Installing transmission cooler for towing on 2015 4.6 L
Discussion in 'Towing & Hauling' started by FRTZ, Jul 7, 2020.
  1. Jul 7, 2020 at 5:36 PM
    FRTZ
    FRTZ [OP] New Member
    FRTZ
    2015 TUNDRA
    hello guys plannig on installing hitch on my 2015 4.6, has anyone installed transcooler as well
  2. Jul 7, 2020 at 5:48 PM
    Yours is not an SR5 with tow package I assume?
  3. Jul 7, 2020 at 5:51 PM
    FRTZ
    FRTZ
    2015 TUNDRA
    its an SR5 double cab no towing package with center seat, but thinkin of camping in some time with family
  4. Jul 7, 2020 at 7:12 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Actually, I believe the tow package ended on 4.6L in 2013, but I could be wrong. I know there are no transmission coolers (usually indication of tow packeage) on 4.6L after 2013.
    To add a transmission fluid cooler to the 4.6L is the same principle as adding a cooler to a 5.7L, but the part numbers are different, because the transmissions are different. Adding a transmission cooler was done early on the 4.6L but not documented with a photo illustrated "how-to". Start with thread linked below. Cooler information is toward the end of the thread. Additional information is available, search "4.6L transmission cooler".
    I contribute a parts list down further in the referenced thread. Some part numbers still need to be verified with @Roman. Right now, I'm on the fence, but have no immediate need. When the next Covid-19 relief deposit comes, maybe I'll pull the trigger.
    https://www.tundras.com/threads/4-6-towing-with-no-tow-package.34031/
    Hbjeff and Black Wolf like this.
  5. Jul 7, 2020 at 7:16 PM
    I know my 2013 4.6 came with a hitch from the factory so I would assume the tranny cooler is there...I never looked lol.
  6. Jul 7, 2020 at 7:17 PM
    FRTZ
    FRTZ
    2015 TUNDRA
    my doesnt have a tow package nor hitch
  7. Jul 7, 2020 at 7:23 PM
    JohnLakeman
    The presence of the hitch and towing receptacles does not mean the truck is equipped with the "tow package" option. Toyota is different from the pack in that they provide a hitch and towing receptacles even if the truck is not equipped with the tow package. :notsure:
    If your truck has the tow package the cooler should be there. My understanding is 2013 Tundra was the last year for the 4.6L transmission cooler.
    Black Wolf likes this.
  8. Jul 7, 2020 at 7:26 PM
    JohnLakeman
    No hitch receiver? :confused: What about the seven pin/four pin receptacles?
  9. Jul 7, 2020 at 7:28 PM
    I just went out and looked. It's in front of the radiator, and damn near the same size as the radiator.
  10. Jul 7, 2020 at 7:38 PM
    JohnLakeman
    LOL...Actually the cooler is built into the top of the AC condenser. The transmission cooler is only a small part of the condenser.
    Yeah, my early assumption was Toyota's coolers were about 10K BTU, but I later saw data from @Krohsis thread that under heavy tow conditions, you actually need closer to 30K BTU cooling capacity! :eek:
  11. Jul 7, 2020 at 7:42 PM
    Yeah I was just reading about it being integrated. I assumed the Tow/haul button probably confirms that it has one as well.
  12. Jul 7, 2020 at 7:45 PM
    JohnLakeman
    Without a doubt. :thumbsup:
  13. Jul 7, 2020 at 7:47 PM
    My 07's Trans cooler was mounted in front of the radiator too. Hard to miss. My 14 is somewhat different. No cooler mounted in front of the radiator. I was wondering what the difference was since my build sheet states that there is a trans cooler?
  14. Jul 7, 2020 at 7:49 PM
    Now I just need to look into the WDH for the new travel trailer. I'm having an enclosed cargo trailer custom built soon as well.....that should be a long 6 week wait.
  15. Jul 7, 2020 at 7:53 PM
    I'm not sure the way they integrate stuff these days. By the way Rough Country tried to tell me that the bumper wont fit even after I sent them the pic of one installed.
  16. Jul 7, 2020 at 7:54 PM
    FRTZ
    FRTZ
    2015 TUNDRA
    there is pre wiring, all i need is 7/4 socket, hitch, brake controller and harness and probably a transcooler
  17. Jul 7, 2020 at 7:56 PM
    JohnLakeman
    If your truck doesn't have an OEM receiver, then you can have an aftermarket receiver installed. A WDH (weight distributing hitch) is a separate item; it installs in the receiver mounted to the truck frame. The downside of having to add the receiver is the additional expense. There are several good receiver brands. Check here to start:
    https://www.draw-tite.com/products/trailer-hitches/AeUCnKDGi1PxWw|pmNRbMp45abhF|9in
  18. Jul 7, 2020 at 7:56 PM
    The trans cooler covered at least 1/4 of my 07 radiator on the passenger side. Nothing there on my 14 so yes I assume the trans cooler is integrated to the AC condenser on my 14.
  19. Jul 8, 2020 at 6:05 PM
    FRTZ
    FRTZ
    2015 TUNDRA
    Talked to the parts guy at toyota today and ask them if I have transcooler installed in my truck, I gave my VIN and he said there is
  20. Jul 8, 2020 at 6:07 PM
    FRTZ
    FRTZ
    2015 TUNDRA
    just weird coz i dont have the tow package nor tow haul mode inside on m board but got the transcooler
  21. Jul 8, 2020 at 6:10 PM
    The tranny cooler and ac condenser are integrated into one unit.
  22. Jul 8, 2020 at 8:27 PM
    JohnLakeman
    If your truck has the nest of snakes (circled in red) below, it has an OEM transmission fluid cooler. If your truck does not have that tubing configuration, then it does not have the OEM transmission cooler. Those circled lines are leading to and from the transmission cooler integrated into a top of the AC condenser.
  23. Jul 8, 2020 at 9:17 PM
    FRTZ
    FRTZ
    2015 TUNDRA
    is this5.7 or 4.6, i really dont know if its gonna be the same spot as the 4.6
  24. Jul 9, 2020 at 5:53 AM
    JohnLakeman
    The transmission cooler tubing configuration in the grille area will be the same for both engines equipped with a transmission cooler because both engines use the same AC condenser (88350-0C010) with the transmission cooler.
    If you still need convincing that you really don't have a transmission cooler, here's a plan: Crawl under your truck on the passenger side and find the transmission. (Or, if you're not sure you can identify the transmission, have a technician do this for you.)
    There will be a hockey puck cylindrical thing near the bell housing (Item 1 below, all have this warmer). If you have an OEM transmission fluid cooler, there will be a thermostat (Item 2) sandwiched between the fluid warmer and the transmission. If there is no thermostat, there will be an adapter that looks similar to the thermostat, but without the bottom outlet/inlet tubes. If there is a thermostat, there will be rubber hoses (Items 3, 4) connecting the thermostat to steel tubes (Item 5) leading toward the front grill area. If you don't have the thermostat and those steel tubes, then you don't have an OEM transmission cooler.
    Rocko9999 likes this.
  25. Jul 9, 2020 at 9:48 PM
    FRTZ
    FRTZ
    2015 TUNDRA
    thanks for the info
