Icon 58650’s
Discussion in 'Suspension' started by LT75, Jan 19, 2019.
  1. May 8, 2023 at 8:12 AM
    #181
    AccuTune Offroad
    AccuTune Offroad New Member Vendor
    El Cajon, CA
    If a shop had the shocks off, no spring and still couldn't rotate, I do not think applying more leverage is going to be a good idea. Aluminum preload nut on steel body. If they are built like Fox/King, it's not an easy replacement. Shock would have to be torn down, reservoir fittings removed for new preload nut to be threaded on. This is time consuming, which equals a costly repair.
  2. May 8, 2023 at 8:14 AM
    #182
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    C4 Overland bumper, BD SAE fogs, Leitner Designs Rack, Rago Bed Channel Stiffiners, Warn Xeon 12S Plarinum, Bedslide, Front Runner Roof Rack, roof rack solar panels, RCI Full under carriage aluminum studs, RCI rear diff skid, Rago dash plate, Rago accessory panels, OEM LED headlights with wiring harness.
    From reading OP post the shop wasn't able to remove the springs at all. I'm a bit confused because I have 800lb springs on and and can easily remove them from the shock without dealing with preload adjuster.
    2point5seconds likes this.
  3. May 8, 2023 at 8:19 AM
    #183
    2point5seconds
    2point5seconds Wish I didn't have so much money
    Sensei
    Nor Cal
    2019 Tundra SR5 TRD 4WD Double Cab
    Icon Stage 9 lift, 700 pound rated Eibach spring, Sumo Springs (rear), RCI engine skid plate. RCI Lower Control Arm Skid Plates, RCI Transmission Skid Plate, RCI Cat Guards, Rago dash plate. RAM phone holder. Bed rails. Tint. 17x8 Icon Rebound wheels. 315/70/r17 Falken Wildpeaks. AAC Trigger 6 Shooter, midland MTX-115 radio, Chassis Unlimited front bumper, OLB Bar light and ditch lights, Baja Fog lights, Smittybilt winch, Husky floor liners, bed rail, Cali Raised Bed Stiffeners, driver's side grab handle, Wheeler's Offroad front bump stops, Decked Tool Box
    Yeah. I apologize for not being more clear.
    The shop removed the shock and placed on a machine to compress the springs to try and make it easier to loosen the adjustor nut and reduce the 3" of preload. That way they could remove the 700 pound spring and add a 800 pound spring.
    I think the tension the springs were adding to the adjustor nut made it hard to loosen
  4. May 8, 2023 at 9:15 AM
    #184
    AccuTune Offroad
    El Cajon, CA
    So with a spring compressor, they were not able to compress it enough for the spring to be loose? Ultimately relieving all pressure from the preload nut?
  5. May 8, 2023 at 9:29 AM
    #185
    2point5seconds
    Sensei
    Nor Cal
    No, they were not.
    After trying it for awhile and getting worried about their safety, they decided not to try anymore. Then the decision to cut the adjustor nut came up. And just to replace them.
  6. May 8, 2023 at 10:21 AM
    #186
    AccuTune Offroad
    El Cajon, CA
    Ah, curious to know what kind of compressor they used. It would be worth going to a shop with a proper spring compressor that can handle that big of a spring. Keep in mind, the spring would still have to be compressed/removed to replace the preload nut, even if it needed to be cut off.
  7. May 8, 2023 at 10:45 AM
    #187
    2point5seconds
    Sensei
    Nor Cal
    Yeah. That's what JCBerb had asked about too. I guess I can ask the guy and see. You'd figured he'd have a good set up for that. That's all he does is repair/replace shocks. And was recommended by a local off road shop.
    What's funny is he never got back to me about a price of what it would cost to cut the adjustor nut off and rebuild the shocks. I'm thinking he doesn't want anything to do with the job since it was so much of a hassle. LOL.
  8. May 8, 2023 at 10:53 AM
    #188
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    Thing is, if the shop could not compress the springs enough to remove them from the shock, then you probably do not have to cut the adjuster nut at all, maybe all you need is to have the spring compressed enough to remove tension to allow you to make the adjustment...? Unless you've confirmed the threads are damaged. At this point, I am curious to see how you resolve this.
  9. May 8, 2023 at 11:00 AM
    #189
    JCBerb
    JCBerb Semper Fi
    Joel
    2017 CM LImited
    Some of these places focus on standard quick turnaround type jobs. In the time it takes them to figure out how to get the coil of the shock they could have probably run through a few quick jobs...
    They can come recommended but I recently learned that does not mean much, had an offroad place around me recommend a place for alignments after going to Icons...well they didn't really know how to do the alignment with the after-market parts.
  10. May 8, 2023 at 1:35 PM
    #190
    2point5seconds
    Sensei
    Nor Cal
    Funny you mentioned that. He came in on a Saturday to do the job. Usually is closed. And he had plans later.
    I am also curious to see how this turns out. I'll keep you updated.
  11. Feb 8, 2024 at 3:48 PM
    #191
    kaymonster
    kaymonster Member
    San Diego
    2018 Platinum
    Anyone know if Icon made any changes or these still come the same way today?
  12. Feb 8, 2024 at 6:52 PM
    #192
    SAGE63
    San Diego County
    @AccuTune Offroad
    I never saw your PM..
  13. Feb 12, 2024 at 2:53 PM
    #193
    AccuTune Offroad
    El Cajon, CA
    We already chatted, replied back to that PM
  14. Nov 11, 2024 at 1:04 PM
    #194
    mistamatic
    mistamatic New Member
    2018 Cement Limited DC
    Did you guys ever find out what 700# spring works for the 3.0?
    coTony likes this.
  15. Nov 14, 2024 at 6:40 AM
    #195
    coTony
    Tony
    Montrose, CO
    I was looking for the same
  16. Nov 14, 2024 at 8:22 AM
    #196
    SAGE63
    San Diego County
    I did not...
