install pre-planning
Discussion in 'Audio & Video' started by smslavin, Apr 10, 2018.
  1. Apr 13, 2018 at 2:25 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  2. Apr 13, 2018 at 2:40 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    ok, I'm running an audition bit one. my last truck was my first time having a true processor and it is amazing the difference it makes. I say GET ONE!!!!!!!!
  3. Apr 16, 2018 at 7:03 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    as i was putting in soundskins yesterday, i started wondering about where to mount the crossovers. i'll have one for each door. is there room to mount them to the door? if so, where's the best spot? the inside of the door panel had a bunch of white batting material. should i yank that off?
  4. Apr 16, 2018 at 7:08 AM
    Danimal86
    Daniel
    Sacramento, CA
    Look at the back of the plastic door panel and you'll see where you have room, since the inside of the door is decently flat.
    Its a bit of a pain to find the right spot. Grab some double sided tape, and put the crossover where you think it will work. try to put the door back on, probably wont work the first time, door back off, move it again..........do over.....
    I went towards the front of that giant foam block. I think there's a pic in my audio build thread.
    smslavin[OP] likes this.
  5. Apr 16, 2018 at 7:09 AM
    smslavin
    Hudson Valley
    Some stuff
    :thumbsup:
  6. May 2, 2018 at 6:06 AM
    smslavin
    Hudson Valley
    Some stuff
    I think I now have everything lined up to tackle the install. I do have one question regarding the entune harness I got from tech12volts and was hoping one of you had the answer. Here's what I have...
    @MTwiford was kind enough to post up which wires went where but his harness is a little different. On the large plug (the top one in the photo), I've made the assumption that the twisted green pair would be for the factory sub if I had one and that the purple is the center channel. Am I correct? On the smaller plug (the bottom one), yellow is the constant 12v to power the FiX but, where does the red one go?
    There is a small box under my passenger seat but I haven't gotten a close look at it yet. I was going to do that today but, it's raining.
    Black Wolf likes this.
  7. May 2, 2018 at 7:15 AM
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    Is that not the remote power wire for the amp? I know mine is red from him
    smslavin[QUOTED][OP] likes this.
  8. May 2, 2018 at 8:14 AM
    smslavin
    Hudson Valley
    Some stuff
    not sure but if it is, that's perfect as it'll save me from running yet another wire.
  9. May 2, 2018 at 8:17 AM
    Danimal86
    Daniel
    Sacramento, CA
    Red is 12v switch
    yellow is 12v constant
