Idatalink Maestro Info
Discussion in 'Audio & Video' started by smooosh, Jan 12, 2018.
  1. Feb 21, 2018 at 7:10 AM
    smooosh
    smooosh [OP] This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    why is that?
  2. Feb 21, 2018 at 7:15 AM
    TdotYdot
    TdotYdot New Member
    Danville,Kentucky
    '17 MGM SR5 Crewmax
    I think my nav is built into the non-jbl head unit that I will be replacing and because the Pioneer 4200nex doesn't have nav built in, it would be another $300 to add the part from Pioneer.
  3. Feb 21, 2018 at 7:28 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    The 4200 doesn't have a place to plug in GPS, since it doesn't have it. I lost the nav and compass, but I kept the STO2 I bought in case I swap headunits later on. The other screens all still work.
  4. Feb 21, 2018 at 7:28 AM
    smooosh
    Ongoing project
    Oh. I meant to keep the nav antenna. Yes if your headunit does not have gps built in you will not need the nav antenna.
    Are you keeping XM? If so you should get the ST02. Also you lose the "now playing" from the stereo in the center console if you dont have the ST02. (at least i did until i added it) No big deal but the ST02 is $20 so it does not break the bank to add it
  5. Feb 21, 2018 at 7:30 AM
    ninjajay
    Spoolston, TX
    Also no built in sirius/xm tuner on the 4200 :eek:
    I didn't lose "now playing" in the center screen.
  6. Feb 21, 2018 at 7:32 AM
    smooosh
    Ongoing project
    Most aftermarket does not have it built in except for the ability to add it. I never did because i dont use XM.
    Hum. Strange. In the 2018 JBL I did until i added the St02. I guess if you dont have GPS or XM you dont need it
  7. Feb 21, 2018 at 7:35 AM
    ninjajay
    Spoolston, TX
    Might be firmware related depending on the head unit used. I also have an 18 JBL.
    Parts I used:
    Maestro RR
    TO2 main harness
    USB TO2 harness
    Metra antenna adapter (radio antenna)
    Micro bypass (video in motion)
  8. Feb 21, 2018 at 7:41 AM
    smooosh
    Ongoing project
    strange. Oh well. Glad it worked for you.
  9. Feb 21, 2018 at 9:32 AM
    TdotYdot
    TdotYdot New Member
    Danville,Kentucky
    '17 MGM SR5 Crewmax
    Did you have to buy the USB TO2 separate or does it come in the TO2 main harness?
  10. Feb 21, 2018 at 12:11 PM
    smooosh
    Ongoing project
    its an add on
  11. Feb 21, 2018 at 2:03 PM
    TdotYdot
    TdotYdot New Member
    Danville,Kentucky
    '17 MGM SR5 Crewmax
    That's what I thought, but thought I'd ask.
  12. Mar 14, 2018 at 2:26 PM
    Brewman78
    Brewman78 New Member
    How much of this is plug and play? I trade trucks yearly would like to move between new trucks
    Thanks
  13. Mar 14, 2018 at 2:30 PM
    smooosh
    Ongoing project
    The maestro itself is the same for every truck/car. Just different flashed firmware. the wiring harness is going to be truck/car specific.
  14. May 22, 2018 at 6:05 PM
    BTBAKER
    BTBAKER DIFFERENT NAME. SAME JUNK.
    Brad
    Castle Rock
    2023 Ram Rebel
    Hey Smoosh, I have the same Headunit in a 17 with the Maestro but I’m not getting any vehicle info. It’s actually greyed out on the Kenwood. Any ideas?
  15. May 22, 2018 at 6:30 PM
    smooosh
    Ongoing project
    Try reflashing it and Check what’s turned on.
    Beerdude77 and BTBAKER like this.
  16. May 22, 2018 at 7:43 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Thanks. How do you reflash the thing?
  17. May 22, 2018 at 7:58 PM
    BTBAKER
    Brad
    Castle Rock
    2023 Ram Rebel
    Forget it. I bought the SW version.:facepalm:
  18. Jun 8, 2018 at 12:33 PM
    rjrankin
    rjrankin New Member
    To bring this up from the dead. I just installed a Kenwood 9704s in my 14 crewmax. Used the maestro rr and to2 as well as the usb adapter. My steering wheel controls all work but I don't get any gauges and my tire pressure is reading na. The wiring diagram said I don't need to plug in the ODB2, but I did after it didn't work, and it was still the same. Anyone have this issue? I've reflashed it twice now. Thanks!
  19. Jun 13, 2018 at 7:14 PM
    #49
    ninjajay
    Spoolston, TX
    Maybe a setting in the headunit. On my pioneer my gauges stopped working once when the OBD2 got unplugged and I had to disable the gauges and re enable them in the HU
  20. Jun 13, 2018 at 7:36 PM
    #50
    PNW_Husky
    PNW_Husky New Member
    Great Pacific Northwest
    2018 MGM CM Platinum
    Does anyone know if you can retain vehicle settings (DRL settings, auto exit seat options, alarm chirp, light timers, etc.) in a JBL Platinum with an aftermarket head unit?
  21. Jun 13, 2018 at 7:37 PM
    #51
    ninjajay
    Spoolston, TX
  22. Jun 13, 2018 at 7:42 PM
    #52
    PNW_Husky
    Ok, can you keep the functions AND get rid of the factory amp?
  23. Jun 13, 2018 at 7:57 PM
    #53
    ninjajay
    Spoolston, TX
    that I'm not sure of... I'm still running stock everything except the HU and Maestro, I'd think it would be fine, though since the the only output from the headunit/maestro to the amp is RCA and remote
  24. Jun 14, 2018 at 8:03 AM
    #54
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    edited... see below.
  25. Jun 14, 2018 at 10:21 AM
    #55
    ninjajay
    Spoolston, TX
    Buried in the menus on my Pioneer
    20180614_121856.jpg 20180614_121845.jpg 20180614_121838.jpg 20180614_121824.jpg
    Spitfireat808 and Stroke250 like this.
  26. Jun 14, 2018 at 10:49 AM
    #56
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
  27. Jun 14, 2018 at 11:25 AM
    #57
    B737
    Jersey Shore
    Nice. I will look in the idatalink settings on my Kenwood. Truck wasn’t running when I checked but I don’t think that makes a difference.
  28. Jun 14, 2018 at 1:25 PM
    #58
    B737
    Jersey Shore
    ah i found them, the truck was off when i checked, oddly enough it needed to be running for the settings to appear.
    Spitfireat808 likes this.
  29. Jul 20, 2018 at 2:43 PM
    #59
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    How many people are running the Maestro on a 2018 Tundra? I just got back from the dealership for a check engine and multiple safety system malfunction issue (code P0705) and they're telling me the Maestro connection to the can bus is what is causing the issue. The codes came back with it disconnected, and they're telling me the Maestro potentially damaged the can bus. They won't warranty it. They're telling me that Toyota is cracking down on anything that connects to the ODB2 port since they're seeing so many issues in newer vehicles. I call bullsh*t.
  30. Jul 20, 2018 at 5:17 PM
    #60
    bowhun2r
    bowhun2r New Member
    Scott
    Steeler Nation
    Mines running fine. Been installed for about 2 months now. Only issue is within that time, my steering wheel functions did not work on startup. After stopping/restarting engine (reboot) it was fine. I think it's happened 2 times in that time span.
