Is it possible to disable the key in ignition chime?
Discussion in '1st Gen Tundras (2000-2006)' started by Aerindel, Jun 19, 2019.
  1. Jun 22, 2019 at 1:22 PM
    Aerindel
    Aerindel [OP] New Member
    Montana
    Yep. Exactly like mine. The mystery remains.
    Luckily, unplugging the resistor is just as easy and works perfectly.
  2. Jun 24, 2019 at 6:10 AM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    Unplugging the resistor didn't work for me. After a day or two I will loose all headlights until I plugged it back in.
    Had to cut the yellow/black wire going to the drl module.
  3. Jun 24, 2019 at 11:34 AM
    Aerindel
    Montana
    I remember you saying that before. Which is bizarre and makes no sense if the wiring diagram I have is accurate as the resistor should have absolutely nothing to do with the normal function of the headlights and the only thing cutting to yellow and black wire should do is disable your highbeams. Perhaps there was more than one way these trucks where wired.
  4. Jun 24, 2019 at 2:02 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    Might be. Mine is a 2000 as well. I have read post from other people with the same issue
  5. Jun 24, 2019 at 2:10 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    I guess if my drl relay was bad, that will cause my headlights not to work if resistor is disconnected.
  6. Jun 24, 2019 at 7:35 PM
    Aerindel
    Montana
    That is true, but it would also mean your headlights are always running through the resistor and never at full brightness, do your headlights seem dim to you? May be worth testing that DRL relay.
    TX-TRD1stGEN likes this.
  7. Jun 25, 2019 at 12:36 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    They are dim without the fogs. I'll def check it out.
    Aerindel[OP] likes this.
  8. Jun 25, 2019 at 12:53 PM
    Professional Hand Model
    Hand Protectors
    Incandescents
    DRL are dim.
    Low beams brighter by twice DRL.
    High Beams are High Beams.
    LED (Katanas)
    DRL and Low Beam are same brightness (bright as sun)
    HIGH Beam is HIGH Beam (like a lighthouse).
  9. Jun 25, 2019 at 4:18 PM
    Aerindel
    Montana
    Indeed. When you turn on your low beams your headlights should be roughly twice as bright as they are when its just the DTRs. Should be really easy to test. If there is no change between your DTRs and your low beams then that would mean the DRL relay is failed, which would make the resistor as the only path to ground for your headlights and dim both your high beams and low beams (but not your fogs, they have a separate ground)
    I actually really like the stock headlights on the tundra. I think it has the best headlights of any vehicle I've owned in that regard. (I also have new headlight clusters so my plastic is nice and clear)
  10. Jun 29, 2019 at 12:10 PM
    TX-TRD1stGEN
    Seth
    South East Texas
    2000 Tundra 4x4
    So I found out today that my relay had an intermittent problem causing my headlights to be dim (low and high beams). Too care of that issue by installing a jumper where the relay was.
    Now trying to figure out the fog light anytime mod. Any chance anyone has a wiring diagram for the fogs??
  11. Jun 30, 2019 at 12:36 AM
    Aerindel
    Montana
  12. Jun 30, 2019 at 5:39 AM
    pop's
    pop's 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    THE TOYOTA DEALER IS YOUR ANSWER!!!!!! NAPERVILLE IL DEALER TURNED OFF THE SEATBELT DINGING - BUT NOT THE LIGHT FLASHING. WORKS FOR ME
    IM SURE THE DEALER IS YOUR ANSWER :facepalm:
  13. Jun 30, 2019 at 5:26 PM
    Aerindel
    Montana
  14. Sep 23, 2020 at 9:20 AM
    BigD56320
    BigD56320 New Member
    Behind the ignition switch is a 2 wire plug. All you need to do is unplug it. It takes out the headlight and door chimes.
  15. Sep 23, 2020 at 10:51 AM
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  16. Sep 23, 2020 at 11:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  17. Dec 13, 2021 at 6:17 PM
    Luckdragon2003
    Luckdragon2003 New Member
    2003 Tundra limited
    I found the 2 wire plug behind the ignition. disconnected it. All is quiet all is right. 2003 Tundra
    Gene_in_FL likes this.
  18. Dec 13, 2021 at 6:38 PM
  19. Dec 15, 2021 at 10:32 AM
    #49
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Bappa likes this.
  20. Sep 8, 2022 at 3:34 PM
    #50
    MNtundra
    MNtundra New Member
    Tony
    Minnesnowta
    01' Tundra AC 4x4, 04' CRV 4WD
    Bilstein 5100's, 4runner Wheels 31" BFG, Rear Seat Delete
    Added pics to accompany the write-up. Thanks to @Aerindel i just did this in my 01’ AC
    2D134618-9200-439C-A9DB-421644077701.jpg 60DEF6B6-FAE9-4D87-9BB1-F3A394854C81.jpg B0506B76-9B2F-4942-95BD-3ADFD1676BBF.jpg 3FD0DA96-8392-4292-BBB3-3F2628C15B8B.jpg FB462B3B-BED7-4691-9DC0-DB80F765CABF.jpg 9BD1CD97-56CA-4B41-931F-6995B496A996.jpg
    bmf4069, NickB_01TRD and shifty` like this.
  21. Sep 8, 2022 at 8:45 PM
    #51
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I figure the day I do this will be the day I forget my keys in the ignition and find a way to lock it. Good write up and pictures though.
    bmf4069 likes this.
  22. Sep 8, 2022 at 8:59 PM
    #52
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Since the thread has been revived and answers provided, I can comfortably make a smart ass answer.
    Take the key out of the ignition.....
    shifty`, bmf4069 and w666 like this.
  23. Sep 22, 2024 at 10:25 PM
    #53
    kulldox
    kulldox New Member
    Bellevue WA
    2001 Black Tundra AC Limited 4WD TRD
    OMG, thanks. This key buzzer was driving me crazy. Every time I want to work on something it keeps beeping. NOW IT IS QUIET!!!!!
