High Angle CV boots for Long Travel, 2nd/3rd gen
Discussion in 'Suspension' started by osidepunker, Jun 19, 2018.
  1. Aug 21, 2018 at 7:54 AM
    #121
    n2deep
    n2deep Pavement Princess
    How did it go? Need any help?
    dcsleeper408 likes this.
  2. Aug 21, 2018 at 10:10 AM
    #122
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    haven't started yet :rofl: I'm gonna try to knock it out today
  3. Nov 1, 2018 at 9:47 AM
    #123
    n2deep
    Just an update - Stock CV boots on LT leaked. Maybe its the tool that didn't seal it well or the installer(haha) They will be coming off again shortly and I will have the same shop that did them before do it again as those never leaked one bit.
  4. Nov 1, 2018 at 9:53 AM
    #124
    osidepunker
    osidepunker [OP] OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    My sdhq boot is still holding up. But one the last trip I noticed the new cv joint was already making noise
    SoCal619 and dcsleeper408 like this.
  5. Nov 1, 2018 at 9:56 AM
    #125
    n2deep
    I don't feel the tool made the bands tight enough, but I had to pull one apart also cause I forgot the snap ring so it wasn't as tight either. I haven't even been off-road with them yet.
  6. Nov 1, 2018 at 10:01 AM
    #126
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I promise you it's not the bands. I've had mine redone 6 or 7 times and used two different style clamps and they always leaked
    The only thing that solved it was a 3rd shop and/or sdhq boots.
    I still don't know if it's the different material of the boots (softer) or the amount of grease being used. My other side stopped leaking a while ago
    SoCal619 likes this.
  7. Nov 1, 2018 at 10:05 AM
    #127
    n2deep
    naww same bands that were on my previous ones that didn't leak. I just wasn't able to get them as tight as I thought they should have been or as the ones that came off. I didn't have SDHRQ boots before either and never leaked one bit. The DIY tools sucked cause I broke two different tools but still wasn't happy with the third tool either.
  8. Nov 1, 2018 at 10:07 AM
    #128
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Then it's gotta be the amount of greased used because it's definitely not the bands
  9. Nov 1, 2018 at 10:11 AM
    #129
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    @n2deep @osidepunker my inner CV boots have puked up some grease so I also apparently have issues
  10. Nov 1, 2018 at 10:13 AM
    #130
    n2deep
    inner??? That is the easy one cause the surfaces are clean when you band them. Its the outer one that is a huge PITA to keep clean before sealing up and banding. They need a grease zerk so you can put it together and then add the grease after. LOL
  11. Nov 1, 2018 at 10:15 AM
    #131
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    wanna have a company custom make some?? we can band together and figure this out...
  12. Nov 1, 2018 at 10:17 AM
    #132
    n2deep
    naww its not that big of a deal to lose some grease. Just a mess to clean up but good thing i have some brake cleaner and rags.
    dcsleeper408 and papasmurf like this.
  13. Nov 1, 2018 at 10:20 AM
    #133
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    i agree, but it is a dumb problem to have
  14. Nov 1, 2018 at 10:22 AM
    #134
    n2deep
    First time I have had the problem in 120k miles. :rofl: Gotta be the installer since I did it myself.
  15. Nov 1, 2018 at 10:24 AM
    #135
    osidepunker
    Alex
    2013 Tundra DC 4x4
    My inners always leaked too
  16. Nov 1, 2018 at 10:30 AM
    #136
    n2deep
    Not sure where mine is leaking exactly - maybe I will run some safety wire around it to act as a second seal. lol Just know there is grease everywhere and could be inner but looks to be the outer
  17. Nov 1, 2018 at 10:33 AM
    #137
    osidepunker
    Alex
    2013 Tundra DC 4x4
    mine always leaked from the wide opening, both inners and outers
  18. Nov 1, 2018 at 11:44 AM
    #138
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Are the boots vacuuming on you @n2deep ?
  19. Nov 1, 2018 at 7:19 PM
    #139
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    @joonbug leaked around that mileage too. Toyota was able to cover it 1 time under warranty. Now his boots are suctioned and the bellows are rubbing
    joonbug and SoCal619 like this.
  20. Nov 1, 2018 at 7:23 PM
    #140
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I feel ya brotha.. inner tie rod boots can be slid back a bit. They just keep the dust out the inner joint. If it's hitting the arm you need to check it out.
    It all apart of the game. add shit to break shit, break shit to add shit etc..
  21. Nov 1, 2018 at 7:41 PM
    #141
    Vizsla
    Vizsla 2 = 2.5
    It’s just the way we use them, have to leak. Heat the shit out of them and push grease out, no torn boot, clean and ignore is what I would do. Maybe there is a sweet spot with grease quantity, boot tension, but good luck with that. Sometimes it is what it is.
    That I would worry about, too much air, not enough grease. Why I fix my own junk, know the dummy to blame. Way better to push some grease out.
  22. Nov 1, 2018 at 7:46 PM
    #142
    n2deep
    Not suctioned. But i am ok with grease getting out, just don't want dirt in. There is still enough grease to lubricate. Don't think dirt will get in unless the boot comes off the joint
  23. May 23, 2020 at 8:25 PM
    #143
    tundra_kc
    tundra_kc New Member
    Tucson, AZ
    2016 TRD Off-Road
    @osidepunker any updates on the SDHQ boots. Recently switched to LT and I busted my passenger side inner CV boot and lost a band. Grease everywhere. I've been looking at picking up their replacement set.
    Mountun Goat and 831Tun like this.
  24. May 23, 2020 at 8:36 PM
    #144
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Is there a clamp on the larger end?
  25. May 23, 2020 at 8:39 PM
    #145
    tundra_kc
    Tucson, AZ
    2016 TRD Off-Road
    Nope. She gone. I never noticed anything and still haven't. The only reason i found it was i just so happened to see grease on the LCA and crawled under check it out. The top of the boot has about a 1 inch cut in it.
    dcsleeper408[QUOTED] likes this.
  26. May 23, 2020 at 9:08 PM
    #146
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    @osidepunker is wheeling this weekend so probably won't get back to you 'til Monday but he's really good with sharing info and trying to help people so I'm sure he'll respond. But, I do believe he's having luck with the SDHQ boots. Now tires...... that's another story.:D
  27. May 26, 2020 at 7:17 PM
    #147
    osidepunker
    Alex
    2013 Tundra DC 4x4
    hahaha I sure am making use of those tire certs #drivebyfeel
    Hey man the sdrhq boots are working fine. No leaks and that the biggest benefit. I think the root problem is the factory boots just dont stretch enough for some suspension setups.
    I did get a pinhole leak on a boot on one of the creases after only a few thousand miles. but seems to be an isolated incident
