I want 110 volts in the bed
Discussion in 'Lighting' started by Eclipsed & Floating, Sep 24, 2017.
  1. Sep 25, 2017 at 12:12 PM
    #121
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Only when i can do your makeup
  2. Sep 25, 2017 at 12:13 PM
    #122
    Eclipsed & Floating
    Eclipsed & Floating [OP] Over it.........
    I’m right where I need to be
    Voluptuous Whitey
    Been done before....anything to keep the tent warm
  3. Sep 25, 2017 at 12:13 PM
    #123
    4x4_Angel
    Bree
    Funky Town, Texas
    Its over rated
  4. Sep 25, 2017 at 12:14 PM
    #124
    4x4_Angel
    Bree
    Funky Town, Texas
    I'll go camping with you....but not share a tent
  5. Sep 25, 2017 at 12:31 PM
    #125
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    not much more evil than freezing rain :notsure:
  6. Sep 25, 2017 at 12:32 PM
    #126
    4x4_Angel
    Bree
    Funky Town, Texas
    mmmhmmm....i would not be sleeping wuth your farts....
  7. Sep 25, 2017 at 12:34 PM
    #127
    ramonortiz55
    Ramon
    Just don't smell them. Keep the covers down, don't tuck your head under the covers. As long as those rules are followed, you wont get a whiff of it.
  8. Sep 25, 2017 at 12:34 PM
    #128
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    Vasoline, hamsters and farts. Oh my.
  9. Sep 25, 2017 at 12:43 PM
    #129
    4x4_Angel
    Bree
    Funky Town, Texas
    no you just smell like it in the morning....I'm good
  10. Sep 25, 2017 at 12:49 PM
    #130
    ramonortiz55
    Ramon
  11. Sep 25, 2017 at 10:00 PM
    #131
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    As I mentioned earlier, this is something I've spent a lot of time thinking about. Hopefully, I can put it into words while being coherent at the same time. Sometimes that's difficult for me.
    With the FJ, I had rolled my own dual battery setup. I didn't like it probably because I didn't do something right due to my many village idiot moments. I want to fix those screw ups this time around and extend it to how I want to use the truck.
    I need spots in the rear of the truck for running a fridge and charging everything from battery packs to laptops. I want to do those things from a second battery. I want to recharge that battery via solar. I've decided to spring for the IBS system. This would be the wiring diagram. The solar is an add-on and not necessary for the IBS system to work. Second battery will trickle charge from the main when the vehicle is running.
    I've gotten mixed responses from my questions about inverters. Most of the answers revolve around not using one. The biggest issue being that the draw from the inverter will far outpace the recharging capabilities of a 400w solar system. Inverters are incredibly inefficient devices. Hence the reason that Toyota requires the vehicle to be running in order to use the factory inverters.
    There are 12v heaters and electric blankets available. I think you are better off skipping the inverter. I will be.
    My plan right now is to build some kind of rack in the bed. I'll put it up against the front of the bed, mounted to the Decked platform. This will have a cover to hold the second battery and a fuse block. The Decked platform has covered cubby holes in the corners. I will be mounting Blue Sea 12v sockets into these. Spot to plug the fridge in. Then I need to figure out the 12v chargers for laptop and battery packs.
  12. Sep 26, 2017 at 5:39 AM
    #132
    Eclipsed & Floating
    Voluptuous Whitey
    I think it sounds like a great plan. I would love to help you build it.
    I'm pretty sure I'm going to skip the inverter after reading more abut the capabilities. Going with a portable mini ultra quiet generator that will be universally functonal on many fronts. I will have lots of uses and don't want to be he'd to operation only near my truck, especially if I don't keep it
    ColoradoTJ and smslavin[QUOTED] like this.
  13. Sep 28, 2017 at 9:31 PM
    #133
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    I stand corrected good sir.
