I’ve got a weird issue, am I the only one?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ghill26047, Feb 5, 2023.
  1. Feb 5, 2023 at 10:37 AM
    ghill26047
    ghill26047 [OP] New Member
    Geoff Hill
    2017 Tundra TSS
    I’ve got an issue that I have no idea how to fix, and I’ve also taken it to multiple techs that can’t diagnose the issue either. I’ve got the 5.7L.
    Basically when I’m accelerating there’s something that’s making the motor run rough, kind of jerky and there’s a pulse in the rpms. I feel like it’s getting really bad fuel mileage to. I have the large fuel tank and I’m barely getting 400 miles out of it.
    I’ve replaced the MAF and TPS sensors. One of the techs changed the transmission fluid and said he didn’t see any irregularities in it (what ever that means).
    My wife has the same truck and hers drives just fine so I know I’m not trippin lol.
    Anyone have the same issue of herd of anything like this?
  2. Feb 5, 2023 at 10:45 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    No codes? Maybe you need a software or pcm reflash? Do you hear or feel anything mechanical?
  3. Feb 5, 2023 at 11:10 AM
    MadMaxCanon
    Maybe pcv valve is clogged. Cheap 8 dollar fix
    DondeContente likes this.
  4. Feb 5, 2023 at 11:12 AM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    Getting 400 miles to the tank isn’t terribly accurate. You need to calculate mpg. I almost never run my tank below half. But when I did I was surprised how much fuel I had left when the fuel light came on. But I only get like 12-13mpg which would be 456 miles per tank if lucky.
    bad fuel or water in fuel could cause pinging. Which is sort of a weird sensation. Computer should be able to compensate. But stranger things have happened.
  5. Feb 5, 2023 at 11:28 AM
    ghill26047
    Geoff Hill
    2017 Tundra TSS
    I’ve ran a bunch of injector cleaner through it.
    it’s got 100K on it but it’s been doing this for a while now.
    I’ve had one check engine light and it was for the MAF so I replaced it with an oem.
    I’ve unhooked the battery a lot for wiring lights and what not. Even replaced the battery a few months ago.
    I’ll check the pcv.
    When I first bought the truck I drove it between Austin and Pittsburgh a few times and I was getting about 560 miles to a tank. yeah it’s all highway but most of my driving is highway anyway.
  6. Feb 5, 2023 at 11:30 AM
    ghill26047
    Geoff Hill
    2017 Tundra TSS
    My philosophy is usually keep driving until something breaks, then there’s no need to guess what the problem it haha. but it’s been doing this for about 50-60K miles and nothing had broken yet lol.
  7. Feb 5, 2023 at 11:33 AM
    Flex fuel?
    When there's hesitation under acceleration it makes me think fuel rail pressure.
    Has anyone put a data recorder on to capture what might be going on?
    Terndrerrr, JLS in WA and HulkSmurf14 like this.
  8. Feb 5, 2023 at 11:44 AM
    MadMaxCanon
    Maybe do spark plugs too
  9. Feb 5, 2023 at 12:10 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    Certainly wouldn’t hurt, but wouldn’t an extreme issue like he’s describing throw a cylinder misfire code?
  10. Feb 5, 2023 at 12:48 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Not necessarily
    JLS in WA[QUOTED] likes this.
  11. Feb 5, 2023 at 1:29 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    My truck did this when I had a defective igniter coil. They don’t alway throw codes initially when failing. Be sure to only use Denso or OEM Toyota coils.
    clarkritchie and JLS in WA like this.
  12. Feb 5, 2023 at 2:17 PM
    MadMaxCanon
    You would think but sometime it has to be really severe. Not sure why.
  13. Feb 6, 2023 at 5:54 AM
    blanchard7684
    blanchard7684 New Member
    The list of things that can cause “fish bite” acceleration is very long.
    codes help shorten this.
  14. Feb 6, 2023 at 7:46 AM
    seydou
    seydou Distinguished Member
    ? Disconnecting a battery starts with disconnecting the negative cable first.
  15. Feb 6, 2023 at 8:14 AM
    2mchfun
    EZ fix...pull the ignition fuse out of your wife's truck. After she experiences a no start and you "fix" it, explain to her that it would be best for you and her to swap trucks.:thumbsup:
  16. Mar 1, 2023 at 9:24 AM
    hammockking
    hammockking New Member
    Scotts Valley, Ca
    2012 Tundra Platinum 4x4
    Workin' on em
  17. Mar 1, 2023 at 11:44 AM
    hammockking
    Scotts Valley, Ca
    Workin' on em
    Found this thread that seems to cover the issue we both seem to be having. Will try topping off the tank and resetting the ECU before moving to replace parts. But based on the descriptions, fairly confident about the next steps. -
    https://www.tundras.com/threads/surging-during-light-to-moderate-acceleration.37175/page-5
    Thread about resetting ECU before parts were replaced - https://www.tundras.com/threads/rough-cold-start.36837/page-3
