I can’t stand our instrument cluster
Discussion in '2nd Gen Tundras (2007-2013)' started by Scuba, Aug 17, 2019.
  1. Feb 29, 2024 at 4:48 PM
    #61
    dangeloc
    dangeloc New Member
    Which display button are you meaning ?the info button ?
  2. Mar 1, 2024 at 2:01 PM
    #62
    07 Tundie
    07 Tundie Shadowfax
    SC
    2007 DC 4.7L 4x2 SR5 Super White
    My bad, the "SELECT/RESET" button.
  3. Mar 1, 2024 at 4:25 PM
    #63
    ACDC2ZZTop
    ACDC2ZZTop Rock n Roll!
    Travis
    Oregon
    2012 MGM Tundra double cab 5.7L V8
    All cosmetic so far see my posts in 2nd gen Black out chrome in progress….
    :(Yeah not a fan of the orange but new shoes take priority
  4. Mar 1, 2024 at 4:38 PM
    #64
    JohnWhicker
    JohnWhicker New Member
    I mean who really looks at the cluster :) I don't
    Hilandr likes this.
  5. Mar 1, 2024 at 5:31 PM
    #65
    Yota0556
    Yota0556 New Member
    2012 Tundra
    i feel like this is the best you can get the 2nd gen to, and is 10000x better than the orange ones
  6. Mar 1, 2024 at 6:09 PM
    #66
    SouthWestGA
    SouthWestGA New Member
    I have an Optitron cluster hanging around i need to find a new home for
  7. Mar 2, 2024 at 10:09 AM
    #67
    YotaFan05
    YotaFan05 New Member
    NE OH
    2011 Tundra Crewmax
    What options are available for the flex fuel models? Just swapping LEDs? It doesn't look like the Optitron is compatible.
  8. Mar 6, 2024 at 10:18 AM
    #68
    dangeloc
    dangeloc New Member
    I have a 2011 FF and the opitron works other than for some reason my DTE, Average mileage, and instant fuel mileage are not reading.
  9. Mar 6, 2024 at 4:32 PM
    #69
    ZeRussian
    ZeRussian New Member
    ‘11 CrewMax
    Same year FF but my all of those work for me.
  10. Mar 6, 2024 at 5:03 PM
    #70
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    Really shouldn’t be mixing Flex Fuel clusters and non flex fuel trucks. Gas gauge range of operation is different.
    Network messaging for Range, Instant and Avg Fuel Economy is probably different.
    The cluster reads in the fuel injector pulse timing to determine fuel usage, it calculates fuel economy and range based off this and fuel remaining in tank.
    If you truck is FF you need a FF cluster, if its no flex fuel you need a non flex cluster. You can’t mix and match.
    Wynnded likes this.
  11. Mar 6, 2024 at 5:43 PM
    #71
    dangeloc
    dangeloc New Member
    you are accurate for certain years. But 2011 they used the same part numbers for FF and non ff. So your statement is accurate depending on the years.
  12. Mar 6, 2024 at 5:44 PM
    #72
    dangeloc
    dangeloc New Member
    Yeah I think it is something just wrong with the cluster. The tanin guys are looking into it for me.
  13. Mar 6, 2024 at 6:10 PM
    #73
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    According to TIS the changes took place 2012.
    However, I have extensively worked with the clusters in these trucks and I am telling you it’s a bad idea to mix any of them up.
    Crazy as it sounds but part numbers the same doesn’t mean EEPROM and firmware files match identically.
    Trucks needs to see fuel injector message from ECM and Rpm message from ECM. With both of those it should be showing and calculating fuel info.
    https://www.tundras.com/threads/2nd-gen-cluster.101993/page-5#post-2662986
    I have not dove deeply into a flex engine ecu but a very good chance it sends the fuel injector info out on a different address in the can bus.
    The flex cluster could be looking for the fuel data message in the wrong spot. The flex ecu sends it on one address, the non flex on a different address.
    I am assuming you have mixed then by the way, I don’t know that for sure.
    Wynnded likes this.
  14. Mar 6, 2024 at 6:58 PM
    #74
    dangeloc
    dangeloc New Member
    hmmm interesting. Thanks for that info I may just have to keep the ugly orange one then. Dang it!
