install pre-planning
Discussion in 'Audio & Video' started by smslavin, Apr 10, 2018.
  1. Apr 10, 2018 at 8:56 AM
    smslavin
    smslavin [OP] New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Getting ready to finally do this. I think I have everything but RCA cables and speaker wire but I'd like a little feedback first.
    I was thinking of mounting amp, FiX and TwK like this.
    I realize that I'll have to extend the wiring from the factory harness to the FiX. I have the Entune harness from tech12volts. Is that reasonable or should I put the FiX under the passenger seat next to the factory harness and just run RCAs to the TwK? If I put it under the seat, is the best option to epoxy a piece of plywood to the floor?
    Next question. Speaker wiring. Planning on running 12g to the sub and 16g to the door components. Yay or nay?
    Anything else I should be considering?
    I've got 8 rolls of Soundskins to get through as well. This is going to take awhile.
    Black Wolf likes this.
  2. Apr 10, 2018 at 2:26 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    Hello!
    The wire huge is plenty and will work well for you. I’m running 16g. Wire with 200wrms through it :)
    Where are you planning on puttin the amp and twk/fix? I put my amps under the rear seat (crewmax) and my Audison Bit One next to the jbl amp.
    smslavin[OP] likes this.
  3. Apr 10, 2018 at 4:57 PM
    smslavin
    Hudson Valley
    Some stuff
    The sub box I had made has a spot to mount the amp. There’s actually enough room to add the FiX and TwK to it. That’s the picture I posted above. Box will go behind the rear seats.
  4. Apr 10, 2018 at 5:06 PM
    Shelbie67
    Blake
    NorCal
    Ok, you could buy speedwire to extend the jbl harness to the amps and have it all out of site (probably what I would do), which would be nice. It mainly comes down to what you want the install to be.
    I like to be as clean as possible. All my wires are hidden, everything is symmetrical and not even noticed it is there.
    Do you have more amps for the components or is that Rockford going to power it?
  5. Apr 11, 2018 at 6:21 AM
    smslavin
    Hudson Valley
    Some stuff
    whoa. that stuff is perfect. i had no idea. thanks for the pointer.
    no, just the one amp. it's 75w x 4 and 500w x 1. plenty of power for what i need and i just wanted to keep things simple.
  6. Apr 11, 2018 at 7:13 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Either way your going to have to run wires back and forth from under the passenger seat to the sub box. I would put the fix and twk under the seat and the amp on the sub box.
    I'll see if i have a picture of the amp rack James made for me. It was a piece of mdf with a couple little feet.
  7. Apr 11, 2018 at 7:52 AM
    Shelbie67
    Blake
    NorCal
    Yea, I have used it a few times and it works pretty well. And a 5-channel will work just fine.
    Honestly, just put it where you want! Be creative and have fun :)
    The pic is where my amps are but I went overkill so I ran out of space.
  8. Apr 11, 2018 at 8:01 AM
    Danimal86
    Daniel
    Sacramento, CA
    Here's the amp rack for under the front passenger seat.
    Here you can see the little feet. Not much too it. I used velcro to hold it down
  9. Apr 11, 2018 at 8:05 AM
    Shelbie67
    Blake
    NorCal
    Did you have the stock jbl amp? Or is that under the driver seat?
  10. Apr 11, 2018 at 8:12 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    :popcorn::popcorn::popcorn: One of these days I'm gonna fix the sound in this truck.
    Shelbie67 likes this.
  11. Apr 11, 2018 at 8:16 AM
    Danimal86
    Daniel
    Sacramento, CA
    Thankfully i dont have the jbl system.
  12. Apr 11, 2018 at 8:27 AM
    smslavin
    Hudson Valley
    Some stuff
    really? my understanding is factory harness > FiX > TwK > amp > speakers. if i mount everything to the sub box, what else is under the seat besides the factory harness? if i put everything under the seat, then it's just RCAs out to the amp. my knowledge is a little limited on this aspect of the truck right now.
    thanks for the pics on your amp rack. so, you just velcro'd it to the carpet?
  13. Apr 11, 2018 at 8:27 AM
    Shelbie67
    Blake
    NorCal
    Let me know! That’s my expertise :)
    831Tun[QUOTED] likes this.
  14. Apr 11, 2018 at 8:33 AM
    Shelbie67
    Blake
    NorCal
    If you are running new speaker wires, then you only need to go from the jbl amp to your Fix, stock wires you would have to go back to the amp.
    If you put the fix/twk under the seat then only rca and remote wire to amp is correct.
    Any other questions :)
  15. Apr 11, 2018 at 8:34 AM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Good to know, thanks!
  16. Apr 11, 2018 at 8:38 AM
    Shelbie67
    Blake
    NorCal
    Absolutely! I work in San Jose so I’m also closish to you
  17. Apr 11, 2018 at 8:39 AM
    Shelbie67
    Blake
    NorCal
    Welcome and you can just screw into the foam, it’s dense enough....I haven’t hade time to make a board. I also thought about sinking the amps down into the foam for looks....idk yet
  18. Apr 11, 2018 at 8:42 AM
    Danimal86
    Daniel
    Sacramento, CA
    Do you have the jbl system?
    You need to make the speaker wire connections under the seat for both input and output. It would probably be easier to just have the fix and twk under the seat and run rca's to the amp in the back and speedwire back to under the front seat for the output from the amp.
    If you put the fix and twk on the box, make sure to get a long usb cable and leave it plugged in so you dont have to pull the back seats out if you need to change a setting.
    Yeah i just used the hook side of some Velcro to hold the rack down to the carpet
  19. Apr 11, 2018 at 8:45 AM
    smslavin
    Hudson Valley
    Some stuff
    truck does not have a jbl sub but there is a little box under the passenger seat. i haven't really gotten in there yet but would that be the jbl amp? yes, i'm going to run new speaker wire.
    i'm sure i'll have more questions. thanks for the input.
    with all you guys in the bay area, if the day job ever sends me back to san jose, we could try for a little meetup.
  20. Apr 11, 2018 at 8:47 AM
    smslavin
    Hudson Valley
    Some stuff
    don't think so. after speaking with james, he said all i would need was the entune harness.
    long usb cable is already on the list.
  21. Apr 11, 2018 at 8:49 AM
    Danimal86
    Daniel
    Sacramento, CA
    Gotcha. I dont have the jbl, so i'm not 100% sure about how the wiring will go, but i bet James will help you through it (i had to call him when i did my install).
    Edit:I thought i read you DID have the JBL. My bad. Yours will look similar to mine.
    Here's mine before i buttoned everything up
  22. Apr 11, 2018 at 9:27 AM
    Shelbie67
    Blake
    NorCal
    If you have the harness then you are good to go. The harness steals the signal after the amp (output side).
    The amp just needs to stay installed. You are talking the amplified signal (post amp), so nothing has to return to it since you are running new speaker wire.
    I’d be willing to give you my cell number if you wanna text/call me anytime.
    smslavin[QUOTED][OP] likes this.
  23. Apr 11, 2018 at 9:28 AM
    Shelbie67
    Blake
    NorCal
    Nice! Absolutely love JL amps and subs!!!
  24. Apr 11, 2018 at 9:34 AM
    Danimal86
    Daniel
    Sacramento, CA
    What? Why would you keep the factory amp? You only need to keep it if you have the jbl system. OP said he doesn't have jbl system. Yank that factory amp out!
  25. Apr 11, 2018 at 9:52 AM
    Shelbie67
    Blake
    NorCal
    I missed that.....
    Pull that shit out! Lol
    831Tun and smslavin[OP] like this.
  26. Apr 11, 2018 at 10:11 AM
    Danimal86
    Daniel
    Sacramento, CA
    Glad we are on the same page. Lol
    Shelbie67[QUOTED] likes this.
  27. Apr 13, 2018 at 9:19 AM
    Danimal86
    Daniel
    Sacramento, CA
    @smslavin
    Did you get the DRC-200 to go with the fix? You'll want that.
  28. Apr 13, 2018 at 9:24 AM
    smslavin
    Hudson Valley
    Some stuff
    that comes with the TwK so, yep, i've got it.
  29. Apr 13, 2018 at 9:26 AM
    Danimal86
    Daniel
    Sacramento, CA
    Good!
    I'll be interested to hear how you like the twk. I thought about adding that to mine.
  30. Apr 13, 2018 at 2:11 PM
    Shelbie67
    Blake
    NorCal
    how are you getting your sound now? you going straight to amp or do you have a processor now?
