Hypertech interceptor review
Discussion in 'Performance and Tuning' started by davesnothere, Aug 16, 2016.
  1. Oct 29, 2016 at 6:25 PM
    #151
    Quartermeter
    Quartermeter New Member
    James
    Alabama
    2014 SR5 DC WHITE
    FOX 2.0 REARS, OME FRONTS FIRESTONE AIR BAGS RCI SKID PLATE
    Keith at Dirtydeeds has them for $320 shipped, Keith 760-877-4234
    I'll get one there. That way I'll have some CS. Hope they have the bugs worked out by now. Per the website they really change the power curve on the tundra + give xtra hp.
  2. Feb 21, 2017 at 8:28 AM
    #152
    scturndra
    scturndra New Member
    wall
    2012 tundra extra cab sr5 4.6v8
    any updates on these?
  3. Feb 21, 2017 at 8:36 AM
    #153
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    I have to say, I installed mine finally about a month or so back...my driving style I dont feel an increase in power (yet) BUT I have seen a pickup in MPG.
    Driving style the same, driving profile and route the same, ambient conditions are similar, HVAC settings unchanged...etc
    I will be keeping this thing installed, I am so far a happy customer. We shall see though what the future brings.
  4. Feb 21, 2017 at 8:42 AM
    #154
    scturndra
    wall
    how much did your MPG's increase?
    I have a 2012 tundra SR5 4.6. sitting on 275's. Before the 275's sitting on 255's I was getting about 16 in the city and 21 on the high way. now I am getting about 14 in the city and 15-16 on the highway(must of the time I am towing my 4 wheeler while on the highway)
  5. Feb 21, 2017 at 8:53 AM
    #155
    14burrito
    2014 SR5 CM 4x4 5.7
    Little history to this will help get a better idea,
    While back when I first got the truck I was getting about 17-18 mpg... realized the tires were wearing like garbage. Pressures adjusted to allow proper tire wear, 14-15mpg.
    Come to recently/present day I continued to maintain 14-15mpg average (always hand calculated for verification).
    The last battery reset was maybe 4 months ago, average on the IP read 14.6mpg. Now coming back to when I installed the Hypertech - I did NOT perform a battery reset so my IP started at my nominal 14.6mpg. Present day, IP is reading 16.4mpg. It has over the period of time slowly risen to its current reading. I see the increase in MPG at ever fill up when calculating by hand. I also see myself driving a little longer between fueling. I was previously fueling at about 300 miles on the tank, I'm now fueling around 330ish.
    I have read people say that once the ECM adjusts to the tuner, MPGs go back down. So time will tell if the increase I see will stay or go.
  6. Feb 21, 2017 at 9:15 AM
    #156
    Quartermeter
    James
    Alabama
    2014 SR5 DC WHITE
    14b did you go online and update it or reprogram your unit?? Just curious
  7. Feb 21, 2017 at 9:20 AM
    #157
    14burrito
    2014 SR5 CM 4x4 5.7
    No Sir,
    Bought it used from a Gentleman that used it for 3 months. He installed it out of the box, never had it updated. I installed it as he sold it to me.
  8. Feb 21, 2017 at 9:24 AM
    #158
    scturndra
    wall
    has it thrown any codes? do you have the tow haul package?
  9. Feb 21, 2017 at 9:28 AM
    #159
    14burrito
    2014 SR5 CM 4x4 5.7
    I have tow haul package, I have yet to tow though. Looking to be maybe a month or so before I will be towing anything. I have driven around town with Tow/Haul activated with no issues.
    I have already done an "elevation change test". I did not receive a CEL during this, but I have not checked fault codes to see if anything had popped up in the background.
  10. Feb 21, 2017 at 9:30 AM
    #160
    scturndra
    wall
    when will you check for fault codes? how do you do that?
  11. Feb 21, 2017 at 9:34 AM
    #161
    14burrito
    2014 SR5 CM 4x4 5.7
    Usually dont make it a habit of checking without having a reason, but I guess this might be a reason to do so.
    Easy, just hook up a scanner.
    I guess ill work on this, take a quick peak and post up if anything registered in the background. Might take me a few days.
  12. Feb 21, 2017 at 9:35 AM
    #162
    scturndra
    wall
    cool, thank you ... I am interested in hearing what you find out.
  13. Feb 21, 2017 at 12:00 PM
    #163
    Harris1881
    Harris1881 New Member
    Oregon
    15' black CM SR5
    I still have it in my truck. I usually only get the cel light when towing, but have got it a couple times when pulling a grade.
  14. Feb 21, 2017 at 12:53 PM
    #164
    scturndra
    wall
    harris but you still like it? what improvements have you noticed with it?
  15. Feb 21, 2017 at 1:08 PM
    #165
    Harris1881
    Oregon
    15' black CM SR5
    Well I haven't removed it. I don't really see any big gains anywhere, but most gains hp/tq wise aren't going to be felt unless your adding a supercharger. Mpg I didn't see any change. I do recommend it as the cheapest way to go.
  16. Feb 21, 2017 at 5:57 PM
    #166
    14burrito
    2014 SR5 CM 4x4 5.7
    No registered code so far
  17. Feb 23, 2017 at 5:25 AM
    #167
    14burrito
    2014 SR5 CM 4x4 5.7
    405miles driven, fueled 24.2gal = 16.7mpg
    I hauled a few hundred pounds for maybe 60 70 miles. Also did some "mudding" after the beautiful rain we got here in Arizona, still carrying half of it around on the underneath of the truck that I still need to wash off and in the wheel causing me to get a free massage on my way to work. Also there's maybe about half hour worth of isollated idle time in order to try to figure out an issue that was happening with the truck.
    Forgot to mention the wife drove the truck for about a hundred miles... who knows what she did with it.
  18. Feb 23, 2017 at 7:49 AM
    #168
    scturndra
    wall
    do the messages have anything to do with hypertech?
  19. Feb 23, 2017 at 7:53 AM
    #169
    14burrito
    2014 SR5 CM 4x4 5.7
    Massage - not message.
    I'm getting a free massage.
  20. Feb 23, 2017 at 9:18 AM
    #170
    scturndra
    wall
    do you have an aftermarket Cold air intake.
  21. Feb 23, 2017 at 9:22 AM
    #171
    14burrito
    2014 SR5 CM 4x4 5.7
    No, just a drop in AFE pro dry S.
    Hypertech has updates for most aftermarket intakes. Most aftermarket are not true CAI as they draw air from under the hood. Factory setup is a true CAI.
    650h1 likes this.
  22. Feb 23, 2017 at 9:24 AM
    #172
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    I sold mine, didn't feel any gains after a while, and think the truck actually started driving better after I took it out. FWIW...
  23. Feb 23, 2017 at 9:24 AM
    #173
    scturndra
    wall
    I have a drop in K and M filter right now and I saw a big difference when I changed out the factory for this. I gained acceleration and 2 mpgs.
    I really am leaning on getting the hypertech. looks really simple to install
  24. Feb 23, 2017 at 1:49 PM
    #174
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Bought my rig in Oct 16, HT was the first mod a week later. No issues. All stock, for now, with a K/N drop in. No lights. Fun to drive. Avg 17.3 mpg overall since the purchase. Just sayin'
  25. Feb 23, 2017 at 2:09 PM
    #175
    14burrito
    2014 SR5 CM 4x4 5.7
    Looks like BD tuners throwing the same MAF codes...
  26. Mar 4, 2017 at 7:55 PM
    #176
    bsavoir
    bsavoir New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    Hmm...I had my bullydog installed 2 years ago and haven't seen any issues.
  27. Mar 4, 2017 at 8:14 PM
    #177
    14burrito
    2014 SR5 CM 4x4 5.7
    Have yet to get it on my Hypertech.
  28. Mar 4, 2017 at 8:51 PM
    #178
    SwampTundra
    SwampTundra New Member
    Macky
    Sorrento, La.
    2017 Tundra Crewmax Limited 5.7 FFV
    K&N CAI, Husky Liners (So Far)
    I want a hypertech as well. I have a 2017 5.7ffv CM Limited and I guess they don't make one yet for the 17's???? Thanks
  29. Mar 10, 2017 at 8:07 AM
    #179
    scturndra
    wall
  30. Mar 10, 2017 at 8:12 AM
    #180
    14burrito
    2014 SR5 CM 4x4 5.7
    Only update is I am happy so far with the unit. Finally got to get into the throttle a bit, accel was smooth and no warning lights on the dash. Not sure if it was like this before or not, but it seemed to hang at red line for a second before deciding to upshift.
    Next is putting my "modded" airbox top section back on. I removed it to test the unit initially with nothing but the Hypertech itself. Then I popped in the AFE and drove around for a while and now is the last piece of putting the top section back on. The "modified" part is I remove the charcoal screen.
