I want to replace the speakers in my Tundra....need help.
Discussion in 'Audio & Video' started by 1999cutiger, Jan 6, 2018.
  1. Jan 6, 2018 at 5:45 PM
    1999cutiger
    1999cutiger [OP] Community Organizer
    2017 Toyota Tundra SR5 4x4
    RBP 67R AK-8 20x9 wheels Nitto Ridge Grapplers 275/55/20
    I want to replace the stock speakers in my 2017 Tundra SR5.
    I don’t want to do anything more than replace the existing speakers....no amps, no HU, etc.
    I am really interested in the Toyota plug and play offerings from Focal but the Crutchfield website says they won’t fit...not sure why.
    Also, is the factory non JBL HU 2 ohms or 4 ohms?
    Suggestions for good sounding, quality speakers that are easy to drop in would be much appreciated.
    Thanks guys...
  2. Jan 6, 2018 at 7:13 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Most likely the Head Unit is 4 ohms, 2v preout.
  3. Jan 6, 2018 at 7:43 PM
    1999cutiger
    That’s what I figured also, but a customer service rep at Crutchfield told me it is 2 ohm.
  4. Jan 6, 2018 at 7:45 PM
    619Tundra
    I'm not sure, I got one too. That will be my next mod. Good luck.
  5. Jan 7, 2018 at 9:51 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Crutchfield told me the same that its 2 ohms. I had the non jbl as well.
  6. Jan 8, 2018 at 9:03 AM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    I'm looking to do the same thing. I have an '18 Crewmax. Stock system is the worst system I've heard. The highs are like an old radio with the dial slightly off accurate.
    Can you replace just the speakers? Will it help at all?
    If crutchfield says it fits, is it a sure thing it fits or could it need other components, like adapters, etc.
    The options I have are Center Dash Speaker or No Center Dash Speaker. I have both right+left dash speakers and a center dash speaker. When I select center-version on Crutchfield, it only shows me center-dash speakers. Are they the same? Ie, do I get 3 of that speaker to redo all of them?
  7. Jan 8, 2018 at 9:24 AM
    Vendeta2k
    Montana
    2018 Limited Cement CM
    replacing the speakers alone might help a bit, but it will be minimal. The main issue with the factory system is a lack of clean power.
    smslavin and MT Madman like this.
  8. Jan 8, 2018 at 9:36 AM
    trdlife
    trdlife Toyota Master Technician
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    I just did a full plug and play upgrade in my 15 PRO and it now sounds great. Upgrading just the speakers will help some, but the to really hear the difference i would recc upgrading the amp. I go rockford fostgate speakers for the front and rear doors, a 5 channel rockford amp, & the taco tunes plug and play amp harness, no cutting and no spicing to factory wiring required. I got the speakers from crutchfield and they came with wire harness adapter and door adapters and they worked great. If you dont want to add a sub, i would still recc getting a 4 channel amp with hi-level imput connectors(that way the taco tunes harness will plug in or even if it doesnt the taco tunes harness is pre-colored so you just put the wires where they go. Crutchfield carries a good selection of amps, I would just get on of the 4 channel mini amps that will be plenty of an upgrade and they fit right under the seat where the factory amp goes.
    TundraLaw, TundraMash and aperezsh like this.
  9. Jan 8, 2018 at 10:54 AM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    I guess the adapters and wire harness are why Crutchfield is 30% higher than anywhere else on the web. Were your speakers shipped with Tundra-specific adapters in the speaker's manufacturer's box with the speaker, or as an add-on that they knew to ship because of your vehicle designation?
    Cincy5 likes this.
  10. Jan 8, 2018 at 11:05 AM
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    I have a 17 CM with non JBL. I find the factory speakers to be terribly low. Most of the time I listen to Podcasts and I have to crank it up to 35-40 and still its pretty quiet.
    Best option would be to buy a 4 channel amp and upgraded door speakers?
    JASON101977 likes this.
  11. Jan 8, 2018 at 11:16 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    Yea they got added when i put them in the cart, they are the basic speaker adapters for Toyota, you can get them seperate from Amazon for about $10 a set. and the Speaker adapters were the Schoshe ones, but they were just fine. I didnt want or need anything crazy, I got front & rear speakers with adapters and harness from crutchfield for $120, and i added a shallow 10in sub behind there rear seat. Just enough to feel some bass and actually hear the vocals with out being max volume.
  12. Jan 8, 2018 at 11:48 AM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    So, didn't touch the dash speakers at all? I feel like that is where the worst quality sound is coming from.
  13. Jan 8, 2018 at 11:51 AM
    trdlife
    ICT
    2015 Tundra TRD PRO
    'TRD REX'
    No i have not yet. And the amp wont affect them either. they get their power from the headunit. but they are on the list to swap out at some point in the future. They are easy to do and pretty cheap.
  14. Jan 8, 2018 at 11:53 AM
    ARamirez73
    ARamirez73 RÖCKIN' N RÖLLIN' WITH MY TÜNDRA CRÜE
    The Lone Star State, RGV, TEXAS
    2014 CM TSS 4WD SR5 5.7 MGM
    Rough Country 6" lift / 35x12.50R20 Cooper Discoverer ST Maxx/ 20x9 +20 Fuel wheels "Mavericks" (Came with) / S&B CAI/ 2-10" Rockford Fosgates R2/ Massive Audio Nano N2 amp (Came with)/ KatSkins seat covers (Came with)/ Weathertechs window vent visors and floor mats/ 1A-AUTO.com aftermarket tow mirrors/ Undercover tonneau bed cover/ Viper alarm 3305V/ Flowmaster Super 40 Dual in-out/ 40" led light bar/ TRD Pro grille/Rough Country 30" LED light bar/TRD rear sway bar/ Ranch Hand legend grille gaurd/ Nfab nurf bars/ 2019 PRO headlights
    Tacotunes.com
  15. Jan 8, 2018 at 11:53 AM
    jna
    jna New Member
    2016 Limited
    Yes they are 2 ohm. I just made that mistake buying 4 ohm speakers that fit then having to send them back. I was looking at replacing the amp but did not want to lose the center speaker in the dash since it works great for phone calls. Now looking at a powered sub and keeping stock speakers.
  16. Jan 8, 2018 at 4:43 PM
    1999cutiger
    This is great info....and it makes perfect sense. If I can add an amp with a wiring kit that is essentially plug and play, I’ll do that. I just don’t want to tear apart my new truck to get better sound.
    trdlife likes this.
  17. Jan 8, 2018 at 4:45 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
  18. Jan 8, 2018 at 6:00 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Right now i just plan on buying the speakers with the premade tweeter sails from tacotunes should be a huge improvement with my kenwood. I hope.
  19. Jan 8, 2018 at 6:47 PM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    Same idea I have.
    I just wonder about my 3 dash speakers, they seem to be the biggest problem and all I see around the net seems to think you have 2 corner dash speakers or just one center speaker. I have three speakers in my dash, for sure.
    I'm a Tiger as well, btw. 2002 BSME
  20. Jan 8, 2018 at 7:06 PM
    Buildn
    Buildn 2017 Tundra Dbl Cab TRD 4x4
    Cleveland, Ohio
    2017 Silver SR5 TRD 4x4 Dbl Cab
    Tinted windows, AVS vent shades, 2018 Toyota LED Headlights, LED Morimoto H11 Fog lights, GTR Lighting LED brake lights & GTR Lighting LED 3rd brake / cargo light kit. TRD center caps, center console tray, Alpine speakers, Alpine amp, Pioneer amp & 10" subwoofer. TRD shift knob, TRD oil cap, TRD radiator cap, Drivers side grab handle.
    Had my system upgraded by BestBuy
    Doors: Alpine R- Series, 6 1/2 with 1” tweeter in fronts, left stock center speaker. 6 1/2 rear.
    Stock head unit: With Alpine amp swap under pass seat runs through radio.
    Under rear seat cargo box is 10” Pioneer Sub with Pioneer amp.
    Installed package $900
    BTW
    Big Ten: Ohio State
    SEC: Georgia
  21. Jan 8, 2018 at 7:24 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    How did they install the tweeters? Tacotunes has pretty much everything for plug and play
  22. Jan 8, 2018 at 7:34 PM
    Buildn
    Cleveland, Ohio
    Used the stock brackets, cut out the stock speaker and replaced it with Alpines tweeter.
    I did it myself on my 2008 Tundra
  23. Jan 8, 2018 at 7:38 PM
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    I also wanted to upgrade my sound system in my '16 SR5. I thought replacing all the door speakers and tweeters in my truck I would be able to tell a real difference in my sound quality. Unfortunately replacing just the speakers/tweeters I could not really tell that it was that much of an upgrade from my stock. I could tell the music was a little crisper but it wasn't near as loud as I thought it would have been. I installed Infinity brand speakers/tweeters in all four doors. I ordered from Crutchfield and they had everything I needed to install the speakers (wires, mounting brackets, plug-n-play wiring to the new speakers, etc.).
    I am now in the process of getting an amp, sound processor, and a couple 10 inch subs for the back seat. After doing this I'm sure my sound system will sound like I want it to and will be so much better! After all is said and done I should have a new sound system for under $1,000. I guess you all can always install your door speakers/tweeters and if it doesn't sound like you want it to you can always add components later. For me I just need to get the rest of my parts and for the weather to get warmer here so I can install everything.
  24. Jan 9, 2018 at 3:44 AM
    joem1cha3l
    joem1cha3l New Member
    Joe
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    I installed new (expensive) speakers to my new head unit and even then, I wasn't impressed. The stock amp has to go too. The Entune puts out terrible power and a shit signal.
    Save some money, install a plug and play amp from Tech12Volt, a new HU and some speakers. Do it once and do it right.
    B737, TundraMash and SuaveRC like this.
  25. Jan 9, 2018 at 5:01 AM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    I think this says it all. I have to just go for it. Never done a car stereo upgrade but I've rewired 2 boats completely, including stereo, autopilot, multiple sounders/nav systems. The only thing that makes me nervous is removing the seat and running battery cable to support the amp.
  26. Jan 9, 2018 at 2:24 PM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    Does anyone know where I can get a schematic of the 2018 CrewMax non-JBL system (w/center speaker if that matters)?
  27. Jan 9, 2018 at 2:46 PM
    joem1cha3l
    Joe
    Albany, NY
    You sure that yours has a center speaker?
  28. Jan 9, 2018 at 6:23 PM
    btodag
    btodag New Member
    BG
    2018 Tundra Limited
    Yes, and corner speakers. Why do you doubt it?
  29. Jan 9, 2018 at 7:58 PM
    Riskyguy
    Riskyguy New Member
    Stewart
    2008 Tundra SR5 DC
    Running the amp wiring is really pretty easy once you get into it. There is nothing too difficult with installing a new system. Just take your time and you will get great results.
    B737 likes this.
  30. Jan 10, 2018 at 2:58 AM
    joem1cha3l
    Joe
    Albany, NY
    Because many of the trucks have a center speaker grill that looks like there’s one but when you open it up, there’s actually no speaker in there.
    Les7311 likes this.
