2006 DC transmission fluid change?
Discussion in '1st Gen Tundras (2000-2006)' started by Mayberry, Nov 16, 2020.
  1. Nov 16, 2020 at 12:52 PM
    Mayberry
    Mayberry [OP] New Member
    Mayberry
    2006 Tundra DBL 4x4
    So my new to me Tundra has very few maintenance records. I’m getting the t-belt, WP, and suck done next week. I’d like to go ahead and change the transmission fluid. Is just a drain and fill the recommended procedure? My wife has a 02 Sequioa, and I have the seller tossed in the printed factory workshop manuals. I know the transmission is different between the two but is the procedure fairly the same?
    Oil changes were kept up with and isn’t due for another 1500 miles. Tires will be rotated. What else am I missing?
    thanks
    YardBird likes this.
  2. Nov 16, 2020 at 4:58 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Your truck has a harder process than an earlier model. Your truck has no dipstick for the trans. You have to drain fluid into a container where you can measure the amount (temperature controlled too) and pour that amount of new fluid in.
  3. Nov 16, 2020 at 5:16 PM
    Mayberry
    Mayberry
    2006 Tundra DBL 4x4
    Thanks. I knew it couldn’t be that I was lucky enough for them to be the same. I do some research on the process.
  4. Nov 16, 2020 at 5:21 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  5. Nov 16, 2020 at 6:12 PM
    weadjust
    weadjust New Member
    Tupelo, MS
    2006 Tundra Limited DC
  6. Nov 17, 2020 at 8:17 AM
    Mayberry
    Mayberry
    2006 Tundra DBL 4x4
    Yardbird-very cool. I’ve dealt with sealed transmissions before, although I don’t recall any having a check valve like the one in the video.
    weadjust- awesome! Thank you.
  7. Nov 17, 2020 at 4:22 PM
    RPR
    RPR New Member
    2005 Tundra SR5 2WD Silver
    In the absence of past records on transmission service, I would suggest you consider dropping the pan, replacing the filter and having the transmission valve body re-torqued. My auto service company charged $220 to have this done on my 05 DC 2 years ago, and I have had this service performed every 50K miles since I’ve owned the vehicle brand new. Breakdown was labor, $136; pan gasket, $12; AT filter $32; and 4.5 qts Toyota WS ATF fluid, $43. They also cut open the old filter and inspect it to let me know if there are any signs of abnormal transmission wear I need to aware of.
  8. Nov 17, 2020 at 5:07 PM
    bmc02
    bmc02 New Member
    Buddy
    E WA
    05 DC SR5 / 06 SEQUOIA LTD
    It's a sealed trans. I just had my 05 done at the dealer at 100k miles per FSM maintenance schedule. It's a flush process and they use some cleaner and conditioner as well. I would usually do trans flushes myself but the sealed trans process gave me hesitation. Better left to the pros, plus I had a coupon. Good for another 100k now.
  9. Nov 17, 2020 at 5:11 PM
    I just need to get the stupid sequence programmed into my scan guage, and then I’ll be doing it; I seem to have a hard time getting it to set or program the right file.
  10. Nov 18, 2020 at 7:40 AM
    chester
    chester best member
    2005 Double Cab SR5
    I've never head of this. Why do it? Are there any how-to's for this?
  11. Nov 18, 2020 at 10:49 AM
    RPR
    RPR New Member
    I’m copying verbatim a quote from my auto tech service company from an article written by the owner of the company, plus a link to the entire article, as to why they re-torque the transmission valve body bolts, when dropping the plan and replacing the AT filter and adding Toyota AT fluid.
    “While the pan is off, we tighten the bolts on the transmission valve body to the specified torque. In time the valve body gasket shrinks, from heat and the bolts loosen. A loose valve body can develop cross-leaks among the passages. This can cause transmission failure. Properly tightening these bolts can help prevent this problem.
    After inspection and checking the valve body bolts, we replace the transmission filter and seal. Next we install the pan and we fill the transmission with the proper fluid. Replacing the filter is key on transmissions with replaceable filters. Restricted transmission filters lower internal pressure and can destroy a transmission very quickly.”
    Link to the entire article http://www.agcoauto.com/content/news/p2_articleid/203
    Bonus article on checking Toyota transmission fluid levels http://www.agcoauto.com/content/news/p2_articleid/345
    The 05-06 Tundra Service manual linked by weadjust in his post above provides the valve body bolt torque specification, on page AT-14 (valve body assembly) for the 19 valve body bolts (11 N-m, 8 ft-lbf) and steps are provided in the service manual.
    flyfisher, JoeDuffer and chester like this.
  12. Nov 19, 2020 at 8:48 PM
    Surf_spear_Mex
    Surf_spear_Mex New Member
    Patrick
    05 tundra ac
    I had Yodaman in Sonoma do a flush, pan drop, and re torque of the valve body. It shifted great before and still does. I trust a man that has conquered the Rubicon trail many times and kept every toyota on it running tip top.
    wandering_boy and YardBird like this.
  13. Nov 19, 2021 at 10:57 PM
    wandering_boy
    wandering_boy Junior Tech Wizard
    California
    2005 AC SR5 TRD
    Don't let a kid out smart you.
    Would this be Sonoma CA??
  14. Nov 20, 2021 at 2:23 PM
    Uh oh. My man is planning his side trips :D
  15. Nov 20, 2021 at 4:51 PM
    wandering_boy
    California
    2005 AC SR5 TRD
    No. I just have No idea when my ATF was changed last and I don't want to get shafted by a dealer.
    shifty`[QUOTED] likes this.
  16. Nov 28, 2021 at 8:26 PM
    stevechumo
    stevechumo New Member
    I changed the transmission on my 05 without dipstick and same as 06. I did it at 100k miles and recently at 199k miles. It's easier than you think. Drain at the bottom and fill at the side. Once the new fluid overflows at the side, then it's enough.
  17. Nov 28, 2021 at 8:36 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    That's ok for the diffs but not the trans.
    Get it up to temp and then open the fluid level check port. There's several posts about this if you check.
  18. Nov 29, 2021 at 12:38 AM
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I guess somehow you have made it 100k miles with this method but fluid should be up to a specific temp when checking the fill plug. Either drain and refill the exact same as the amount drained or follow the procedure for temp rating when checking fill plug.
    MTPatrick likes this.
