How big is yours? Measure up!
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, May 15, 2019.
  1. Jan 7, 2020 at 3:19 PM
    Localsnap88
    Localsnap88 New Member
    NJ
    2005 SR5 Doublecab
    SPC UCAs/bushings, Bilstein 6112 Coilovers @ 1.8”, 265/75 Cooper AT3 LT on Method Grid 16x8/ 0 offset, EBC Rotors/Perf Brake Pads, Energy Poly sway bushings, Moog greasable Endlinks, Airaid Synthamax Dry filter, Magnaflow 18” SI/SO muffler , Toyota SS rolled exhaust tip, Spider black housing headlights, Phillips Racing Vision halogens, Eagle Eyes LED smoked tails, Eagle Eyes LED Third Brake, Aftermarket OEM style fogs, full interior LEDs, reverse LEDs, Tinted sides and rear, bug deflector, window visors, AMI Stub Antenna 5” Aluminum/SS/rubber steps, TPMS delete, SAIP blockoff/delete, M1 Synthetic Engine and Diff oils,
    Happy new year brother , nice truck you have. I have a similar silver sky 2005 doublecab that I recently added a Bilstein 6112 coilover lift to, believe it’s sitting about 1.75-1.85 inches of lift in front, and with a helper spring installed I’m about 3/8” higher in the rear . Tomorrow I have wheelers offroads 3 leaf progressive arriving , it’s basically very similar to the icon progressives you say you installed. Question - I assume you removed your overload lead when installing the icon pack? And just to confirm, you said you were sitting at around 22.75 in in rear after installing them? Do you recall what you were sitting at in the rear inch wise before the icon? Thanks in advance , trying to decide if I’m pulling or keeping the overload when I get rid of the helpers and add the progressive pack
    speedtre likes this.
  2. Jan 7, 2020 at 4:21 PM
    speedtre
    speedtre New Member
    Inland Northwest
    Getting ready to throw a Wheeler's AAL on as well, so I'd be interested in that info as well...:thumbsup:
  3. Jan 7, 2020 at 5:08 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    I honestly did not measure before installing. I did remove the overload. It didn't seem to raise it immensely if I were to guess maybe an inch, but it does ride much nicer.
    Tundra2 and speedtre like this.
  4. Mar 7, 2020 at 3:46 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    OME 2886 springs and 90004 shocks front = 24"
    OME shocks 60091 with 1" block rear = 23"
    SPC UCA's
    285/70/17 KO2's
    No rubbing.
    I still need to add a winch and skid plates so the front will probably come down a little on the future.
  5. Mar 7, 2020 at 4:23 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I’m about to add 5100s all the way around on my 06 2wd, I’ll add measurements as I go. I agree with whoever said they had a ridiculous nose down rake. 5EC2CA13-2691-439C-BD57-2F7BC08E77B6.jpg
    Darkness[OP] likes this.
  6. Mar 7, 2020 at 6:38 PM
    Tohopko
    Tohopko New Member
    2004DC
    Front: Bilstein 6112s 6th notch with 600lb springs, 3/8 spacer on driver's side, SPC UCAs, currently at 3.1 or so on the caster = 23"
    Rear: Bilstein 5160s, Wheeler AAL with 3° diff wedge and factory overloads = 23.5" with the A.R.E. cap on.
    285/70r17 BFG K02 on SCS BR8 17x8.5 -1020200130_150629.jpg
    Have some rub on the driver's side mudflap when the steering wheel is cut to the left, both forward and reverse. Was hoping to use a heat gun to mold the flap a bit, but may need to beat down the pinchweld underneath. It isn't serious, just annoying.
  7. Mar 8, 2020 at 12:09 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Are you on stock leaf springs? Do you know how old they are? I'm just impressed and a little surprised you got that much lift from the AAL.
  8. Mar 8, 2020 at 10:57 AM
    Tohopko
    Tohopko New Member
    2004DC
    yes, stock springs. 2004, original as far as I know, 127k miles. I'm using the Wheeler AAL pack (3 springs) plus a 3° axle wedge that also adds a small amount. The factory overload is still in place as well. Wheeler claims 1.5" without the factory overload, I ended up with around 2 with the wedge and the overload.
  9. May 13, 2020 at 8:36 AM
    2000 TRD 4WD with 5100's at the 4th notch on TRD springs. 21 3/4" up front, 22" out back. Measurements are center hub to the larger factory fender flares bottom edge.
    265/75/16 Hankook Dynapro ATM's on 16x8" powdercoated Eagle 589's with 4.5" backspacing and 1.25" wheel spacers.
  10. May 13, 2020 at 8:44 AM
    Professional Hand Model
    Hand Protectors
    Interesting seeing the different measurements.
  11. May 13, 2020 at 8:48 AM
    Hand Protectors
  12. May 13, 2020 at 12:38 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    2006 Tundra 4.7 AC 2wd
    2006 Tundra: Stock air intake 3 inch catback Magnaflow 13742 2.5 inch front lift 1.5 inch rear blocks 2014 sr5 4Runner wheels (17x7) 1.5 inch hub centric wheel spacers p285/70/17 Nitto Terra Grappler G2 Weathertech floor liners
    Thats a good little lift just from doing 2nd notch on 5100’s, with 4x4 to boot. The TRD springs I believe are the difference maker with how much stock springs will yield. Do you have the updated 5100’s? I know they redesigned them, but as far as I know they only changed the position of the top groove. So basically instead of the top being 1/2 apart it’s more like a 1/4 inch on the redesign.
    Voss and Darkness[OP] like this.
  13. May 13, 2020 at 12:59 PM
    Hand Protectors
    Not sure, but I’ll snap a pic later and post it for a determination here. I know for sure the shop confirmed with me that we were doing just 1 notch up from stock.
    I’ll also remeasure again for grins to confirm my priors.
  14. May 13, 2020 at 1:29 PM
    Hand Protectors
    Remeasured drivers side only. All pics are from drivers side, as well. My rear measurement bumped up from 22.5” to 22 7/8”! All things are the same except my two side boxes (40-50 lbs total) are now removed with new updated measurement.
    Front 21.5” (same)
    Rear 22 7/8” (risen 3/8”) :notsure:
    revtune likes this.
  15. May 13, 2020 at 4:04 PM
    Hand Protectors
    @revtune which Billybobs are these? Updated?
  16. May 13, 2020 at 4:56 PM
    revtune
    revtune New Member
    Dane
    Houston Texas
    Sorry, it’s hard to tell by this photo. If you can get a pic of the actual part number near the bottom of the shock, that would tell us if they’re updated. Here is a note from the wheelers off road website:
    “Please note: This Bilstein model 24-261425 replaces the older Bilstein model 24-188265. The only visible difference we've seen is that the new shocks' top clip groove is slightly lower than the older model, yielding a little less lift on the top groove. Also, the new shocks ship with large flat washers for bump stop spacing.”
  17. Nov 7, 2020 at 4:55 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    King Coilovers, Camburg UCA and Deaver Leafs in rear.
    285/75 R16 with -10 offset and 1.25” spacers
    Front:
    Driver 22 1/4”
    Passenger 22 1/2”
    Rear:
    23” both sides
  18. Dec 13, 2020 at 7:58 AM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    New BIG-O Monroe specials on the front
    DF 20 1/4
    PF 19 3/4
    PR 22
    DR 22
  19. Dec 19, 2020 at 11:53 AM
    #49
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    6112 set at 5 and 7 (1.6") . 5160 and stock leafs in the rear.
    Front 21.5
    Rear still 22
    RustyShackle323 likes this.
  20. Dec 20, 2020 at 6:24 PM
    #50
    Suprlogr1
    Suprlogr1 New Member
    2004 dark grey tundra 4x4
    How many miles have you had the super charger on it, looks real nice!!
  21. Dec 20, 2020 at 7:10 PM
    #51
    jImmegart
    jImmegart Second Youngest tundra owner in the west!
    Jonah
    California
    2003 Tundra TRD Sport
    FN Counter steer type X w/ 285/70r17 Geolanders JBA y-pipe and pro street 6000 muffler 2.5 king coilovers w/ total chaos uca and custom 2.0 king rears Skidrow front plate TRD Sport package W/ Factory rear swaybar and LSD
  22. Dec 21, 2020 at 5:28 PM
    #52
    imDementeD
    I bought it with the supercharger already installed. Not sure exact mileage. I was thinking it was on it during the service in 2006 at 132k miles but I did notice it had an OEM filter during that service. When I received it, it had a K&N which I think is common with the TRD S/C. So not really sure. Couldn't find any other records that would indicate the installation of the supercharger.
  23. Apr 22, 2021 at 3:56 PM
    #53
    Hand Protectors
    So today for grins I measured mine and the tape broke at 2”. :rofl:
    Seriously, my front was 21.25” and the rear 23” solid.
    Keep in mind I’m as empty on gas as it gets due to upcoming Fuel Pump install. My hope springs eternal. :D
  24. Apr 22, 2021 at 5:59 PM
    #54
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Your rear springs are a full inch higher than mine were completely unloaded. These ATS HD springs are only a half inch higher than your 20 year old stockers. Amazing.
  25. Apr 23, 2021 at 4:10 AM
    #55
    Hand Protectors
    Yeah. Its hard to understand as she has done her fair share of haul/tow. I always wondered about some Tundras I’d see on the road with saggy pants but know now that their are different springs for 2 or 4 wheel drive.
    Yesterdays measurement was with maybe 2 gallons gas? The prior measurement a few years back I didn’t take note of the tank content. Seems my front has dropped 1/4” but the rear came up 1/2”. Maybe its the rear lift and frontal tilt down action Geometry happening?
    I’ll take another measure with a full tank.
    onesojourner[QUOTED] likes this.
  26. Apr 23, 2021 at 9:59 AM
    #56
    Wes_heppy
    Wes_heppy Trucks...Dirtbikes... Guns...
    Weston
    2003 tundra 4x4 4.7
    TC UCA Radflo coilovers Long Tubes LSD
    35/12.5/17s, 2in spacers, Radflo 2.5s, TC uppers, icon Add a leaf with overload sitting at 24 front and 23.75 in the rear. Ripped off the front fender flares if it makes any difference. Probably have too much preload adjusted on the coilovers honestly.
  27. Apr 30, 2021 at 8:24 AM
    #57
    Hand Protectors
    Measured again now that she has a topped off tank of gas.
    21.5” on both fronts.
    22.75” on driver rear
    22.5” on pass side rear
    des2mtn and onesojourner[QUOTED] like this.
  28. Apr 30, 2021 at 8:51 AM
    #58
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    ATS HD spring update
    Here things are loaded to camp 600# tongue weight and no weight distribution on yet. The front lifted 1/8th. This would not be safe to tow like this, demonstration only.
    Rear 21"
    front 21" 5/8
    I can stand on the bumper and there is still a fair bit of suspension travel. The old springs would have been completely worthless at this point, bumpstop city, all day everyday.
    These springs are made to do work and I like them.
  29. May 19, 2021 at 4:11 AM
    #59
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I think I've posted before that I suspected the drivers side front was lower than the passengers side.
    From the center of the hub cap to the top of the edge of the fender on the drivers side is 21.75 inches.
    From the center of the hub cap to the top of the edge of the fender on the passengers side is 22.5 inches.
    I'm only interested in the front right now so that's all I measured. Pretty bummed to confirm my suspicions. What can I do to fix it?
    I even have the .25" spacer installed on the drivers side to account for the drivers side lean that usually comes with these trucks.
    Can't fathom a .75" difference. I do not understand.
  30. May 19, 2021 at 4:20 AM
    #60
    onesojourner
    SW MO
    06 DBLcab LTD 4x4
    Did you replace your front coils?
    Tundra2[QUOTED] likes this.
