Installing bed lights
Discussion in 'Lighting' started by bsktball55, Oct 22, 2017.
  1. Jan 2, 2018 at 8:30 AM
    Woodguy65
    Woodguy65 New Member
    The reviews on the battery/remote light from Walmart - say it "eats" batteries due to the fact the remote has to be "always on" in order to communicate/work with light and uses batts quickly. If that's true that would be only down side, has anyone experienced dim light or dead battery after couple months useage?
    ccdawnpatrol likes this.
  2. Jan 2, 2018 at 4:33 PM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Had mine in for three months. Still original batteries. The light may eat batteries when it's on, but it's not on for long in my using it.
  3. May 17, 2018 at 5:46 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    what is the range, could you like have the remote in the cab, like in the center console or laying around the shifter somewhere and it come on ?
  4. May 19, 2018 at 7:14 PM
    Masshole
    New England
    Yep.
  5. May 19, 2018 at 7:40 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Wish I would've known this prior to me installing the Matt Gecko bed light kit. Woulda saved me time on wiring the thing up. Oh well.. mines done and it works awesomely!
  6. Jun 28, 2018 at 3:47 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    Update: The lights are great but the batteries finally wore out. I may just reduce it to one since they are fairly powerful. Side note, my son may or may not have left them on(he's 2.5) when we were getting stuff out of the bed the other day. I did just happen to order some LED lights I am hoping to set them up soon. Cost $20 with a remote and sticky adhesive on the bottom.
  7. Jun 28, 2018 at 10:05 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    3 pack.....
    NewImprovedRon likes this.
  8. Aug 16, 2018 at 8:00 AM
    multirc
    multirc New Member
    Ron
    2018 Tundra 1794 Edition
  9. Aug 16, 2018 at 8:03 AM
    multirc
    multirc New Member
    Ron
    I was thinking of getting something like that from Walmart as well but the only thing im hesitant about is the batteries themselves with the summer heat. Like 100 degree weather and with no ventilation in the bed with the cover on, could probably get up to 120 and afraid the batteries would explode from the heat.
  10. Aug 16, 2018 at 8:14 AM
    Pudge
    CT
    No issues so far with mine. It's been high 90s and humid here.
  11. Aug 16, 2018 at 11:27 AM
    Masshole
    New England
    No issues here either. Although the crazy heat did end up melting the adhesive tape and the light bar ended up in the bed of my truck. No matter. I'll just stick it back on when the temps cool down. Not much call for it during the long days of summer.
    Pudge[QUOTED] likes this.
  12. Aug 16, 2018 at 12:07 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Ha, same with mine, found it on the bed one day, used automotive trim tape and all good. We’ve had a continuous heat wave, no mini explosions. Motion activated so it only be ideal if you had a cover. I pull it off (only the magnetic strip is taped) and recharge it about once a month or two, $20 Amazon. They come in pairs and triples too for smaller versions.
    I have this one:
    Pudge likes this.
  13. Aug 16, 2018 at 12:17 PM
    multirc
    multirc New Member
    Ron
    Oh OK, well as long as the batteries are OK. I think i'm going to go with Matt Geckos's lighting. I like everything hard wired. I had solar lights with batteries on my balcony and got tired of swapping the batteries out every week so I bought hard wired (driveway) lights and problem solved...LOL!!!! Thanks for your input guys!!
    Pudge likes this.
  14. Aug 21, 2018 at 4:55 PM
    ccdawnpatrol
    Salt Lake City, UT
    I just started installing his set up. I realized that it was my fault with the batteries, I left the light on, better yet, my 3 yr old son did when we were cleaning out the truck. But this way the lighting system will stay hard wired for years to come. No more batteries and what not.
  15. Aug 22, 2018 at 7:22 AM
    multirc
    multirc New Member
    Ron
    How did you make out with the set-up? Did you run directly to the battery? This is what I want to do but before I order from Matt. I want to make sure I know what i'm doing since I never wired anything up on a vehicle before. I also want to use a different switch other than the one that comes in the kit. I want to use a 3 prong lighted switch and currently learning how the wiring goes with that. 2 reasons why I want to run direct to the battery is 1: I want to be able to switch the lights on anytime without having to turn the ignition or have parking lights on. 2: I figured if I run directly to the battery with a fuse right by the battery, I cant screw anything up with the electrical system since its a brand new truck (2018). If I can accomplish this and all is well, then my next mod will be to install a light bar or pod lights on my bull bar.
  16. Aug 26, 2018 at 2:34 PM
    ccdawnpatrol
    Salt Lake City, UT
    I actually have not finished it yet. You can actually message him and he will send you the list of instructions. But to answer your question, yes, you hook up to the battery directly.
  17. Aug 26, 2018 at 2:41 PM
    mohd.darmaki
    mohd.darmaki New Member
    Mohammed
    1794 platinum Black model 2017
    Honey-D kit , sos performance lowering kit , TRD daul exhaust , front & rear sway bars ,TRD Air Intake , TRD Pro Grill/Hood Bulge , 2018 Front lights/ Fog lights , Fuel marveick wheels 20x12 negattive44 with grapper 305 tires , Glossy Black Door Handles Cover Half mirrors tailgate w cam, Tundra Steep foot; Fridge center console ,Tundra black Tailgate Trim Bezel , 4x4 Tundra tail , cup olders , Disk Brake Calipers Cover , TRD Liscense Plate , kuda mount black, Super Charger
    Good idea i think i will do same is that water resistant
  18. Nov 28, 2018 at 11:48 PM
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    Anyone try to put in a wired LED light in the rear sides of the bed, but tapped into the trailer harness in some way and switchable at the tailgate? I like the stick - on types but would want to one-up that with a wired power source near the rear.
  19. Nov 29, 2018 at 5:19 PM
    #49
    doggiecareman
    doggiecareman YOLO / Best to do it with a Toyota
    Eric
    North Central CT
    Tundra Army Green Limited Double Cab TRD Off Road 2021
    TRD dual exhaust/Factory running boards/center console safe/Truxedo X15 Tonneau/ceramic coated/ceramic window tint/BFG KO2's/swing cases/debadged
    I just had under the rail lights, 4 on each side installed with them being controlled by the cargo light switch on the dash earlier today. Was considering going with a setup similar to what is posted here as it is definitely much less expensive but am happy with the outcome for the 200.00 I paid. It took them about an hour and a half to install.
    Shukidevdas, Randy Morton and hi_rawb like this.
  20. Mar 9, 2019 at 1:13 PM
    #50
    hi_rawb
    hi_rawb New Member
    rob
    Bay Area
    2018 CM TRD SPORT 4x4
    2018 Trd Sport
    Where did you get the rail lights? I want to do the exact set-up..
    doggiecareman[QUOTED] likes this.
  21. Mar 15, 2019 at 10:40 AM
    #51
    doggiecareman
    Eric
    North Central CT
    At a local custom shop in Enfield CT.
    http://onpointconnections.net
  22. Mar 16, 2019 at 7:12 PM
    #52
    Chi2Az2014
    Chi2Az2014 New Member
    2014 Tundra
    Nice lighting idea! How do you batteries handle the heat of the Summer? I wonder how they would handle the 120 degree weather of AZ?
  23. May 27, 2020 at 1:45 PM
    #53
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    I must be missing something here. Does anyone have a picture showing which holes in the scuff area and lower portion of the cab where the wires run through?
  24. Jun 12, 2020 at 9:43 AM
    #54
    SoCalTecHead
    SoCalTecHead New Member
    Tony
    Orange County California
    2020 Cement CM Limited
    Good idea and for $20 bucks its hard to go wrong.
    HulkSmurf14 likes this.
  25. Feb 7, 2021 at 4:11 PM
    #55
    avt007
    avt007 New Member
    Rob
    2010 Silver Tundra Double Cab
    I'm working on this today. To make your life easier, remove the left rear tail light. It's only those two screws (T30) and it comes right out and you can feed the wires up into the box easily.
