Idatalink Maestro Info
Discussion in 'Audio & Video' started by smooosh, Jan 12, 2018.
  1. Feb 28, 2019 at 1:58 PM
    #91
    TNtundra18
    TNtundra18 New Member
    Charlotte, NC
    2018 Tundra Limited
    Installed one on my girlfriends Jeep and everything worked as it should. It was a pretty neat set up and I was impressed.
  2. Feb 28, 2019 at 4:50 PM
    #92
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Toyotoholic likes this.
  3. Feb 28, 2019 at 5:47 PM
    #93
    Smoofers
    Smoofers New Member
    N TX
    2018 TRD Sport
    Really? My 2018 TRD Sport shows numeric TPMS in the instrument cluster screen under the same panel as the trailer brake readout. I have a hard time believing a platinum wouldn't have that feature.
  4. Feb 28, 2019 at 9:18 PM
    #94
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
  5. Mar 2, 2019 at 1:33 PM
    #95
    tnine
    tnine New Member
    Todd
    2016 TRD Off Road
    ADS External Reservoir Shocks Deaver Leaf Springs 35" Tires C4 Fabrication Bumper Warn Winch Baja design LP9
  6. Mar 3, 2019 at 7:06 AM
    #96
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I had an installer hook up 4 new door speakers with the JBL amp group buy, and a new pioneer head unit.
    The installer said he’s getting no sound to the speakers and thinks the idatalink maestro is the problem. Anyone have any experience with this? The front 3 dash speakers are working because it’s wired directly to the new head unit.
  7. Mar 3, 2019 at 7:28 AM
    #97
    ninjajay
    Spoolston, TX
    The maestro needs to be told you're using an external amp from the HU RCA
  8. Mar 3, 2019 at 7:37 AM
    #98
    pschiller86
    Paul
    Temecula, CA
    How do I do that?
  9. Mar 3, 2019 at 8:13 AM
    #99
    ninjajay
    Spoolston, TX
    IIRC, don't plug in the speaker parts to the Maestro at all, RCA goes directly into the headunit, and whatever speakers you want on deck power go directly to the HU part as well
  10. Mar 3, 2019 at 8:18 AM
    #100
    pschiller86
    Paul
    Temecula, CA
    That’s what my installer said he did. But still had to audio from any of the new speakers.
  11. Mar 3, 2019 at 8:22 AM
    #101
    ninjajay
    Spoolston, TX
    What about the head unit? Maybe a setting in there to configure how the RCA outputs.
  12. Mar 3, 2019 at 8:25 AM
    #102
    tnine
    tnine New Member
    Todd
    2016 TRD Off Road
    @ninjajay im looking at the RR-TOY02-DS for the maestro. I’ve read some install horror stories that require soldering wires. Did you have to do any soldering, or was it all just adapter plug ‘n play?
  13. Mar 3, 2019 at 8:25 AM
    #103
    pschiller86
    Paul
    Temecula, CA
    Ill definitely take a look at that when I go see the truck. He says a lot of these idatalink maestro devices are faulty. And it seems that way reading reviews on Amazon but I dunno.
  14. Mar 3, 2019 at 8:30 AM
    #104
    ninjajay
    Spoolston, TX
    Soldering is one option to build the harness. You can also use caps, connectors, or even electrical tape. I chose to solder mine. I think Crutchfield sells prebuilt ones that would be 100% plug and play?
  15. Mar 3, 2019 at 9:20 AM
    #105
    cantle
    cantle New Member
    Durango, CO
    2018 Platinum CrewMax Barcelona Red
    TRD Pro Exhaust, TRD Skidplate, TRD Faux-Pro wheels, Ridge Grapplers
    I'm fine with soldering... other than that, how is the install? I was going to get the items listed on the Maestro website and take a stab at it myself... along with the head unit of course. I assume I can build the harness and solder on the bench, or does it need to be done in the vehicle?
  16. Mar 3, 2019 at 9:34 AM
    #106
    pschiller86
    Paul
    Temecula, CA
    I was recommended to buy a new idatalink maestro and see if that fixes the problem.
    :spending:
  17. Mar 3, 2019 at 12:22 PM
    #107
    ninjajay
    Spoolston, TX
    You can do all the wiring on the bench so everything is PnP once you're in the truck. The most annoying parts for me were removing the console and running the OBD2 wire down.
  18. Mar 3, 2019 at 12:24 PM
    #108
    ninjajay
    Spoolston, TX
    That doesn't sound right, give idatalink tech support a call
  19. Mar 3, 2019 at 12:39 PM
    #109
    pschiller86
    Paul
    Temecula, CA
    Their support is only open Mon-Fri so if it doesn’t go well today I’ll call them up tomorrow.
  20. Mar 3, 2019 at 1:21 PM
    #110
    cantle
    cantle New Member
    Durango, CO
    Sweet. And I assume those parts are on the install instructions? I've never done anything car-audio before like this, but it seems pretty straight forward.
  21. Mar 3, 2019 at 4:53 PM
    #111
    ninjajay
    Spoolston, TX
    Yup, there's a big graphic for each vehicle that shows which wire matches with what on the HU harness, plus a few that are mfg specific at the end
    cantle[QUOTED] likes this.
  22. Mar 3, 2019 at 6:10 PM
    #112
    cantle
    cantle New Member
    Durango, CO
    Got it, and went through it (dry fire) before I order anything. You said finding the OBDII port was a bitch? Do you have to re-route anytthing?
  23. Mar 3, 2019 at 6:17 PM
    #113
    ninjajay
    Spoolston, TX
    Finding it is easy, dropping the cable down from the headunit was a pain
  24. Mar 4, 2019 at 12:08 PM
    #114
    Icuhackn
    Icuhackn New Member
    Joe
    ninjajay, I am about to do my install in the next day or so with the Pioneer AVIC-8400NEX ... all from Crutchfield so I have the maestro, etc. Just curious if you know ... does the existing "mic" in your truck work for phone calls, etc or did you run the new radio mic? I am not seeing anything stating or not stating that it connects up to maestro, etc. Thanks in advance! I have a 2017 MGM CM Platinium.
  25. Mar 4, 2019 at 1:36 PM
    #115
    ninjajay
    Spoolston, TX
    I ran a new mic, some people actually use the new mic in the factory location but I just clipped it to the driver sun visor
    Icuhackn likes this.
  26. Mar 4, 2019 at 6:35 PM
    #116
    cantle
    cantle New Member
    Durango, CO
    It would rad if you took pictures/documented everything. I will do the same when I get around to mine, and it'll help the collective resources of this site!
  27. Mar 4, 2019 at 6:55 PM
    #117
    tnine
    tnine New Member
    Todd
    2016 TRD Off Road
    @ninjajay another noob question for you.. I’m assuming your parking sensors still function on the HUD once you replaced the head unit? This is functionality I definitely want to retain if I replace the head unit. The shop I’m talking to hasn’t installed the maestro in a Tundra with parking sensors, so they are reluctant to gaurentee it will continue to function. I assume it’s a separate system, but I know a lot of manufacturers are starting to run all functions through their head units and wanted to confirm before I spend that kind of money.
  28. Mar 4, 2019 at 7:30 PM
    #118
    ninjajay
    Spoolston, TX
    I have an 18 so my sensors show up in the center cluster. No change in functionality
    Lux749 likes this.
  29. Mar 5, 2019 at 4:13 PM
    #119
    Icuhackn
    Icuhackn New Member
    Joe
    Just want to make sure ... is the antenna on top of the CM above passenger side (roof) the Satellite antenna? Cant find any documentation ... I am assuming it is and that the GPS antenna is hidden someplace else inside the truck. Thanks in advance all!
  30. Mar 5, 2019 at 7:54 PM
    #120
    pschiller86
    Paul
    Temecula, CA
    Does any one have a pic of the maestro RR with the proper placement of all the wiring? I’m not getting the controls to work on the steering wheel.
