Installing bed lights
Discussion in 'Lighting' started by bsktball55, Oct 22, 2017.
  1. Oct 22, 2017 at 10:37 AM
    bsktball55
    bsktball55 [OP] New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I tried searching, but couldn't find what I'm looking for so if someone knows where I can find a similar thread let me know.
    I bought some LED strip lights to install in my bed. The directions they give show taking it up to the battery to install. I thought I saw on here or another site that someone just hooked them up to the cargo light circuit so they came on anytime the cargo light was on. Can someone help me with how to wire them into the cargo light circuit.
  2. Oct 22, 2017 at 1:26 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    @RowdyRon has the knowledge.
    rons23, 040Tundra and NewImprovedRon like this.
  3. Oct 22, 2017 at 6:54 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Thanks Ron! I've been waiting to install some puddle lights and I'm gonna use your advice to wire 'em. I installed sliders today so it's now time for the lights.
    NewImprovedRon and BlueBottle like this.
  4. Oct 23, 2017 at 4:55 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Thanks for your help. I'm going to try and install them this week. Hunting season is coming up and it's always a pain in the ass trying to find stuff in the bed since I have the cover on it. Hopefully this will brighten it up a little.
    NewImprovedRon likes this.
  5. Oct 23, 2017 at 5:06 AM
    Cfincke
    San Antonio
  6. Oct 23, 2017 at 7:52 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Where did you ground it to the frame at? Is there a screw somewhere that you attached it to? Or did you add a screw somewhere? Can I just hook it into the ground wire that is in that same wire loom?
  7. Oct 23, 2017 at 5:05 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Last questions for you. Did you add a fuse when you hooked into the wire? I fished the wire up into the door scuff plate area and into the bed so now I just need to get the tester to determine exactly which wire it is. It looks like there are two wires that are very similar in color. Also did you do anything to protect your wire where you ran it up through that drip hole? I had to cut the outside insulation off of the wire they supplied in order to get the wire up through there so it's just the small wires and I'm afraid they may rub there a little and eventually short out.
  8. Oct 23, 2017 at 5:25 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Thanks for all of you help. I appreciated it. That wire and the wire that is the 4th from the right I think are the two I am having telling them apart. My lights say to use a 3 amp fuse so I may pick one up.
  9. Oct 23, 2017 at 5:52 PM
    SuperSilverTundra
    SuperSilverTundra i didnt pull up i Landed
    Nick
    Los Angeles California
    16 TUNDRA 5.7 PLATINUM-PRO
    3"/1" TOYTEC 18x9 XD818 Heist 295/70r18 COOPER XLT DirtyDeeds BAMuffler 2018 LEDs KatzKin Leather S&B CAI
    This is what i did cost $14 and took 5 mins to install no complaints and wiring i hate wiring
  10. Oct 23, 2017 at 9:12 PM
    yoshi82
    yoshi82 New Member
    DAVID
    HOUSTON
    2014 Silver Tundra SR5
    3in ToYtech lift on Tundra and 2.5in in the rear. Tow Mirrors. Toyota grill, and Front bumber. New 6in antenna. Repainted the stepping boards
    Where u got them from?
  11. Oct 24, 2017 at 7:59 AM
    SuperSilverTundra
    Nick
    i was at walmart buying some lights for my house and came across this and for $14 decided to give it a try i just applied double sided tape and it hasn't moved even after i went on a few trails this weekend not bad for the price i plan to hit it with some silver paint later cool thing is it has a remote so you can pretty much install anywhere bedlite.jpg @yoshi82
  12. Oct 24, 2017 at 8:10 AM
    SuperSilverTundra
    Nick
    @RowdyRon that's a good point i might buy another just to see i will let you know
    ccdawnpatrol and NewImprovedRon like this.
  13. Oct 25, 2017 at 3:24 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    How bright is the Toyota kit?
  14. Oct 25, 2017 at 5:01 AM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    This is going to be my mod. No muss. No fuss. Nothing for me to break. :homer::D
  15. Oct 25, 2017 at 5:05 AM
    RaginCajuns
    RaginCajuns New Member
    Prairieville, LA
    2017 Super White Tundra Platinum 4X4
    My Tundra came with this feature (LED bed lights) when I bought it. Looking on the Toyota web site it was like a 200-250 dollar adder. Well worth it since I duck hunt a lot.
    I also changed by top back cab lights to LED and they are a lot brighter than the crappy stock bulbs.
  16. Oct 28, 2017 at 5:28 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    Got it all wired up and it is working great right now. When I was hooking it up, I must have shorted it out because I blew a fuse, now that it's all hooked up it's good to go. Now I just have to wait till it warms up later this week to actually stick them on and finalize the wiring.
  17. Oct 28, 2017 at 7:57 AM
    Masshole
    New England
    Bought same thing on Amazon this week and just installed. No wiring. Works great! Installed light at cab end and switch switch within easy reach of the tailgate under tonneau. No wires. No fuses. Perfect for me. Thanks for the idea. @SuperSilverTundra
    Bassmonkey67 likes this.
  18. Nov 30, 2017 at 4:35 PM
    ccdawnpatrol
    ccdawnpatrol New Member
    Salt Lake City, UT
    2017 SR5 MGM CM 4x4 5.7L
    Do you have a picture of the lights being installed and in a dark setting?
  19. Nov 30, 2017 at 4:35 PM
    ccdawnpatrol
    Salt Lake City, UT
  20. Nov 30, 2017 at 4:48 PM
    ccdawnpatrol
    Salt Lake City, UT
    Here's a link to the GE LED light strip from Walmart.
  21. Nov 30, 2017 at 4:52 PM
    Masshole
    New England
    Comes with two 3M sticky squares on the back of the light. Mounted light center cab-side bed.
    Controller mounted just inside right side of tailgate using the provided velcro.
    Nothing fancy, but works for me.
  22. Nov 30, 2017 at 4:53 PM
    ccdawnpatrol
    Salt Lake City, UT
    Boom, there you go. Ran out of batteries yet? I would assume they last a long time being LED's. Might get a 4 pack of these and really light up the bed, or start with two. Thanks!
  23. Nov 30, 2017 at 4:56 PM
    Masshole
    New England
    Haven't needed to change batteries. Great thing about this light is one control button turns on all of the led light bars within range.
  24. Dec 9, 2017 at 10:40 AM
    Tundraplatinum
    2016 Platinum CM
    just finished installing the Toyota bed light kit in my 2016 very nice kit but definitely don't follow the instructions from Toyota, do what ron said wires right under drivers rear step pad you can fish them right in tru existing holes in body and there is a threaded 6mm hole right under there too for the ground connection. my 2016 the cargo light is a brown wire.
  25. Dec 11, 2017 at 10:02 AM
    cfred70
    cfred70 New Member
    Craig
    Ohio
    2018 Tundra SR5 Crewmax
    Extang Solid Fold 2.0, 20% Tint, Black Emblem Overlays
    This may be the cheapest, best mod on this entire site....
  26. Dec 30, 2017 at 9:41 PM
    ccdawnpatrol
    Salt Lake City, UT
    I went with two just to get a little more coverage. Not completely necessary but it covers almost the entire bed except for the front portion right under where it is mounted. IMG_2607.jpg IMG_2606.jpg
    Matty4wd, aperezsh and NewImprovedRon like this.
  27. Dec 31, 2017 at 6:13 AM
    TUNDRA375
    TUNDRA375 New Member
    GA
    2021 TRD PRO LUNAR ROCK
    I decided to invest in that...smart and cheap. Great photos..
    ccdawnpatrol likes this.
  28. Dec 31, 2017 at 7:18 AM
    V-TRAIN
    V-TRAIN New Member
    2015 TUNDRA LIMITED
    does one remote work for both lights ?
    ccdawnpatrol[QUOTED] likes this.
  29. Dec 31, 2017 at 8:15 AM
    ccdawnpatrol
    Salt Lake City, UT
    Yup! I just realized that my remote is different from the original poster. Mine has an on and off button. A smidge annoying instead of just hitting one button to turn them off and on. So make sure to get the listed in the bottom of the thread.Go me, ha.
  30. Jan 2, 2018 at 8:04 AM
    War Machine
    War Machine SSEM # 5 3MW
