I'm so new!
Discussion in 'New Member Introductions' started by Zelphrin, Apr 29, 2021.
  1. Apr 30, 2021 at 7:02 AM
    LML 3500HD
    Are you shopping your truck, pulling it behind a U-Haul, or driving?
    We have a pretty good network of members if you need any help on your travels. If you take I-70, stop in for a beer. I did the I-40 route when going from the East coast to west.
  2. May 1, 2021 at 5:30 AM
    Zelphrin
    Zelphrin [OP] New Member
    Jon
    2014 Toyota Tundra Limited Double Cab
    Aftermarket antenna, interior LED lights, license plate LED lights, LED bed lights, 6" Rough Country lift kit with V2 rear shocks and front lifted struts (no spacers), ION 134 20x10 matte black wheels with Toyo Open Country AT2 33" tires
    This truck will be pulling my 1990 Mercedes 300SL all the way to Maryland...
  3. May 1, 2021 at 1:56 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Thank you for your Service and welcome from Phoenix
    Zelphrin[OP] likes this.
  4. May 1, 2021 at 2:00 PM
    Zelphrin
    Jon
    For those from Socal... I just ran some Big Bear trails!
    Kgfit85 likes this.
  5. May 1, 2021 at 2:13 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Please answer the following questionaire:
    1) what transmission gear will you be towing in?
    2) will you engage the Hoe/Tall shift point logic of your ECU by pressing the Hoe/Tall button?
    3) will you engage the cruise control logic of your ECU while towing?
    4) what tire pressure will you be running?
    5) what is the largest tire I can run on a stock PRO suspension?
    6) what engine oil do you use? list brand and viscosity, plz.
    7) do you monitor your transmission temperatures?
  6. May 1, 2021 at 2:18 PM
    Zelphrin
    Jon
    1) what transmission gear will you be towing in? As an automatic i will delegate that to Tow/Haul. Generally, I tow in 4th gear, but I haven't towed anything in a long time let alone with this Tundra since my grandfather's Avalanche... and he liked to tow in 3rd for hills, and 4th for flat land.
    2) will you engage the Hoe/Tall shift point logic of your ECU by pressing the Hoe/Tall button? Yes.
    3) will you engage the cruise control logic of your ECU while towing? No. I have pretty much abandoned cruise control after lifting the truck.
    4) what tire pressure will you be running? This is an interesting one. I'm going to take some suggestions on this.
    5) what is the largest tire I can run on a stock PRO suspension? On completely stock... I'd have to google this one.
    6) what engine oil do you use? list brand and viscosity, plz. Currently using Pennzoil full synthetic 0W-20... because it's hot here where I am lol.
    7) do you monitor your transmission temperatures? Not normally.
    These are all good questions that I'm about to do research on. Thanks!
    hagrid likes this.
  7. May 1, 2021 at 4:28 PM
    Dupey
    Dupey I love chips and salsa!
    Northern Colorado
    2014 tundra platinum
    TRD PRO GRILL TRD PRO HEADLIGHTS W/I hacker ADAPTER WIRING WEATHER TECH FLOOR LINERS C4 FRONT BUMPER WITH 30 inch LIGHT BAR RCI ROCK SLIDERS RCI SKID PLATE RCI LOW PROFILE BED RACK ARB TOURING ROOF TOP TENT TOYTECH 2.0 FRONT COILOVERS TOYTECH REAR SHOCKS TOYTECH 1.75 SHACKLES
    Welcome from northern Colorado
