How do I disable TPMS warning light on Dash?
Discussion in '1st Gen Tundras (2000-2006)' started by Heger, Feb 3, 2023.
  1. Feb 3, 2023 at 9:55 AM
    Heger
    Heger [OP] New Member
    I have an 06 DC. I just got it lifted along with new wheels. But the TPMS warning light on the dash blinks.
    How do I disable it? Is there a fuse to pull? A wire I can cut? Or do I have to remove the whole dash and pull the small light bulb?
    TIA
  2. Feb 3, 2023 at 10:01 AM
    FrenchToasty
    FrenchToasty The Desert rat, 6 lug enthusiast
    Mo
    The SoAz
    None
  3. Feb 3, 2023 at 10:05 AM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    FrenchToasty likes this.
  4. Feb 3, 2023 at 10:32 AM
    GXPaycheck
    GXPaycheck New Member
    Central NC
    Did you check the pressure on the spare? I had that issue. If it's not that you have a bad sensor.
  5. Feb 3, 2023 at 10:36 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  6. Feb 3, 2023 at 10:37 AM
    FrenchToasty
    Mo
    The SoAz
    None
    Not hardly, that would be lord shifty or knight bubba of duble cabith
    BubbaW, Elevatorguy and shifty` like this.
  7. Feb 3, 2023 at 10:38 AM
    tundrainsc
    tundrainsc Happy Tundra 1st Gen
    06 Limited 4.7 2WD
    Just put small piece of black electrical over the blinking light. That's what I did on my 06 DC. You can't even tell the tape is there. If you ever want to replace the sensors you haven't cut wires or removed parts.
    HBTundra likes this.
  8. Feb 3, 2023 at 10:46 AM
    texasrho83
    texasrho83 DGAF#1
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Ok then you're a Prince or Duke of Searchith
  9. Feb 3, 2023 at 11:03 AM
    FrenchToasty
    Mo
    The SoAz
    None
    I’ll allow that
  10. Feb 3, 2023 at 1:40 PM
    shifty` One great big festering neon distraction
    Mine started flashing recently. I need to sniff my sensors to see if one's not transmitting, then replace and program it in.
  11. Feb 3, 2023 at 1:44 PM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    Virginia Beach
    2021 CrewMax TRD OffRoad
    Stock for now
    Ya'll are letting me down. How can you go a whole thread without at least snarky answer?? :D
  12. Feb 3, 2023 at 1:49 PM
    Elevatorguy and FrenchToasty like this.
  13. Feb 3, 2023 at 1:51 PM
    FrenchToasty
    Mo
    The SoAz
    None
  14. Feb 3, 2023 at 1:54 PM
    radon222
    Ed
    Virginia Beach
    Stock for now
    Thank you, Thank you
    Shows are every hour on the hour. Don't forget to tip your wait staff....
    :oops::oops::oops::oops::oops::oops:
    Elevatorguy, FrenchToasty and shifty` like this.
  15. Feb 3, 2023 at 1:54 PM
    Teutonics
    Teutonics New Member
    2005 DC SR5 4WD
    I'll add that I did the "cut the pink wire and ground it" mod (I think I have that right) and it was waaaayyy more of a PITA than I thought it would be. It's in a very awkward spot with very little room to work. In hindsight the electrical tape might have been a better solution, but my OCD wouldn't allow for it!
  16. Feb 3, 2023 at 1:56 PM
    Fixing the problem the right way isn't as difficult as everyone makes it out to be. But I digress.
    Tell you what, I'll document the process when I finally do mine.
  17. Feb 3, 2023 at 2:02 PM
    FrenchToasty
    Mo
    The SoAz
    None
    What buying new sensors? Hahaha
    I know mine is on because my spare doesn’t have a monitor, I’ve learned to live with it, I visually inspect everyday, and I’ve got bigger fish to fry
  18. Feb 3, 2023 at 2:25 PM
    Mine's flashing though. It's been rotating between flashing constantly (TPMS comm fail) and flashing at startup/staying solid. I've tried multiple resets per the manual, no dice. It's gone away and come back a few times, so I'm sure it's just one of the sensors finally has a battery going out.
    I meant to dig a little more on TPMS sensors. IIRC, they broadcast out on 433Mhz. In theory, shouldn't be too hard to figure out which one isn't broadcasting, I think? I'll hafta see if the new OBDII tool is able to read the 4 or 5 TPMS sensor IDs currently installed. I'm curious if it'll allow rewriting new IDs in too.
    I'm just on the fence; I need new tires anyway, and I need to get my lift installed, but I'm hinging on extended links, so I'm getting off my ass and ordering today or tomorrow so I can get all this crap done.
  19. Feb 3, 2023 at 2:37 PM
    Teutonics
    2005 DC SR5 4WD
    Sure, replacing the sensors is the preferred solution and it’s not hard at all, but it’s also a LOT more $$$.
    shifty`[QUOTED] likes this.
  20. Feb 3, 2023 at 2:42 PM
    BubbaW
    BubbaW Been Real
    Bubba
    Where Eagles Nest
    T150 Lover
    Please take pics, as @bmf4069 always says, like a lot !
  21. Feb 3, 2023 at 2:44 PM
    Solid Snake
    Solid Snake New Member
    2006 AC 4x4 V8
    I had the same issue. Spare tire was the culprit.
  22. Feb 3, 2023 at 2:48 PM
    JasonC.
    JasonC. ¯\_(ツ)_/¯
    TX
    2001 4x4 4.7L AC Limited 44k mi
    Everyone on this board secretly hopes shifty has the same problems their trucks have. ;)
