Installing puddle lights on factory SR5 mirrors
Discussion in 'Lighting' started by panicman, Apr 21, 2019.
  1. Apr 25, 2023 at 7:18 PM
    #151
    icodeintx
    icodeintx New Member
    Scott
    Palacios, Texas
    2021 Cement Gray Tundra SR5 CrewMax
    LED Headlights, LED Fog Lights, LED Interior lights
    I'm doing mine from scratch. What power source do I tap into?
    Update: I should have stated that I have a 2021 SR5 without fancy mirrors.
  2. Apr 26, 2023 at 2:37 PM
    #152
    Pot Hole
    Pot Hole Where dem Mallards at?
    Mount Ulla, NC
    2020 White Limited TRD
    TRD skid plate, Stainless Running Boards, JDA Astar turn signal bulbs, VLEDs footwell lighting, Wet Okole seat covers, Weathertech Window Deflectors, more to come!
    Mine are tied into VLED interior lights, but I think you can scroll back through some of the earlier posts in this thread and find the specific wire you will need to splice into.
    Taco-Spike likes this.
  3. Apr 26, 2023 at 4:20 PM
    #153
    Taco-Spike
    Two Trucks
    You have a few options. The 2 most people do are the cargo light wiring or the footwell light.
    Both have a pro and con
    I did cargo light. I like having it on a switch and off during day use and on, on demand
    TreeCat and icodeintx[QUOTED] like this.
  4. Apr 26, 2023 at 7:24 PM
    #154
    Tundra-XP
    Tundra-XP New Member
    Will
    2020 Toyota Tundra XP MGM CM TRD Off Road
    Ok. I just did mine today. I installed the VLEDS and it plugged it into my VLEDS footwell lights. The package came with a 3 way splitter that plugs into the plug that plugs into that little driver side footwell light socket. Took like 3.5-4 hrs. It wasn’t easy either. I know some say it is but it was a PITA to get that large end through the rubber grommets. Not to mention I broke my passenger side mirror glass trying to pop it off. Now I need a new one. But it’s all done and love the outcome. Wished I had a switch also but I like when they automatically turn on when I approach. I’ll look into getting rock lights with a switch another time. Here are some pics.
    bulldog93 and TreeCat like this.
  5. Apr 27, 2023 at 4:50 AM
    #155
    Pot Hole
    Mount Ulla, NC
    Looks good. Connecting them to the VLED footwell lights IMO is the way to go even if it is a PITA to get the connector through the rubber grommet. I love mine.
    bulldog93 and Tundra-XP[QUOTED] like this.
  6. Dec 13, 2023 at 9:55 AM
    #156
    Rakso
    Rakso Tundra + Tacoma=Winner
    Oskar
    18 CM Super White 4X4
    TRD sway bar, TRD filter
  7. Feb 28, 2024 at 2:51 PM
    #157
    chance03
    chance03 New Member
    has anyone tried putting a puddle light on the bottom of the door like a lot of the german cars have?
  8. Feb 28, 2024 at 4:26 PM
    #158
    Pot Hole
    Mount Ulla, NC
    Not sure you would get nearly as extensive illumination coverage outside the vehicle as you do with them mounted much higher up in the mirror housing.
  9. May 21, 2024 at 9:26 AM
    #159
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    I did this modification about a year ago, and since day 1, I've been having issues with my door locks using the key fob when the LEDs are on. I'm 100% sure it's related to the LED's because I've wired them into the bed cargo light and when I turn the switch position to "off", I no longer have the issue. When the switch is in the "on" position, if the LEDs are on when attempting to use the key fob, my door locks are very finicky. I have to be super close to the truck to lock the doors using the key fob, and I have to press it multiple times to get it to respond. The locks work perfectly as soon as the LEDs turn off. It's very similar to the known RF interference issue with LED's in the bed cargo light. I know it's not the bed cargo light that's causing the issue because I'm using the VLED 921 "no interference" LED's that are made to solve this exact issue, plus I had those installed long before doing the puddle light install and never had an issue.
    Is anyone else experiencing this issue? It's very annoying! I wish VLED made puddle lights that were "no interference" like the 921 bed cargo LEDs I'm using! https://www.vleds.com/shop-bulb-numbers/921-led/921-36-w-5500k-t.html
  10. May 21, 2024 at 9:58 AM
    #160
    1lowlife
    1lowlife Toxic prick and pavement princess
    DADA
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
    What lights are you using for the puddle lights?
  11. May 21, 2024 at 10:02 AM
    #161
    Redline870
    Ian
    Central NY
  12. May 21, 2024 at 10:20 AM
    #162
    1lowlife
    DADA
    That's odd.
    I used these and tapped into the little floorboard light.
    They look a lot like what you have but cost $50 more.
    Never had an issue on my 2014, but there are lots of differences between 2014 and 2021 wiring and accessories..
    UNIVERSAL LED PUDDLE LIGHT (vleds.com)
    The thing about using the floorboard light is they dim on and off.
    At least on my 2014 they do.
    Sorry about the wind noise.
    https://youtu.be/k0hMlh9S_6o?si=SjiRD98uFGoFUwAy
    bulldog93 likes this.
  13. May 21, 2024 at 11:20 AM
    #163
    Redline870
    Ian
    Central NY
    Those are the same lights, they're two of them in kit form with a bunch of extra wiring/connectors. I didn't buy that kit because I don't like the VLED connectors, so I bought the two $30 lights by themselves for a total of $60. I made my own wiring harnesses with wire loom installed over the outside of the wires and mini deutch connectors at the mirror and door, in case I need to remove the mirrors or doors.
    1lowlife[QUOTED] likes this.
  14. May 21, 2024 at 11:22 AM
    #164
    Redline870
    Ian
    Central NY
    I wonder if it's because I tapped the bed cargo light instead of the floorboard light. I wonder if just having them on the same circuit will induce rf interference that interferes with the key fob.
  15. May 21, 2024 at 11:26 AM
    #165
    1lowlife
    DADA
    I wish I'd of seen that, I didn't use their connectors either..:eek2:
    I also used a connector in case I need to remove the mirror.
    There are 2, one for the puddle lights, one for the signal mirrors.
    0205FD35-0BA7-4525-ACFA-EFEDDAC5C371_zps_b9b4e32777485e3f1efbb85ba21727ec29b72ba2.jpg
  16. May 21, 2024 at 6:12 PM
    #166
    Pot Hole
    Mount Ulla, NC
    I would be willing to bet that is the source of your problem.
    I've had VLED puddle lights for roughly a year now with no issues, however, I did plug them into my VLED floorboard interior lights so they come on and go off with that circuit. Really liked the plug-n-play of the VLED wiring and (if need be) I can replace a puddle light just by removing a mirror.
  17. May 21, 2024 at 6:42 PM
    #167
    Tundra234 Mods, mods, and more mods
    That's how mine are on my 2020.
  18. May 21, 2024 at 9:45 PM
    #168
    Tundra-XP
    Will
    I did this MOD a while back, followed the instructions and have had zero issues. Great MOD. I also tapped into the small floor board light like it recommended and mine dims as well. I also liked the their connections, all plug and play and no splicing or anything. I did add extra small connections in the mirror/door incase I had to change them and didn't want to take the entire system out to replace the lights if one went bad.
  19. Apr 15, 2025 at 9:48 AM
    #169
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Sorry, resurrecting from the dead. Looking to do this as well, but will the puddle lights be on low output like the footwell lights when driving?
  20. Apr 15, 2025 at 9:53 AM
    #170
    No.
  21. Apr 15, 2025 at 4:58 PM
    #171
    Redline870
    Ian
    Central NY
    As Tundra 234 said, no. The light on the floor is only dim because it’s tiny. It’s still getting 12V like every other bulb in the truck which is all that’s needed to run at full brightness.
    Pot Hole and Dr3wski[QUOTED] like this.
  22. Apr 15, 2025 at 5:44 PM
    #172
    Dr3wski
    Dr3wski New Member
    2018 SR5 4x4
    Appreciate the response!
  23. May 3, 2025 at 10:15 AM
    #173
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    I installed the VLED universal puddle lights and have a pro tip for guys. Remove the speakers (just 4 screws) and you have a big cavity to clean up the wire and it’s one less place you have to fish wires. Fishing wires is the worse part of this project. The yellow circles are where I zipped tied.
    panicman[OP], Pot Hole and bulldog93 like this.
  24. May 3, 2025 at 12:35 PM
    #174
    greg8765
    greg8765 New Member
    Grant
    Utah
    2021 Cement Tundra
    Thanks for sharing. Just ordered what I needed. How long did it take you to install, start to finish?
  25. May 3, 2025 at 5:23 PM
    #175
    panicman
    panicman [OP] Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Geez... that was over 6 years and many projects ago.
    I think the hardware installation for both mirrors was a couple hours, and running wires and finding the right circuit was another couple hours.
  26. May 4, 2025 at 5:51 AM
    #176
    Pot Hole
    Mount Ulla, NC
    When I did mine, it took about 5 hours to do both mirrors. Obviously, running the wiring took the most time, but after you do one side the other side isn't quite as bad. Having the VLED interior light wiring to plug directly into my existing footwell light made a huge difference and saved some time as well.
    Definitely one of the best mods I have done on my truck.
  27. Jan 11, 2026 at 10:13 AM
    #177
    Redline870
    Ian
    Central NY
    For anyone who cares, I’ve verified that tying into the cargo light wires was the source of my key fob problem. The cargo light wiring was acting like an antenna and causing interference, it’s the whole reason VLED makes the low RF noise LEDs for the cargo light. On the newer Tundras, you need to tie into the footwell light. If you want to retain the footwell light and not cut any factoring wires, buy a VLED #74 bulb adapter for $2 that plugs into the bulb socket, buy a #74 bulb socket on Amazon, combine the two and bring off a secondary for mirror power. I stole the idea from @RainMan_PNW.
    1lowlife and bulldog93 like this.
