How to fit 285/70 R18 on stock?
Discussion in 'Wheels & Tires' started by roy2015, Oct 30, 2019.
  1. Nov 30, 2019 at 3:16 PM
    Kurdt
    Kurdt New Member
    Austin TX
    2019 Cement CrewMax TRD OR
    Correct, the bumper caps were chrome and I had those powder coated. Also did that with the stock TRD OR wheels.
    I bought the hood bulge in Cement color from @Roman at Toyota of Cool Springs. Unfortunately you cannot buy the surround separately from the grill, so I had to buy the Cement color assembly for a 2017 TRD Pro. Which reminds me, I still need to sell the TRD Pro grille insert. The color was perfect, and an easy install other than swapping the grill insert out.
    Good luck with the de-chroming...it was the first thing I did with mine before moving on to other things.
    Roman likes this.
  2. Dec 1, 2019 at 7:08 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    19, Limited, CrewMax, Off Road, Cement Gray
    None Yet
    @Kurdt, thanks buddy. Glad to hear that the 2017 TRD pro Grille and Buldge in Cement gray matches the color . I have seen on the forum several people that say it does not match . I like the original paint instead of after market paint . From my experience, it holds up better. When you swapped the TRD Pro grill with your grill, did you break any of the tabs ? Was it easy to do?
  3. Dec 2, 2019 at 3:33 PM
    Kurdt
    Kurdt New Member
    Austin TX
    Swapping the grill was kind of a pain in the ass and it takes patience, but not hard. I believe I broke one, maybe two tabs. There are a few that are really stubborn.
  4. Dec 2, 2019 at 10:17 PM
    Willskaf
    Willskaf New Member
    William
    Castro Valley, CA
    None Yet
    Ok. Thanks buddy
  5. Dec 12, 2019 at 8:29 PM
    MICKs18yota
    MICKs18yota New Member
    Ohio
    2018 Tundra SR
    I’ve got 285/70/18 Yokohama Geolander MT’s on mine I ended up with 6112’s set on 1.9 I left the rear stock with 5100’s only had to take front spat off and minor trimming on the mud flaps.
  6. Jun 9, 2021 at 5:46 AM
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Bump
    Anyone have stock suspension (less than level) and fit 285/70s on?
  7. Jun 9, 2021 at 6:53 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  8. Jun 9, 2021 at 7:43 AM
    frichco228
  9. Jun 9, 2021 at 7:46 AM
    AverageJoe
    AverageJoe New Member
    DFW TX
    21 DC SR 4WD
    This is why I went with 275/70/18s on my 2021. Can appreciate the desire for 285 but in my case going down by 10 still fit my requirements and got them mounted on powdercoated factory rims off fleaBay with no spacers or other mods necessary. Although I'm probably going to be upgrading rims in the future for weight reduction but the rims were cheap enough figured I'd give 'em a shot although the powercoating/painting they did on end caps sucks.
  10. Jun 9, 2021 at 8:01 AM
    CCLJ03
    Craig
    That’s definitely the smart move! I’ve had 275’s before, and I think they look more impressive than some people on this site give them credit for, but I think 285 is really going to scratch my itch without making me feel like I went overboard.
  11. Jun 9, 2021 at 8:11 AM
    AverageJoe
    DFW TX
    21 DC SR 4WD
    I hear you, scratch it!
    CCLJ03[QUOTED] likes this.
  12. Jun 9, 2021 at 8:14 AM
    frichco228
    I would have run them if there were some ATs I wanted in the size. Rg is the only tire other than some MTs. But I need something 3 peak rated with good wet traction. The size does look great on Tundras.
  13. Oct 20, 2021 at 4:26 PM
    keepin’itreal
    keepin’itreal New Member
    2017 Toyota Tundra TRD Offroad
    Hi guys - would love some help. Ive spent days reading through posts. I’m having Bilstein 5100installed next week, I do not want to lift the rear, I dont want anything too aggressive looking as it’s a pavement daily driver but Ive had the truck 4 years and I want to make it less stock but keeping the stock rims.
    So I’m struggling with what tires to run - I’m leaning toward 285/75/15 duratracs, and I’m cool with trimming the skid plate and the mud flap and some minor wheel well plastic. Most posts Ive seen are a 3/1 lift which I’m not doing. Will this set up work (likely) work for me with the 5100’s, stock rims and no rear lift on 285/75/18’s?
