Ideas For Center Console Switches
Discussion in '2.5 Gen Tundras (2014-2021)' started by Inquiringone, Jun 7, 2020.
  1. May 16, 2022 at 3:36 PM
    #91
    Rocfrog
    Rocfrog New Member
    Nick
    2019 Toyota Tundra TRD Pro Voodoo Blue
    I offer two different styles…hidden hardware and visible hardware (AJT style)
    nick
  2. May 16, 2022 at 6:38 PM
    #92
    Bradyboyy88
    Bradyboyy88 New Member
    Shaun
    Do you sell prepainted and sanded ones that will look oem? Also are the slots the same dimension and specs as the oem center console under the screen (2014+)
  3. May 16, 2022 at 7:19 PM
    #93
    Rocfrog
    Rocfrog New Member
    Nick
    So they are sold as what I call “unfinished” so I do little to no post printing work to them. Lots of people use them as is, mine is as is in my truck.
    I’m not sure what your second question is…
    Nick
  4. May 16, 2022 at 7:43 PM
    #94
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    You'll be able to fit the same size switches as Toyota OEM. Ch4x4 sells them as does AOB (Air On Board)
    Rocfrog likes this.
  5. Apr 4, 2024 at 1:19 PM
    #95
    Getoffmylawn
    Getoffmylawn New Member
    Taylor
    Bumping an old thread since I'm going to install one of these in my truck. Can you tell me what you did to smooth out the top? Is that sanded and painted? Or just sanded?
  6. Apr 7, 2024 at 2:45 PM
    #96
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    You want one of these:
    https://www.tundras.com/threads/rmf...insert-non-platinum-trim.139001/#post-3510057
    If you want it smooth instead of textured, then a combination of some light sanding and several coats of a filling/building primer, followed by finish painting it with SEM Trim Coat.
    bulldog93 likes this.
  7. Apr 7, 2024 at 2:53 PM
    #97
    Getoffmylawn
    Taylor
    So I have the one from CN designs similar to that one in the link, and he suggested using a glazing putty to smooth it out and then sanding it down by hand. Thanks for the suggestion on the filling/building primer, I may give that a go.
    I kind like the texture of that one in your link though...may just get that one and run it as is!
