High Angle CV boots for Long Travel, 2nd/3rd gen
Discussion in 'Suspension' started by osidepunker, Jun 19, 2018.
  1. Aug 12, 2018 at 5:02 PM
    #91
    osidepunker
    osidepunker [OP] OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    The sdhq boots are thick soft flexible rubber.
    But I'll reserve judgment until they have some real miles on them
    Vizsla and dcsleeper408 like this.
  2. Aug 12, 2018 at 5:13 PM
    #92
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    As far as I can tell, they're Neoprene rubber. RCV uses neoprene for their "high angle" stuff and SDHQ's website says these are basically the same. I'll give them a whirl, too. @osidepunker lets race to see who can rip theirs first :bikewheelie:
  3. Aug 12, 2018 at 7:19 PM
    #93
    n2deep
    n2deep Pavement Princess
    I will give the Toyota ones a try and see how they do.
    dcsleeper408 and Vizsla like this.
  4. Aug 12, 2018 at 7:49 PM
    #94
    Vizsla
    Vizsla 2 = 2.5
    I think they might be ok, my 16 had them also. At ride height they rub together much less than previous rubber boots I’ve had on various vehicles.
    dcsleeper408 likes this.
  5. Aug 13, 2018 at 8:12 PM
    #95
    n2deep
    Just an FYI. The boots I pulled off felt about like the same material. So we will see how they hold up.
  6. Aug 13, 2018 at 9:12 PM
    #96
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Keep us posted once you and Alex get some dirt miles.
  7. Aug 14, 2018 at 9:59 AM
    #97
    n2deep
    The Toyota kit times with grease, clamps and boots.
    Inner CV joint - held in by clip
    Full axle exploded view
    Inner CV
    Inner Axle with C clip
    Outer CV joint
  8. Aug 14, 2018 at 10:04 AM
    #98
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You doing that work yourself?
  9. Aug 14, 2018 at 10:05 AM
    #99
    n2deep
    Yupp - Its much easier when I have another vehicle to drive.
    Only thing I am not sure of is what grease goes where. There are 2-200gram packs and a 215gram pack and a 90gram CV-Joint Lube-Pack.
    The ones I did in the past only had 2 packs- one for the inner and one for the outer.
  10. Aug 14, 2018 at 10:13 AM
    #100
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Nice!
    huh. Call a shop and ask someone
  11. Aug 14, 2018 at 10:43 AM
    #101
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    fun stuff!
    messy job, but saves a few bucks.
    I can't tell from the picture, but are the grease packs different colors @n2deep ?
    Part # different, would you happen to know which one is for inner and which for outer?
  12. Aug 14, 2018 at 10:48 AM
    #102
    n2deep
    Would have had a shop do it but wanted to know how they work on the Tundra in case I need to do trail repair. All the grease packs look like the same color and thickness so not sure what goes where. Digging thru the service manual now to see what I can find.
    equin and dcsleeper408 like this.
  13. Aug 14, 2018 at 10:52 AM
    #103
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    for sure! let me know if you find anything on it. For my taco/4runner axles it was 2 different colors and viscosity, Light went inner and dark was outer.
    Don't for get to inspect that bearing cage. Sometimes you can have very small hairline cracks in em.
  14. Aug 14, 2018 at 10:54 AM
    #104
    n2deep
    cage looks good -just some surface wear mark but nothing significant.
  15. Aug 14, 2018 at 11:04 AM
    #105
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    i think the bearing grease doesn’t matter for tundras. Both inner and outer has bearing cages vs the Tacoma/4runner they had a Tripod bearing inner and cage outer. And there cage outer uses the thicker bearing grease.
    Only thing that bugs me is the different part # on your bearing grease packages
    831Tun likes this.
  16. Aug 14, 2018 at 12:30 PM
    #106
    n2deep
    The Toyota Service manual says pack the outer CV with approx 300grams of grease and the inner CV with 400grams of grease from the boot kit. So looks like the 2 200 gram packs go in the inner CV and the 215 and 90 gram packs go in the outer CV.
    TRD15559, 831Tun, equin and 1 other person like this.
  17. Aug 15, 2018 at 5:05 PM
    #107
    n2deep
    So I filled one boot and clamped it down and sure as shit the crimping tool broke. POS - waiting on a HD tool to finish the job. So the truck sits on jack stands till Friday.
  18. Aug 16, 2018 at 9:35 AM
    #108
    osidepunker
    Alex
    2013 Tundra DC 4x4
    damn dude that sucks. send me a link to the HD tool you bought
    btw, I put a couple hundred freeway miles on the new boot and so far no leaks. The OEM boots would leak immediately so maybe the new ones are good. We'll see after I do a real trip
  19. Aug 16, 2018 at 10:14 AM
    #109
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    what tool did you use?
  20. Aug 16, 2018 at 10:27 AM
    #110
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    @n2deep or @osidepunker u guys got a diy thread/link to rebuild axles? I'm due for booty replacement as well.
  21. Aug 16, 2018 at 12:07 PM
    #111
    n2deep
    I can make one but the new tool won't be here till tomorrow and I can finish the job. If the tool doesn't suck haha
  22. Aug 16, 2018 at 12:09 PM
    #112
    n2deep
    It was something I picked up at CarQuest. The one that Napa had looked even less stout.
    dcsleeper408[QUOTED] likes this.
  23. Aug 16, 2018 at 12:53 PM
    #113
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    damn, its not the tool.. you just too buff. :muscleflexing:
    joonbug likes this.
  24. Aug 16, 2018 at 5:43 PM
    #114
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    So zero leaks so far from SDHQ boots???
  25. Aug 17, 2018 at 5:07 PM
    #115
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Yeah so far no leaks, but I've only done about 200 street miles. Nooo to do a real dirt trip before I call them good
  26. Aug 18, 2018 at 11:58 AM
    #116
    n2deep
    So one thing about the OEM boots is since they are a little stiffer the ridge that rides in the groove on the axle is a bit more solid. Is that good or bad? I don't know yet I just know where the boot sits on the axle it was more secure before clamping down.
  27. Aug 18, 2018 at 12:28 PM
    #117
    HighDesertSurfer
    HighDesertSurfer Surf The Dirt
    New Mexico
    2018 SuperWhite DC TRD OR
    Leer shell
    @n2deep Hard core, brother! If I had my front axles laid out in front of me like that, I would be freakin out ( a bit! )....and I was a bit apprehensive about installing ABS guards...Ha! :rolleyes:
  28. Aug 18, 2018 at 12:39 PM
    #118
    n2deep
    Just have to think of things like a puzzle and put it back together like it came apart. However on the second axle I forgot a few things and had to pull it apart three times. Just moving too fast and forgot the inner clamp for one boot and then the clip that holds the inner cage from pulling out. Made a bigger mess and had to be careful not to destroy the outer clamp when I pulled it off so I could reuse it. I have been waiting toooo many days for parts on the repairs and didn't want to wait anymore.
    HighDesertSurfer likes this.
  29. Aug 18, 2018 at 2:47 PM
    #119
    Help New Member
    Ryan
    Tucson, AZ
    @n2deep do you have any particular guide that you find worked best? I've been watching the good ole youtubes in preparation for doing my rebuild Monday
  30. Aug 18, 2018 at 2:52 PM
    #120
    n2deep
    I will post up a step by step tomorrow. I just finished and cleaning up.
    Here is the Service Manual infohttps://drive.google.com/open?id=1kc2CikbqdiXJbVEQ0m2x4CDzjE1k93Ux
    Pull Wheel
    Remove Axle dust cover, cotter pin and axle nut
    Remove two lower Ball Joint bolts
    Pull axle out of Hub - careful not to damage seals and pull hub out of way and support with jack or stands.
    Pry inner axle from differential - You will lose fluid so have pan ready
    Once Axle is out cut existing band off CV boots and remove C clip from inner axle housing
    pull axle apart following Service manual - keep track of how it came apart.
    Clean axle and install outer CV boot and fill with Approx 300grams of grease
    I banded the small side so it didn't move around as I was trying to fill with grease.
    Clamp the big side of the outer CV boot.
    Place the small ring over the axle and then the inner CV boot - install the bearing race and the c-clip holding it on the axle.
    Found it easier to install the cage and ball bearings into the inner CV cup and then the C clip to keep it from coming out before filling with grease.
    Clamp the small side of the boot and fill with grease.
    Clamp the large side and replace the C clip on the inner axle and re-install axle into truck. Using a Screw driver if needed to tap the axle into the differential. (See Service Manual)
    Install outer axle thru hub careful no to damage seals - install axle nut to pull axle thru hub. Install lower ball joint bolts and torque to 221lbs.
    Torque Axle nut to 249lbs -re-install Lock cap, cotter pin, axle dust cap and Wheels
    Drain and fill Front diff(2.2qt) or just top off - I used Amsoil 75w-90
    This is the tool I used for the CV clamps and it seemed to work OK -https://www.amazon.com/OTC-4722-Sti...=UTF8&qid=1534631784&sr=1-2&keywords=otc+4722
    Sas, TRD15559, chugs and 2 others like this.
