Hotshot Offroad's 2021 Tundra Build
Discussion in '2.5 Gen Builds (2014-2021)' started by memario1214, Jul 5, 2021.
  1. Jul 27, 2022 at 3:28 PM
    #121
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Gave the ol' battleship a spit shine at the carwash this morning after a hot minute... Also, wrapped the TSS sensor in some flat black vinyl for now until I decide that I am going to run some sort of printed design up there. I hated the glossy finish of the OEM one so something had to change! I also routed the TSS wiring up and around in the TRD Pro grille so that it's no longer visible at all. Small details :cool:
  2. Jul 27, 2022 at 3:44 PM
    #122
    I had to get rid of the black piano gloss around the shifter....my eyes couldn't handle the sun glare any longer.
  3. Jul 27, 2022 at 3:51 PM
    #123
    memario1214
    Colton
    Missoula, MT
    Want. Talk to me.
    French Avocado and Taco-Spike like this.
  4. Jul 27, 2022 at 3:53 PM
    #124
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    George is being stingy with that stuff around the shifter :p
    Taco-Spike likes this.
  5. Jul 27, 2022 at 4:21 PM
    #125
    No way. Haven't gotten a good sizing on the cut yet. I sprayed it with the Rustoleum Painters Touch 2X Matte Clear. It does the job and keeps the lettering.
    @memario1214 , wipe it down with an alcohol wipe and spray 2 light coats and you will be good to go.
  6. Jul 28, 2022 at 6:52 AM
    #126
    memario1214
    Colton
    Missoula, MT
    Did you mask off the MESO trim ring? Or did you just spray right over the top of it?
  7. Jul 28, 2022 at 7:21 AM
    #127
    Mine is the oem that I coated with the SEM trim black paint. You can mask it.off or remove it. It is fastened with plastic rivets. When I removed mine, there was enough post left that I was able to re-melt it with a soldering iron.
  8. Jul 28, 2022 at 7:25 AM
    #128
    memario1214
    Colton
    Missoula, MT
    I'll rephrase. I've already swapped my chrome one out for a black one and re-welded the plastic together. A job which I would prefer to not do again :rofl:. I was seeing if you ran right over that with the matte clear or if what I am looking at is the result of that (now) black trim piece being masked off?
  9. Jul 28, 2022 at 8:25 AM
    #129
    Gotcha. I removed it and did not spray it so it's just the SEM paint. No idea why I didn't just spray it too lol.
  10. Jul 28, 2022 at 8:31 AM
    #130
    memario1214
    Colton
    Missoula, MT
    Well now I don't know what to do! I'll probably just spray it still installed...
    RobertD and French Avocado like this.
  11. Jul 28, 2022 at 8:35 AM
    #131
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrĂĽeMax
    That’s what I would do, leave it with a (somewhat) uniform finish across the shifter area.
  12. Jul 28, 2022 at 8:35 AM
    #132
    I'm thinkig that it will be just fine. I'm going to spray it over the rest of my interior pieces that I used the SEM on.
  13. Jul 28, 2022 at 8:37 AM
    #133
    memario1214
    Colton
    Missoula, MT
    And by installed I mean just leave the entire console area assembled and just start spraying!
  14. Aug 3, 2022 at 8:52 AM
    #134
    memario1214
    Colton
    Missoula, MT
    Picked up a couple of fresh goodies... And of course they had to be finished in Hotshot Red :cool:
    New rear lift shackles (current ones have to be pulled for some spare tire clearance anyway) + some upgraded tie rod ends. Hoping to clean up my (albeit minor) bump steer issues and dial that alignment in!
    Pics suck because I had to screenshot them from a video :rofl:
  15. Aug 3, 2022 at 12:17 PM
    #135
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    What's the situation with your current shackles? Are they Coachbuilders too?
  16. Aug 3, 2022 at 3:48 PM
    #136
    memario1214
    Colton
    Missoula, MT
    They are. So I actually ran the bolts through them backwards during install which led to a clearance issue with my spare. I haven't been running a spare for a long time now, but load E tires but :notsure:. I knew I was going to be tearing them apart again, and I stumbled across these red ones. These are literally just for tying the Hotshot brand together with unique stuff. I actually have a set of Icon RXTs on order (which aren't supposed to be here until the end of Oct) to compensate for the weight of the additional goodies I am adding back there. I also picked up a +1" shackle second-hand from a member on here so we'll see what combo between the RXT pack options and shackle lengths I ultimately end up landing on once I start strapping on parts.
    RainMan_PNW[QUOTED] and RobertD like this.
  17. Aug 3, 2022 at 6:18 PM
    #137
    RainMan_PNW
    Casey
    Clark County, WA
    Cool.
    I didn’t know if CB was making special “big ass spare tire clearance” shackles in red. I was gonna have to look into it when I finally got a full size spare…
    bulldog93 likes this.
  18. Aug 4, 2022 at 7:37 AM
    #138
    memario1214
    Colton
    Missoula, MT
    Haha nope! Just happened to make some in red! I think I read somewhere that these shackles will still support a 35" underneath with some finessing?
    RainMan_PNW[QUOTED] likes this.
  19. Aug 4, 2022 at 7:59 AM
    #139
    TRDFerguson
    Jake
    2018 MGM CrĂĽeMax
  20. Sep 22, 2022 at 10:05 AM
    #140
    memario1214
    Colton
    Missoula, MT
    CBI Bumper INSTALLED. No lights in there yet as I am currently embattled with deciding if I want to clearance for some DD C2s, or go with some S2 pros. My gut is telling me that I will end up running S2s as I don't see myself using the backlight on the C2s if I went that route. I also am not super hot on the silver plates that top this bumper from CBI. I'm either going to make my own, or at the least get these ones coated black.
    I'll get some better pics too. Just some quick iPhone shots after getting it on!
    54C6AE84-6129-4124-AA8D-F4F5C5300D94.jpg BBDB5C01-F4BE-4B08-A384-2D9881F16BCA.jpg
  21. Sep 22, 2022 at 10:11 AM
    #141
    Line-X that whole bumper and it would look sweet. I think I was blinded by the chrome on the sides of the tail lights lol.
  22. Sep 22, 2022 at 10:16 AM
    #142
    memario1214
    Colton
    Missoula, MT
    I just realized how over-exposed those shots ended up when posted here in a larger format! I just re-uploaded unedited versions.
  23. Sep 22, 2022 at 10:19 AM
    #143
    Looks good to me. You need this....
  24. Sep 22, 2022 at 10:20 AM
    #144
    memario1214
    Colton
    Missoula, MT
    I do not. I already have 2 sets of tails split open... Just gotta find some time to finish the project!
    ToyoMafia, TRDFerguson and Outbound like this.
  25. Sep 22, 2022 at 10:22 AM
    #145
    Lol. It's just vinyl that makes them look alot better. I just did vinyl on my 3rd brake conversion as well since I couldn't use the cargo lights anyway. What projects are you doing to your tails?
  26. Sep 22, 2022 at 10:25 AM
    #146
    memario1214
    Colton
    Missoula, MT
    I'll be doing a full paint similar to @TurdFerguson, but then have some other lighting goodies I am trying to shoehorn into there depending on available space. Just gotta find the time and energy :rofl:
    ToyoMafia likes this.
  27. Sep 22, 2022 at 10:26 AM
    #147
    That would be awesome to see.
  28. Sep 22, 2022 at 10:34 AM
    #148
    My rear bumper....pods are on an on/off/reverse switch.
  29. Sep 22, 2022 at 11:05 AM
    #149
    RainMan_PNW
    Casey
    Clark County, WA
    Really happy with the S2 Pro in my bumper, and it was easy to make up some plug and play harnesses that simply tapped them off my factory reverse lights. I do plan on reconfiguring the reverse light circuit to work using factory settings (reverse trigger) OR manual switch. Just have to place the right kind of relay in the right place…
    and like you, I’m not a fan of the bare aluminum tread plates. Looking at getting mine type3 hard coat black anodized maybe
    bulldog93, Baja Designs and ToyoMafia like this.
  30. Sep 22, 2022 at 11:14 AM
    #150
    Ha...you didn't have enough fun when you were chasing wiring on my Rigid setup with the front/rear switch that I used? :D
