they're for the later years. It comes with a plug in on the end that I had to cut off and splice into mine. We don't have that plug on the earlier models. Still works good though 8 years later.
    DKC[OP] likes this.
  15. Aug 5, 2025 at 1:00 PM
    I've been full-on, inside and out of the EPC, and scoured Google. I can't find a complete sub-harness or individual end-to-end harness for the 2005-2006 Tundra V8 knock sensors.
    I've found a sub-harness for earlier years, but drawing a blank on which years. It has the plugs for both knock harnesses and the starter, and I think a ground tee that mounts to a bolt hole in the valley/top of the block, and I think it connects toward the back of the valley, near where the intake meets the block, possibly beneath the crossover housing.
    I'd need to go down a painful path to try and find that damn thing again, to figure out what year it's for.
    DKC[OP] likes this.
  16. Aug 5, 2025 at 1:25 PM
    DKC
    DKC [OP] New Member
    Dillan
    Yea I see a few spots where I can toss a bolt in and ground. I think I'll toss the other sensor in bank 1 and put it all back and see where it lands. Getting good at taking the manifold and evap hoses off. By the end of this I'll be able to do it with my eyes closed.
  17. Aug 5, 2025 at 1:28 PM
    That was going to be my next suggestion, if the part number is the same, swap banks. If it stays on one side, it's the wiring.
    I know both knock sensors use shielded wire, I'm quite certain what you're referring to as "ground" is actually shielding. Looks like you're treating it like coaxial/RG6 cable, I don't think it should be.
    DKC[QUOTED][OP] likes this.
  18. Aug 5, 2025 at 3:32 PM
    bmf4069 Captain wtf
    Students are starting to show up, but I have a pic on my very first thread of that connector. I'll dig it up later.
  19. Aug 5, 2025 at 4:17 PM
    bmf4069[QUOTED] likes this.
  20. Aug 5, 2025 at 4:18 PM
  21. Aug 5, 2025 at 8:41 PM
    bmf4069 Captain wtf
  22. Aug 6, 2025 at 7:23 AM
    DKC
    DKC [OP] New Member
    Dillan
  23. Aug 6, 2025 at 7:25 AM
    DKC
    DKC [OP] New Member
    Dillan
    AH nvm he does mention he had to splice into it
    bmf4069 likes this.
  24. Aug 6, 2025 at 8:09 AM
    bmf4069 Captain wtf
    You got it homie. There was nothing back there, in there, anywhere around there. Gotta do what you gotta do.
    FrenchToasty and DKC[QUOTED][OP] like this.
  25. Aug 10, 2025 at 12:48 PM
    DKC
    DKC [OP] New Member
    Dillan
    I sent it like this after swapping the bank 1 and 2 sensors, and moving the brown (knock sub-harness) to a bolt on the fuel rail. Still coding after clearing and driving around several times. My next plan is replacing w/ OEM sensor and remove the Sub harness and replace with simple connectors and that will remove the brown issue altogether. If that works I'll replace the other sensor and hopefully we will be set.
  26. Aug 10, 2025 at 3:07 PM
    Denso is the OEM manufacturer of those sensors. Go buy Denso brand sensors, without the Toyota box and 30-50% upcharge. Just don't be stupid by ordering them from scAmazon, fleaBay, WallyMart, Sears, Home Depot, Temu, or otherwise. You'll get authentic looking product, which will be anything but.
    Then use the money you saved to buy new OEM pigtails specifically for your VIN. It should make wiring easier, if the OEM pigtails are color-matched.
    bmf4069 likes this.
  27. Aug 11, 2025 at 4:41 AM
    bmf4069 Captain wtf
    Agreed. I ordered the harness straight from the stealership. Didn't think to get a part number back then but it was like $50 with no sales or deals.
  28. Aug 12, 2025 at 9:48 AM
    DKC
    DKC [OP] New Member
    Dillan
    I'm going to try a vulture shop, those OEM sensors are too high specially considering that I'm still unsure if that is the cause. I'm kicking myself for tossing the old ones, lesson learned there!
  29. Aug 12, 2025 at 10:18 AM
    I never toss old parts. I usually hold them for a year or two, esp. if they're questionable on being bad.
    Not saying to buy OEM. Buy Denso brand. They are the OEM manufacturer, but much cheaper than buying from a dealer. Just don't buy them from a sketchy place that's known for counterfeit parts (scAmazon, fleaBay, WallyMart, Temu, Sears, Home Depot, etc.)
    But seriously: Buy new pigtails from the dealer, so hopefully you get wire-color-matched harnesses and the method of wiring makes more sense. It's OK to get the part number from the dealer, just don't buy it directly from them. Instead order it thru https://autoparts.toyota.com so you can cash in on up to 50% discount, and if your local dealer supports pickup from that National Toyota Parts site, you still save the money, it's savings you don't get otherwise.
    This is one of those parts where, it's such a pain in the ass to get under the manifold - tedious, at best - just get it done right with the right parts the first time, and 'cry once', you know?
  30. Aug 12, 2025 at 10:43 AM
    DKC
    DKC [OP] New Member
    Dillan
    Can you find a link for the denso? I searched for a while and couldn't find anything.
