I'm at my wits end- Master Cylinder issues..
Discussion in '1st Gen Tundras (2000-2006)' started by Stats, Feb 11, 2019.
  1. Mar 9, 2019 at 5:53 PM
    Stats
    Stats [OP] New Member
    2005 Tundra LTD
    The junk yard replacement started leaking 1 week after the install aannnnnnnnnd had a tensioner pulley bearing go out
    The dealership repair tech found out the Dumb AZZZZ parts department quoted the wrong part number and resulting price.... 1000.00 for the master n brake booster to the service coordinator THREE DIFFERENT TIMES. ANNNNND they had the parts in house to do the repairs all along.
    I went thru the roof.
    Went to Service Mgr. explained I had 30 day rental and purchased parts that could have been avoided first time.
    Long story longer.... they took my expenses off this bill.... 1500.00 actual costs.. not "my time" searching, finding time etc.
    The Mgr made it right.. I gave the repair techs Saltgrass steak house gift certificates for finding the discrepancy.. they installed all repair items.. booster n master free.
    A lot to get there, but "All's well that ends."
    Happy Stats
  2. Mar 9, 2019 at 6:18 PM
    Professional Hand Model
    Hand Protectors
    Stoked you got it fixed. Good on ya for tipping out the techs. Give us the final conclusion of exactly what parts we need and what to avoid. Some quick bullet points.
    Luckydog likes this.
  3. Mar 9, 2019 at 7:50 PM
    Stats
    2005 Tundra LTD
    My situation 05 Tundra.. No ESC.. Electronic speed control
    This is a total unit... Booster n master
    As listed on the receipt.
    OEM Parts
    Cylinder Assy, Brake
    P/n 47200-0C073 List $1224.71 Net.. $772.73
    Labor $632.31
    Added new fluid n bled brakes..
    Lessons Learned:
    NEVER get used parts that have seals or O rings.. They WILL degrade over time and may never work properly again as in my case...an 05 sitting in the TX sun/summers.. should known better and can't fix/repair them... obviously
    NEVER trust a parts department answer to a parts answer. Make them prove (eyes on) the recommendation vs the VIN number.
    The "seasoned" parts guy never cross-referenced my VIN to the documented replacement parts list..... just pulled it out of his ass as to what he
    "thought" is was or "should be". This 05 year used two different master cylinder configurations..same with the Sequoias. Some had ESC.. some didn't... mine didn't and he thought it should have the higher priced part.
    I'd find a source to cross reference parts to your VIN.. to verify every part referenced for future repairs.
    YMMV
    Hope this helps.
    Stats
  4. Mar 10, 2019 at 5:28 AM
    Bqe
    Bqe New Member
    2005 tundra
    Took apart the failed cardone master...was missing an o ring between the main master and secondary unit that attaches to booster. Purchased a raybestoses master which came with replacement o rings that attached to the secondary unicorn part.. Makes me wonder what other gaskets and seals a1cardione left out of their rebuild that caused it to catastrophically fail at speed in the first place.
  5. Mar 10, 2019 at 6:30 AM
    Stats
    2005 Tundra LTD
    Been wondering how your situation turned out...thanks GOD it wasn't tragic like it could have been!
    How long were you stuck.?
    How do ya get home n how did you get a new part?
    What was your fix?
    Maybe my part number solution can help...
    I'm SEWWWWW done w/ rebuilds n salvage parts.
    I know dealerships aren't perfect by any stretch n you pay for their service dearly, BUT I do have easier recourse if needed vs a
    parts house like Cordone or Summit who strung me along for 11 days of broken promises and $35/ day car rental w/ no results....
    I HATE liars.
    Give us an update on your situation.
    Thanks Much
    Stats
  6. Mar 10, 2019 at 12:50 PM
    Somemedic
    Somemedic New Member
    Mark
    2000 SR5 AC Cab/ 2010 Dbbl Cab Long Bed
    Yak racks Awning LED dash LED headlights / fog lights Hellwig Helper springs KC HD springs Bed slide out Sony AX100 w/ cam SOS Big Brake front kit Rancho 9000 front / rear
    15whtrd likes this.
  7. Mar 10, 2019 at 1:14 PM
    Stats
    2005 Tundra LTD
    I'm not sure I'd want to be a Beta Tester for a "critical function" item such as my brakes. Too much potential liability for me personally and if something bad or a major accident were to happen...Oh boy, unleash the lawyers!
    Looking at the configuration, my configuration has the brake line inputs on the opposite side of the item pictured... right side termination.
    In the installed position (my config.)brake lines are on the left side, with another line from the master to the unicorn part.. left side as well. See my original pic.
    I appreciate the input though. It is a solution, but not for me.
    This whole experience has made me an OEM or nuthin' guy... buy once, cry once... hopefully.
    Thanks for the input
    My issue is solved and it took a long time to get there with a few good lessons learned.
  8. Mar 10, 2019 at 1:28 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Congrats. Having been there myself before, I know you can finally take a deep, relaxing breath. You scored BIG getting the dealer to cover your expenses...you musta' really raised some hell. :rofl:
  9. Mar 10, 2019 at 2:03 PM
    Stats
    2005 Tundra LTD
    No, I really didn't raise some hell... the Svc. Mgr knows me by face n we make small talk conversations when I'm there.
    Just presented it as "Your parts department presented some bad information to the service coordinator (3 times) which cost me 1500.00 of which didn't need to happen if the person had done their job right the first time.... i.e. cross-referenced to VIN to the correct parts list."
    It was pretty simple.... I portrayed the following;
    What would you do if this was your Mom or daughter's having the same issue?
    I'm going to buy another truck and I want to buy it from this dealership, but if this unnecessary expense doesn't get resolved, I'll take my purchase and future service to another dealership.
    And then I shut up....and didn't say a word.
    Having two managers in the same room helped put the onus of "doing whats right" in their court...and they played nice.
    Calm, cool n steady was the plan and was executed perfectly.
    Brash, course language and threats wouldn't have been appropriate.
    If you want to learn more about the negotiations tactics used.. get the CD's, book or audio book of
    "Never Split the Difference" -Chris Voss.
    I listened to them while driving...over and over.
    Those tactics I learned REALLY worked n it was played in spades for this problem.
    I was like.. CRAP.. this stuff DOES work.
    This recommendation is a HUGH nugget of information for future negotiations of any kind.
    Promise.
    Hope this helps.
  10. Mar 12, 2019 at 1:43 PM
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    15whtrd likes this.
  11. Mar 12, 2019 at 1:48 PM
    Racingjohndeere55
    Racingjohndeere55 New Member
    Just a dumb question, is it loosing fluid that you need to top it off several times or is it just a one time thing because the level is low?
    FlightSimGuy likes this.
  12. Mar 12, 2019 at 1:57 PM
    FlightSimGuy
    I'm assuming you are asking me? I'm not sure, I'll ask him. I know he said something about fluid coming out when he removed it.
  13. Mar 12, 2019 at 1:59 PM
    Racingjohndeere55
    Ok, that's not where I was thinking.
  14. Mar 12, 2019 at 4:36 PM
    Stats
    2005 Tundra LTD
    See my previous post... #32, 34 for the work around.....
    PLS DON'T buy a salvage part... seals will prolly be degraded n leak like it did mine... IF you can find one... my salvage part lasted a week.. tops..
    Good Luck.... seriously buy the P/N listed above n save yourself a LOT of headache.
    Stats
  15. Mar 12, 2019 at 11:05 PM
    Bqe
    Bqe New Member
    2005 tundra
    Whatever part u buy photo match it to your existing as 2005 used different masters and brake systems. My truck used part 11-3300 from cardone which is the only company to rebuiod and offer the OEM two part master together. I eventually bought a new raysbesrayb front main master and reused the back unicorn part that bolts to the booster. They're available on Amazon.
  16. Mar 14, 2019 at 2:47 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    Like I said, I would of just used one from an older vehicle. All they did is make a 2 piece master cylinder.
  17. Mar 14, 2019 at 7:30 AM
    FlightSimGuy
    Link?
  18. Mar 15, 2019 at 2:25 AM
    Bqe
    Bqe New Member
    2005 tundra
  19. Mar 18, 2019 at 9:29 PM
    #49
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    I'm confused as I have a 2006 DC with what seems is the same booster, balancing valve, master cylinder configuration as well. Did you say the dealer wants $3800 for the part? Is this part below not the correct part?
  20. Mar 19, 2019 at 12:28 AM
    #50
    Bqe
    Bqe New Member
    2005 tundra
    Picture of part is correct but Toyota doesn't include balancing valve for the 380. That's sold with the booster. Check the diagram of booster and you'll see it.
  21. Mar 19, 2019 at 3:00 AM
    #51
    remington351
    2006 SR5 DoubleCab
    I think we have both a stability control and non stability control version in this discussion. The pic in the original post is appears to be the non stability version, which is also what I have. I'm thinking #47207 does come with the distribution valve. The stability version is completely different, or so it appears, and I see now the price for the assembly is $2k. Bummer if you have stability control.
    speedtre likes this.
  22. Mar 19, 2019 at 6:06 AM
    #52
    Bqe
    Bqe New Member
    2005 tundra
  23. Mar 19, 2019 at 6:15 AM
    #53
    speedtre
    speedtre New Member
    Inland Northwest
    I was a bit bummed my 2006 didn't have stability control when a bought it a few months ago....not anymore.
  24. Mar 19, 2019 at 7:58 AM
    #54
    remington351
    2006 SR5 DoubleCab
    Thanks for pointing that our Bqe. Now I understand the problems others were having sourcing that part as the "entire booster" assembly mentioned in the notes , 44610-0C051, is discontinued. I would not have expected this from Toyota.
  25. Mar 19, 2019 at 9:10 AM
    #55
    Bqe
    Bqe New Member
    2005 tundra
    Problem is A1cardone is remanufacturing the OEM complete master cylinder but they're apparently screwing up as I've had three of theirs fail on me. I've purchased a new raybestoses front part only and now have the issue with the balancer part leaking into the booster. Wish Cardone would figure out how to fix this as it's not cool losing brakes at speed.
  26. Mar 19, 2019 at 10:02 AM
    #56
    remington351
    2006 SR5 DoubleCab
    I see a reference on some of the parts websites to a master cylinder rebuild kit for $50 or so. Could it be as simple as replacing the three o-rings and possibly the piston #1 shown above?
  27. Mar 19, 2019 at 10:11 AM
    #57
    Bqe
    Bqe New Member
    2005 tundra
    Please post link for that website.
    Does it include the rebuild for the secondary balancer unit? I see the o ring between booster and balancer but that just seals the vacuum and doesn't prevent brake fluid leaking into booster.
  28. Mar 19, 2019 at 10:32 AM
    #58
    remington351
    2006 SR5 DoubleCab
    I'll find it again. The terminology is what's confusing me. Post #57 is from the service manual. What I believe your refer to as the "balancer" the FSM calls the master cylinder body.
  29. Mar 19, 2019 at 10:38 AM
    #59
    Bqe
    Bqe New Member
    2005 tundra
    It's called the secondary master cylinder.
  30. Mar 19, 2019 at 10:47 AM
    #60
    remington351
    2006 SR5 DoubleCab
