How to improve gas mileage
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bruiser47, Feb 11, 2021.
  1. Feb 25, 2022 at 7:07 AM
    #181
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    As an example: I recently followed a friend on his Ural motorcycle. That bike can only go about 60 max. So I set the cruise for 55 on a long flat stretch of road for about 50 miles and got 20 mpg. If I keep it under 70 I'll get 17 on the highway, over 80 it drops quickly. Thats with a soft tonneau and 20" aggressive mud/snow tires.
  2. Feb 25, 2022 at 8:36 PM
    #182
    Buildingdoc
    Buildingdoc New Member
    So... I was running about 12-13 loaded with tools and gear. Put 35s on... got worse. Then I went to a 5.29 rear-end. Went up about 2-3 mpg. Then did a 38 gallon tank for the range. Stopped carrying as much weight. Getting about 18 MPG now and I'm really happy.
    HulkSmurf14 likes this.
  3. Feb 26, 2022 at 4:15 AM
    #183
    Mobeyk
    Mobeyk New Member
    Oshawa Ontario Canada
    2012 Tundra TRD pro, 2018 SR5
    Vland headlights, LED fogs, Rough country lower bumper LED bar, third light switch to LED, ICL ceramic coating, hood fender
    My truck is a tool. Do I want a fancy tool that feels good using it? Heck ya. Do I mind it costing a bit more than another tool and is more reliable, certainly not. Mine does add up as my advertising billboard, my office and my workshop. If I can't pay the gas its like I can't pay for rent, office supplies or ads. IMG_0274.jpg
    GODZILLA, hANNAbONE and HulkSmurf14 like this.
  4. Feb 26, 2022 at 5:59 AM
    #184
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    If paying for fuel is a problem, there are much bigger problems at hand.
    GODZILLA and Chip_Tundra like this.
  5. Feb 26, 2022 at 6:36 PM
    #185
    04rktaco
    04rktaco New Member
    Lee
    California City
    2014 SR5 TRD crewmax 4x4
    All-pro rocksliders RCI aluminum skidplates TRD pro suspension TRD pro exhaust coachman 1inch lift shackles cooper tires
    My KLR gets me the best mileage out of my Tundra just not when it’s cold
    GODZILLA likes this.
  6. Feb 26, 2022 at 6:55 PM
    #186
    Otaku4life69
    Otaku4life69 Welcome to the Dark Side.
    David
    Bay Area CA
    2017 Black SR5 CM
    Pro Comp 7" lift, King Shocks. Moto Metal 961's, 37" Pro Comp Xtreme MT2's, Custom Leather seats, Corsa Exhaust
    The forum members that know me know that I bought the showroom slut with all the balloons on it. It was a dealership build that came with a 7" lift and 37" tires on 20's. On the very first drive I knew the gears would need to be changed to go with 37" tires. After I had the new gears installed, I saw a 2 MPG increase. Not only will the correct gears for tire size save the tranny, but it will also improve the MPG.
  7. Feb 27, 2022 at 7:31 AM
    #187
    2014 Black tundra
    2014 Black tundra New Member
    2014 tundra sr5
    I put a throttle body spacer and cold air intake in my stock 2014. I gained about 1.5 more gas mileage. I added a 3.5 RC lift and new wheels and 295/70R18 tires. And lost about 2 to 3 mpg. So, I’m in the negative. I’m told re-gearing will bring me back to where it was. But I’m not doing that yet. Maybe I will if I put on 37s.
  8. Mar 1, 2022 at 7:38 PM
    #188
    critchton
    critchton New Member
    4 toyotas owned
    If you put on bigger tires, your speedometer may read slower than actual speed. (Ex: 45mph reading at 50mph actual) Seems the odometer might read fewer miles traveled as the larger diameter tires have a longer revolution. These factors may skew accurate MPG calculations.
  9. Mar 6, 2022 at 7:58 AM
    #189
    chuckfinley
    chuckfinley New Member
    2021 LR Tundra TRD Pro
    2021 LR Sequoia TRD Pro
    18.3 yesterday on highway some tailwind involved.
  10. Mar 6, 2022 at 12:10 PM
    #190
    Rw429
    Rw429 New Member
    Rob
    2017 Black Toyota Tundra SR5 Crewmax TRD Off Road
    Man, the best mpg I can get is 15 and I have completely stock set up with no mods. I guess it’s probably due to mostly driving through stop lights and in town, 80% of the time. Oh well, I still would not trade my 5.7 for an ecoboost engine. Been there prior and not a fan of the issues with Ford.
  11. Mar 6, 2022 at 12:28 PM
    #191
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    A 7 foot lift? Impressive! How do you get in it?
  12. Mar 6, 2022 at 2:05 PM
    #192
    Saltyhero13
    Saltyhero13 Throbbing Member
    HulkSmurf14, Kung and WBW[QUOTED] like this.
  13. Mar 6, 2022 at 2:53 PM
    #193
    Kung
    KG, VA
    WBW and Saltyhero13[QUOTED] like this.
