Hypertech interceptor review
Discussion in 'Performance and Tuning' started by davesnothere, Aug 16, 2016.
  1. Sep 8, 2016 at 10:12 AM
    #91
    scturndra
    scturndra New Member
    wall
    2012 tundra extra cab sr5 4.6v8
    Harris do you have an update on the hypertech?
  2. Sep 8, 2016 at 10:33 AM
    #92
    Harris1881
    Harris1881 New Member
    Oregon
    15' black CM SR5
    I ended up not camping last weekend so I didn't get the chance to tow the trailer. I'm still driving it as hard as I can on roads around town and still no cel. I should have time this weekend to really push it and see if it comes on.
  3. Sep 9, 2016 at 2:47 PM
    #93
    Harris1881
    Oregon
    15' black CM SR5
    Would the software recognize that it was plugged into the computer? When I first plugged mine in it would even show up as being plugged in. I just kept trying and it finally worked.
  4. Sep 9, 2016 at 3:05 PM
    #94
    07tacoswb
    07tacoswb New Member
    2016 Super White Tundra Crewmax XSP-X
    It would show up in the device manager. Even the update software recognized it but it wouldn't update. Failed every time. Tried three different computers. I was on the phone with hypertech for 45 minutes. Then the guy told me the code meant it was defective and needed to be replaced.
  5. Sep 9, 2016 at 4:01 PM
    #95
    Harris1881
    Oregon
    15' black CM SR5
    Sorry man that really sucks. Good luck with it.
  6. Sep 9, 2016 at 4:06 PM
    #96
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    That's crazy... I don't know him personally, but just being a vendor here and based on his reputation, I'm sure it wasn't defective when he took it off his truck. I wonder if you sent it back to him, he could have them warranty it and send you the warrantied one.
    Not that you did anything to it. Just making the case that he wouldn't do you wrong.
    Harris1881 likes this.
  7. Sep 10, 2016 at 5:09 AM
    #97
    David P
    David P New Member
    David
    Alabama
    2016 Toyota Tundra 4x4 CM Platinum
    BDS 7" lift with Fox coil overs and 2.5s in the rear, CB shackles w/ poly bushings, CB steering kit, CB poly rack bushings, Dakar rear leaf pack w/ CB poly bushings, Bushwacker paint to match fender flares,, Fab Fours premium bumpers font + rear, Fab Fours modular roof rack with lights all around, ARE Z series shell, BDS Traction control bars, Fuel Nutz 2 piece 22x10 wheels, Toyo MT 37X13.5, Spod overhead lighting control unit, Kenwood/JL Audio, Dynamat sound deadening throughout the cab, Morimoto 40" LED light bar hood bulge, Viper remote start alarm, Bully Dog tuner, S+B CAI, Retro'd HID Headlights, Morimoto 2-Stroke LED Fogs, Undercover tool boxes.
    I've had the hyper tech on my '16 - 5.7 - 4x4 Tundra for several month. I started off with a light lift, 3/2 and 285s then went to a 5 inch lift with 35x12.50s and now I am at 7 1/2 with 37x13.50 on 10 inch wheels - added the hyper tech inline speedo calibrator which has also helped with the transmission shift points. Honestly, I cannot really feel a big enough difference in any power loss due to the extra sized tires and weight which has to be attributed to the hyper tech products on my truck. FYI, also have the pedal module in place; I've adjusted to it as it does feel like it requires a little more pressure needing to applied to the pedal but I feel that it smooths the acceleration out and really works to keep the RPMS at or under the 2k mark which I would assume would help with MPGs as if that is really a reasonable factor when you go with 37s. Overall, I think it helps even at a modest level but apparently enough to offset added weight and rotational force to the truck.
  8. Sep 10, 2016 at 5:42 AM
    #98
    Harris1881
    Oregon
    15' black CM SR5
    Have you had the check engine light come on at all?
  9. Sep 10, 2016 at 6:35 AM
    #99
    David P
    David P New Member
    David
    Alabama
    I did one time and it was due to a bent pin in the connector at the air intake. I called Hypertech and they sent me a replacement unit and haven't had a single issue since. I take it all off every time I go to the dealer for routine service intervals, I'm now at 10k miles then put it all back on after with no issues.
  10. Sep 12, 2016 at 7:11 AM
    #100
    davesnothere
    davesnothere [OP] New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    Quick update after my first trip to coast with TT. I ran about 65 the whole way down, about 150 miles, with rpm at 3k the whole time. At some times I'd hit 4k rpm on hills. No CEL light. So until it comes back on, if it does at all, I have concluded my review.
  11. Sep 12, 2016 at 7:56 AM
    #101
    07tacoswb
    That's awesome news. I'll have to save again for a while and get a new one. I'm looking forward to getting one on my truck. Thanks for the keeping us updated.
  12. Sep 14, 2016 at 3:33 PM
    #102
    650h1
    650h1 New Member
    2013 Rock Warrior C/M
    Did you put the pedal sensor in or just go back to stock intake to fix cel issue?
    What is the difference with the pedal sensor? Does it make it less powerful?
  13. Sep 14, 2016 at 11:34 PM
    #103
    TruckyTruck
    Gary
    The pedal sensor makes the throttle less sensitive. It really shines when you aren't towing. When you are cruising on the highway and give it a little gas, normally the torque converter will unlock, using a little more fuel. But since the throttle is less sensitive, it helps you to give just enough pedal to get you a little more speed, or not lose speed on a climb, without the converter unlocking. All of that to say, a tad more mpg. You can certainly do it without the sensor though... You just need to be easy on the throttle. I took the pedal sensor off when I ran the HT. When you tow, in my opinion, it doesn't help.
    650h1[QUOTED] likes this.
  14. Sep 15, 2016 at 5:55 AM
    #104
    650h1
    650h1 New Member
    But is the pedal sensor what fixed the cel or is the stock intake?
  15. Sep 15, 2016 at 8:19 AM
    #105
    TruckyTruck
    Gary
    Well I hat to speak for the guy, but the pedal sensor won't have any bearing on the cel. When I had the HT, I ran it for a little while with an afe drop in filter and got the cel. When I replaced the filter with a stock one, I didn't get the error. If you have any modification to the air box or a cat back that flows better than stock, you will end up with a cel periodically. But from my experience, it's any change to the stock air box that does it.
  16. Sep 15, 2016 at 8:27 AM
    #106
    davesnothere
    Dave
    Down South, Texas
    I did not put pedal thing on as I like the quick get up, gas is cheap in Texas. I just swapped out k and n back to stock. Still enojoyin it, and still no light or any warnings on ultra gauge.
  17. Sep 15, 2016 at 8:56 AM
    #107
    scturndra
    wall
    dave so you like it better then the unchip? can you really feel and difference?
  18. Sep 15, 2016 at 9:02 AM
    #108
    davesnothere
    Dave
    Down South, Texas
    Yes and yes, just get one though Amazon and that way if you don't like it you just return it no questions asked, keep original packaging. I could tell you all day, and have in previous posts, I like it but it's gonna be one of those things you have to see for yourself. And results may vary as I have a 5.7 and diff setup.
  19. Sep 15, 2016 at 9:13 AM
    #109
    scturndra
    wall
    I read some where that when you hook it to your pc, that you can pick which air intake you have. Just wondering why the stock intake would be better then the CAI.
  20. Sep 15, 2016 at 9:14 AM
    #110
    650h1
    650h1 New Member
    I also read that even you use the stock intake, you should pick a different one when you plug it in as it gets better power... is this true?
  21. Sep 15, 2016 at 9:59 AM
    #111
    davesnothere
    Dave
    Down South, Texas
    The stock is a CAI, and the best one for our engine. We have a Toyota, one of the best engines in the world, and more expensive than the body. Why wouldnt Toyota put in a k and n or a s and b if they were better? If it was a ford or somethin I would do it as it worked well in my mustang gt. Also I sold my k and n, do you think I did it cause it was better than stock?
    Don't know about choosing a diff intake
    650h1 likes this.
  22. Sep 15, 2016 at 4:55 PM
    #112
    650h1
    650h1 New Member
    Dave, I just ordered one of these, any tips for the set up and install?
  23. Sep 15, 2016 at 6:49 PM
    #113
    davesnothere
    Dave
    Down South, Texas
    Nope, it's pretty straight forward. Plug and play. There's a couple vids online for Toyota install.
  24. Sep 15, 2016 at 7:26 PM
    #114
    TruckyTruck
    Gary
    Just plug it right into the flux capacitor...
    Marty McFly and 650h1[QUOTED] like this.
  25. Sep 15, 2016 at 11:26 PM
    #115
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Has anyone used the Interceptor with their supercharger?
  26. Sep 16, 2016 at 2:06 AM
    #116
    TruckyTruck
    Gary
    From what I read, it's a big no no. It will lean a SC truck out to the point where it's only a matter of time.
  27. Sep 16, 2016 at 6:32 AM
    #117
    davesnothere
    Dave
    Down South, Texas
    Unichip is what is used I believe for s/c
  28. Sep 18, 2016 at 6:22 AM
    #118
    650h1
    650h1 New Member
    welp, bought one of these, downloaded the tuner software, plugged it in, it started going through the update and fuck me. Error 0x040A - couldnt contact update server. have tried it a bunch of times, get the same thing. Why are these things such huge pieces of shit?
  29. Sep 18, 2016 at 7:15 AM
    #119
    davesnothere
    Dave
    Down South, Texas
    I'm sure you didn't but I have to ask, did you plug in tuner before it said too? I think someone else had same problem also with that code. Damn the bad luck
  30. Sep 18, 2016 at 7:17 AM
    #120
    650h1
    650h1 New Member
    No, I just downloaded the application, ran it, and thats what happened.
