I want to replace the speakers in my Tundra....need help.
Discussion in 'Audio & Video' started by 1999cutiger, Jan 6, 2018.
  1. May 12, 2018 at 5:59 AM
    #61
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    He means he modified the rear door factory tweeter location to allow his new tweeters to fit. There is some plastic that holds in the factory tweeter and he cut some away and then glued his new tweeter in.
    Question, how do you plan to power a sub with a 4 channel amp? Bridge the rear channels and not hook up any rear speakers?
  2. May 12, 2018 at 6:36 AM
    #62
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    @Beerdude77 is right. the factory tweeters in the rear doors are pretty small and the have a little plastic cup that holds them in. i took a dremel and cut the cup out so there would a flush mounting surface. i did not want to modify the front side of the door as i wanted to keep the factory appearance.
    also, if you're going to run new speaker wire rather than use the factory wire, you will need to drill a small hole in the door so you can get the wire through the factory grommet. the factory wiring harness takes up the whole space.
    you'll need a 5 channel amp or a 4 channel and a separate sub amp. i'm using a 1000w 5 channel amp. 75w x 4 @ 4ohms and 500w x 1 @ 1ohm.
  3. May 12, 2018 at 6:49 AM
    #63
    Beerdude77
    This was exactly what I thought too regarding the requirement of drilling that harness to fish the wires through. @B737 says he didn't have to, perhaps he can explain how he was able to avoid this procedure
    smslavin[QUOTED] likes this.
  4. May 12, 2018 at 7:00 AM
    #64
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i'm not sure how you could get through there without drilling a hole. there is no space in the factory harness connector. i did a small hole just below the harness. it's just large enough to put 16g speaker wire through. then i just put a little bit of silicon around it to seal it up. i can take a pic for you if you need it.
  5. May 12, 2018 at 7:17 AM
    #65
    Beerdude77
    Nah I believe you, I've seen the same in videos on YouTube and can't fathom how to do it without drilling. @B737 says there is a way in this thread https://www.tundras.com/threads/has-anyone-upgraded-the-dash-speakers.25539/
  6. May 12, 2018 at 7:53 AM
    #66
    TroyF
    TroyF New Member
    Troy
    Surrey British Columbia
    '17 TRD Offroad
    Leveling kit, BFG AT KO2
    So, I was blown away by how poor the sound system is. I've never upgraded a vehicle sound system in my life but this sound is worse than a 80s Kcar. My question is do I have to replace the front control center (is this what y'all are referring to as a head unit). I don't want to lose anything and want to leave it as stock as possible. I don't need loud but I do want quality or at least not shit. Thanks in advance.
    Sunnier likes this.
  7. May 12, 2018 at 8:03 AM
    #67
    Beerdude77
    Control center=headunit
    You'll need a sound processor to clean up the sound quality if you want to keep stock headunit
  8. May 12, 2018 at 8:19 AM
    #68
    TroyF
    TroyF New Member
    Troy
    '17 TRD Offroad
    Thanks. I think I read that there are aftermarket head units that keep a lot of the functions available. Do they maintain the large viewing screen? My eyes appreciate big font lol. Hard to believe a $60000 truck has this kind of system in it.
  9. May 12, 2018 at 10:25 AM
    #69
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    I am going 4 channel Kicker Key amp and a powered sub.
  10. May 12, 2018 at 12:35 PM
    #70
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    Drilling the factory seals is nuts. I did not want to compromise them. Get a snake, needs to be similar to a thin automotive speedometer cable, and fish the snake through with the factory bundle, without damaging the wires. Just takes patience and a little extra time.
  11. May 12, 2018 at 4:40 PM
    #71
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    What hu will adapt to the streering wheel and the options of the truck, like the original?
  12. May 12, 2018 at 4:46 PM
    #72
    B737
    Jersey Shore
    you want a HU that is compatible with iDataLink / Maestro
  13. May 12, 2018 at 8:02 PM
    #73
    Beerdude77
    What is powering your subs?
  14. May 12, 2018 at 8:20 PM
    #74
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Powered sub.
    The kind with integrated amp within the box.
    Kicker Harmony has good reviews.
  15. May 12, 2018 at 8:55 PM
    #75
    Beerdude77
    Gotcha so essentially running 2 amps so you'll need to install a distribution block.
  16. May 30, 2018 at 4:04 PM
    #76
    jmdwifi
    jmdwifi New Member
    Fredericksburg VA
    2018 Cement 5.7 Limited with offroad
    All chrome gone, pro grill, KC ditch light and bluetooth wireless controller.
    I had a Jeep Wrangler a couple cars ago. It had the alpine stock system with the subwoofer. For a stock system, it was kick ass. The head unit also had a 60 gig drive built in. I copied all the music I own on that thing. Toyota stock system is no better than the FJ I had 8 years ago. No push to start is a mo fo as well. Last truck being a taco and all. I did the OEM Audio plus in my taco and it sounded really good. I don’t know that it sounded 1500.00 good though.
  17. Sep 5, 2018 at 12:30 PM
    #77
    Ajbolo
    Ajbolo New Member
    Andrew
    2018 4x4 tundra crewman
    Did the kicker key amp work out good? Only 180w? I was thinking about getting that to power 4 jbl component door speakers. Not sure if it’s enough power though
  18. Sep 5, 2018 at 12:47 PM
    #78
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    For my listening pleasure I am completly satisfied, it won't blow your doors off, then again you aren't spending a ton of money.
    Sounds great even cranked up.
  19. Sep 6, 2018 at 6:07 PM
    #79
    Buildn
    Buildn 2022 Tundra Limited CM 6.5 Bed TRD Off Road
    Medina, Ohio
    TRD Air Filters, Front door windows tinted to match the rears. Wheel locks, Talons Garage cat shield, Tyger Automotive soft tonneau cover, WeatherTech floor mats with Tuff Skinz Custom Emblem kit, Toyota OEM Emblem Black Out kit. AVS vent covers on all four doors, Red Tundra letters on front bumper & TRD highlighted in Red on front grille. Tailgate Tundra Letters in Black.
    I have $900 bucks into my upgrade. Alpine R Series in doors with 1” tweeters. Kept stock head unit but have Alpine amp running door speakers. Pioneer 10” sub with Pioneer amp running the sub.
    TK1979 likes this.
  20. Nov 27, 2018 at 4:57 PM
    #80
    Ob1
    Ob1 New Member
    Stupid question John, but I'll ask no less. How did you wire in your KEY180.4 ? I have the same amp and I've purchased the Metra harness as well as the Sosche and no joy. There is a 12 pin plug not provided by them. Today I ordered harness #4438 from AutoHarness.com hoping that it works. Then I read that you need the male side as well. Did you have to leave the OEM amp in place and plugged in ? Or did Kicker amp replace the OEM one altogether. Also, I purchased a powered sub. How do I tap into the speaker signal to run the sub? Sorry for all the questions but any help would be greatly appreciated.
  21. Aug 29, 2022 at 12:49 PM
    #81
    DFW_SoldTacoBoughtTundra
    DFW_SoldTacoBoughtTundra New Member
    DFW
    2021 Limited 4x4
    6112s, Icon add-a-leaf pack, Icon 17s
    Truck is a '21 Limited Crewmax non-JBL
    Reviving an old thread here but seems to have a lot of relevant information in it. I'm trying to wade through all my options on how to improve the stock audio and, like many, want to retain the stock look and features. I've already installed a powered sub which has drastically improved the quality but was looking at replacing the speakers and have opened up a tangled mess of possibilities due to the configuration of the stock non-JBL system. I've got a couple directions I'm considering going but want to be sure that I don't lose any features.
    1. My first option is to replace the factory amp with a small 4 channel (at 4 ohms) amp as well as replace the 4 door speakers with upgraded 4 ohm speakers and abandon the dash speakers in place. If I abandon the dash speakers will my phone calls still come through the door speakers? Seems like a silly question but I swear I read somewhere that the phone call audio comes from the center speaker.
    2. Second option is everything in the first option except leave the dash speakers connected and probably replace them with higher quality speakers that match the factory speaker impedance.
  22. Aug 29, 2022 at 1:06 PM
    #82
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    I replaced my dash corner speakers, but that center speaker was a problem. I never found something I knew would work. If I recall, it has something odd about it like it has signal coming from two directions to be the "center". I just left it there.
    What sub config did you put in, I never actually bit that off but have subs everywhere in my house (living room, bedroom, bonus room) and am a musician/sound guy who loves clear lows!
  23. Aug 29, 2022 at 1:25 PM
    #83
    DFW
    2021 Limited 4x4
    I installed a "cheapy" powered compact sub from Crutchfield. It's a Sound Ordnance which is their in-house brand as far as I know. It fits under the driver's seat and sounds good for what it is. I'm happy with it considering what it cost. I'm kind of thinking of cutting a little section out under the rear seat to move it back there but it is fine where it is for now.
    That center speaker is a doozy. It's an 8-ohm dual voice coil with each coil in parallel (I believe) with the corner dash speakers. Not sure what to do with them, abandoning them seems like the best option as long as everything still works withouth them.
  24. Aug 29, 2022 at 5:36 PM
    #84
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I just left the dash speakers alone. They don't put out enough sound to even notice.
  25. Sep 2, 2022 at 6:55 PM
    #85
    Deacon Blues
    Deacon Blues New Member
    2018 Tundra TRD Off Road
    You can swap the corners for the tweeter of your choice and leave the center as is.
    mtucker and TK1979 like this.
