Hot Tundra from AZ
Discussion in 'New Member Introductions' started by Damicci, Jun 17, 2021.
  1. Jun 17, 2021 at 11:01 AM
    Damicci
    Damicci [OP] New Member
    Damian
    2001 White Tundra SR5 V6
    Greetings. 1st Time Tundra owner from Tucson AZ. :bananadead:
    Owner of a 2001 Tundra SR5 v6 17x,xxx miles.
    Mainly used to head to the desert to "put holes in paper" and the usual large item haul. Occasional 91 mile trips to Phoenix for IKEA. :duh:
    Timing Belt last done at 15x,xxx miles
    Recently had the following replaced:
    Steering Rack Bushings
    Brakes (Need new rotors, current rotors on final turn)
    Upper and Lower Ball joints.
    Up next
    Carrier bearing and U-Joints
    Valve cover gasket
    Tie rods
    Any other things to be on the look out for?
    Thanks.
  2. Jun 17, 2021 at 11:19 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    welcome from so cal
  3. Jun 17, 2021 at 11:45 AM
    Welcome from NY.
  4. Jun 17, 2021 at 11:51 AM
    Azblue
    The Dirty T ( ^_^)_且
    Welcome from Tucson.
  5. Jun 17, 2021 at 11:52 AM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  6. Jun 17, 2021 at 11:56 AM
  7. Jun 17, 2021 at 2:08 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Welcome from another tucsonian. Let's see that tundra!
  8. Jun 17, 2021 at 2:10 PM
    AZTundra
    Paul
    Phoenix, AZ
    Welcome from up north (Phoenix). Not any cooler up here either.
  9. Jun 17, 2021 at 2:27 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Welcome from Tucson, this was my temp display the other day C50B4211-9012-4892-B5DD-137F576DC1C8.jpg
    YardBird likes this.
  10. Jun 17, 2021 at 2:33 PM
    AZ Red Nek
    AZ Red Nek Native of the Valley, Bowl, Basin, ETC...
    Chuck
    2016 White SR5 Crew 4x4
    Hidden 1200# Waren winch, Baja Desgins lights, Switch Pro switch and controller, S&B air box and in bed tool box.
    Welcome from Phoenix
  11. Jun 17, 2021 at 2:35 PM
    WBW
    WBW Resident lurker
    Bruce
    Surface of the Sun - AZ
    2015 CM Tundra SR5 2WD
    Welcome from Chandler.
  12. Jun 17, 2021 at 2:48 PM
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Must have been morning still...
  13. Jun 17, 2021 at 3:07 PM
    81 TOY
    81 TOY New Member
    Larry
    Vermont
    2008 Limited Crew Max
    Welcome!
  14. Jun 17, 2021 at 3:11 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  15. Jun 17, 2021 at 3:20 PM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Welcome from Penciltucky
  16. Jun 17, 2021 at 3:30 PM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Welcome from Mesa.
    Has the truck always been in dry climate? If it's from a region that uses salt to de-ice the roads, you may want to check the underside for carriage rust. (https://www.tundras.com/threads/early-1st-gen-2000-2003-tundra-frame-replacement-faq.54331/)
    You may also want to do a fluid flush on the following:
    Steering - https://www.tundras.com/threads/power-steering-flush-how-to.85254/
    Transmission - https://www.tundras.com/threads/2006-dc-transmission-fluid-change.78227/#post-1982660
    Rear differential - https://www.tundras.com/threads/don...ar-differential-oil.90301/page-2#post-2277318 or https://www.tundras.com/threads/don...ar-differential-oil.90301/page-2#post-2277344
    Suspension - @ 150,xxx miles, you may want to look in to replacing the shocks and rear leaf springs. Since you are primarily using it to go punch holes in paper in the desert, you can just replace them with OEM ones. With fire season in full effect here, it'll be a while where you can actually go to BLM land for that stuff.
    You might also want to check this thread for a checklist of maintenance : https://www.tundras.com/threads/noo...ntenance-help-and-updates.84559/#post-2132185
    Damicci[OP] and TucsonTundra1794 like this.
  17. Jun 17, 2021 at 3:31 PM
    Gravy
    Gravy Cat herder, ASCM #π
    Yucaipa, California
    2008 White DC 4x4, Limited TRD
    OME Nitrocharger/2612 (front), Bilstein 5100s (rear). Vanguard roll bar modified (by me) to fit over Patriot Stealth retractable tonneau. Aftermarket halo headlights with HID, various LED bulb replacements. 17" Fuel Blitz wheels with some 33" Nitto terra grapplers. Hoodscoop, nfab nerfbars, Bushwacker flares. No-name aftermarket grille, led fender extensions. Black Horse bambi-basher. Various offroad lights.
    Welcome from SoCal. PICS
  18. Jun 17, 2021 at 4:17 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  19. Jun 17, 2021 at 6:33 PM
    Damicci
    Damian
    Awesome info here. Thank you.
    Carfax, reported it was originally purchased here in Tucson, AZ and has only had 1 owner. I did get underneath to check the carrier bearing and u joints. no obvious rust, just dirt and dust.
    Yeah, with the fire restrictions in play, figured now would be even better to get this truck cleaned up. the previous owners were filthy so I spent probably a week going through and shampooing and cleaning the interior.
    Will review those maintenance threads and get to work.
  20. Jun 17, 2021 at 7:29 PM
    Welcome from Ohio
