I'm screwed
Discussion in 'General Tundra Discussion' started by TRD-tv, Mar 20, 2019.
  1. Mar 20, 2019 at 1:51 PM
    TRD-tv
    TRD-tv [OP] New Member
    OHIO
    2012 MGM Tundra TRD
    yeah this is all from installing my Clazzios, and im gonna look into new bolts for sure. and yeah at this point im kinda forcing them. i guess ill get new bolts
  2. Mar 20, 2019 at 1:51 PM
    15whtrd
    15whtrd Mr. Blonde
    Wish I could come give you a hand
    TheBeast and TRD-tv[QUOTED][OP] like this.
  3. Mar 20, 2019 at 1:52 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    ill definitely try this as well. great ideas here. and no those are half turns lol
  4. Mar 20, 2019 at 1:53 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    ^^ yeah, wish I could help. I feel helpless!
    TRD-tv[OP] and 15whtrd like this.
  5. Mar 20, 2019 at 1:55 PM
    TRD-tv
    OHIO
    2012 MGM Tundra TRD
    damn, yall are so sweet. i appreciate it. im gonna go grill a burger, than try some of the ideas here. in the meantime ill order some new bolts
    Darkness, TheBeast and 15whtrd like this.
  6. Mar 20, 2019 at 1:55 PM
    15whtrd
    15whtrd Mr. Blonde
    So you say it’s got two layers of steel that are threaded? If that’s the case and it’s spinning in 15 to 20 turns before it gets difficult, it sounds like it’s not starting on the second set of threads properly.
    Try this. Spin them in until it starts to get difficult. Then back them out a few turns and get some weight on the area to sandwich the two metals together then see if they will thread in.
  7. Mar 20, 2019 at 1:56 PM
    Adam New Member
    I second the idea of take the seat out and try to run them down. I had some issues with my back 2 wide bench seat. I had to end up sitting in it and wiggling my fat ass around until it clicked down.
    15whtrd likes this.
  8. Mar 20, 2019 at 1:57 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah I agree the seat out might be the key to figuring out what it’s going to take to get them to thread in properly. Once you get that down then try it with the seat.
  9. Mar 20, 2019 at 2:01 PM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    Are you leaving all the other bolts loose? I found that sometimes you must still be able to wiggle the seat a tiny bit to get all of the bolts in place, and then torque them down once everything is ready.
  10. Mar 20, 2019 at 2:40 PM
    G10dra
    G10dra Not a New Member
    Are all 4 bolts the same length, if not then the two short once may be for the back. If they're the same length then try each bolt on each thread to see which one screws in loosely without much effort. Most bolts should screw in almost half the length before needing the help of a ratchet tool.
  11. Mar 20, 2019 at 2:54 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    I would never use a impact on anything on my truck, that's just me. Hell I don't like using a cordless other than taking out or screwing them back in till you can hand tight the rest of the way. As mentioned above I would look for shavings or debris in the threads. Run a tap down them, Tap Magic works well with drilling and tapping. If there stripped, move up 1 size and re-tap. Take all bolts down as you go. You got this Man:thumbsup:
  12. Mar 20, 2019 at 3:17 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If the bolts have a taperd end for the first few threads, those are self-tapping bolts. Because of the taper, they will go wrong a few threads before the real f'up begins.
    The tapping plates on the body that they screw into are probably drilled but not tapped. During assembly, the tapping plates are threaded on assembly using self-tapping bolts. Because of this, expect the bolts to be tight in the threads. They will cut new threads if you get them cross-threaded, which is probably what is happening. As a previous post suggested, use a long extension on your socket to help you get them started right.
    Edit: Oh...wait...15-20 TURNS!!! They're started straight...you got something else going on like @15whtrd said.
    Trooper2 and 15whtrd like this.
  13. Mar 20, 2019 at 3:38 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    I can't offer anything here but this.
  14. Mar 20, 2019 at 4:36 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If bolts look good, get a tap and re-thread.
    probably tap for new bolts too.
    OR18TRD likes this.
  15. Mar 20, 2019 at 6:40 PM
    Mlk7879
    Mlk7879 New Member
    Michael
    18 sr5
    I had the same problem. The thread was fine.i had to give up and just say to my, self cross thread is better than no thread, I had to use an impact and it went in fine after about a quarter inch. No damage to the threads whatso ever. Iam guessing it just needs some torque to get going.Maybe it is some type of safety measure built in so the seats won't ever become loose unless some one puts enough torque on it to fully remove bolt and seat.
    TheBeast likes this.
  16. Mar 20, 2019 at 6:53 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just set a weight limit for passengers. 200lbs and up should be safe, less than that and they may fly out during braking.
  17. Mar 20, 2019 at 7:25 PM
    markshoreline
    markshoreline New Member
    Mark
    Whidbey Island, WA
    2006 Tundra TRD 75k miles
    Front trailer hitch, tonneau cover
    I know your problem well! I removed the driver side rear seat to gain more storage space by removing the bolts that attach the seat base to the bracket. However, when I went to snug the bolts back in place after the seat was out I have the same problem! It's almost as if there is a loose piece under the bracket that the bolt threads on to. It may be necessary to remove the bracket, run the bolt through the seat base and then reattach the bracket to the floor.... However, I just left the bolt loose in the hole and stored the seat in the garage ;)
  18. Mar 20, 2019 at 7:34 PM
    Why not run a tap in the hole to check/clean the threads.
    Trooper2 likes this.
  19. Mar 20, 2019 at 8:49 PM
    #49
    speckmon
    speckmon Must. Have. Pow.
    Thornton, CO
    '07 mountain road bomber
    This guy gets it. Working in a precision machine shop all day....I'd never use any impact on most parts of my vehicle, aside from suspension. Mighta fucked 'em from the get go. I'd get out the tap and die and go from there.
    driverdog and rons23[QUOTED] like this.
  20. Mar 20, 2019 at 8:59 PM
    #50
    shackleford rusty
    shackleford rusty New Member
    TEXAS!
    admittedly did not read all the prior posts; only skimmed.
    but... on a crewmax, the 60 rear seat has 3 bolts with same thread pattern and 1 bolt with different pattern.
    the inside rear bolt (middle of cab, but left rear (looking at back window) bolt of CM backseat is a course threaded bolt), while the other 3 (right rear (looking at back window) and front 2 are a fine thread.
    hope the above made sense.
    just reinstalled the rear 60 seat of my CM after the jbl sub GB and noticed the difference (it was also mentioned in the GB installation post).
    i am very careful to place the exact bolt in the original hole (that's what she said) when reinstalling anything. takes more time when disassembling, but i have a little bit of extreme OCD.
    my wife kicked her skid plate bolts "out of the way" and mixed them all up while i was changing her oil (all laid out on ground the position in which removed) and i freaked out.
    uncomfortable dinner that evening.
    hope this helps and good luck to ya.
  21. Mar 20, 2019 at 9:40 PM
    #51
    Fireman/68W
    Fireman/68W New Member
    J
    S/E Wyoming
    2018 White SR5 Tundra
    A lot in progress!
    Are the front and rear bolts the same length?
  22. Mar 20, 2019 at 9:45 PM
    #52
    TheBeast The Beach
    that was my experience as well..minus the impact :)..needed some torque to get going.
  23. Mar 20, 2019 at 9:48 PM
    #53
  24. Mar 20, 2019 at 9:59 PM
    #54
    Twinky
    07 double cab work horse
    Maybe this was already been asked but, do the bolts have any thread lock on them?
    If so maybe your just reaching the thread lock on the threads and thats what is causing them to feel tight.
    Other then that, i do know that getting them algined right can be a bit tricky sometimes.
  25. Mar 21, 2019 at 12:16 AM
    #55
    Kerktam
    Kerktam Lexus truck wanted
    middle of nowhere, up north
    2023 limited TRD OR, 2024 silverado 5.3
    35 tires, 2 inch level kit
    Plan b is taking it to the shop, they will not afraid to get them in there tight
  26. Mar 21, 2019 at 12:43 AM
    #56
    Dapsters
    Dapsters New Member
    I registered an account just to ask this... isnt your problem the exact opposite of your thread title?
  27. Mar 21, 2019 at 2:44 AM
    #57
    Welcome.
  28. Mar 21, 2019 at 3:22 AM
    #58
    Diesel3612
    Diesel3612 New Member
    2019 tundra SR5 crewmax 4X4 super white
    Bull bar, chase rack leveling kit 33s on anthracite rims
    If they tighten quick then cross thread is done
  29. Mar 21, 2019 at 3:58 AM
    #59
    Moon Puppy
    Bob
    South Carolina
    2020 Tundra Limited
    That's messed up, why would they have different bolts?
  30. Mar 21, 2019 at 4:09 AM
    #60
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    Interesting choice of words after the previous comments were talking about lube...
    TRD-tv[QUOTED][OP] likes this.
