Hey everyone my name is Jeff and I'm a new owner of a 2001 tundra. Truck is super clean for its age
Discussion in '1st Gen Tundras (2000-2006)' started by Thejeff2001, Sep 20, 2020.
  1. Sep 20, 2020 at 7:48 PM
    Thejeff2001
    Thejeff2001 [OP] New Member
    Jeff
    2001 gold? Toyota tundra 2wd
    I own a 2001 tundra. I just bought it Friday and I noticed that my oil pressure gauge drops down to almost 0 at idle ( once warm) and moves up once I give it gas. Is this normal ? If not what could be the problem.
  2. Sep 20, 2020 at 7:58 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Welcome, and no that's not normal. Should be about 1/2 way on the gauge when warm. I would install a new oil pressure sensor to see if you get different readings. Good luck.
    Hbjeff and Jim LE 1301 like this.
  3. Sep 20, 2020 at 8:05 PM
    ^^This^^
    Welcome from NY.
  4. Sep 20, 2020 at 8:44 PM
    Sunnier
    Sunny
    San Diego, CA
    It shouldn’t go as low as zero, but mine stays pretty low at idle, lower than any other vehicle I’ve owned.
    There’s a thread showing the range. I don’t this is the one I was thinking of, but here’s a start:
    https://www.tundras.com/threads/2001-toyota-tundra-sr5-v6-oil-gauge-reads-low-to-none-at-idle.33106/
    Edit: Here you go. Just above “zero”:
    https://www.tundras.com/threads/oil-pressure-gauge-with-pic.12351/
    Welcome from SoCal!
    FrenchToasty likes this.
  5. Sep 20, 2020 at 8:53 PM
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Welcome aboard Jeff. I'm thinking Sending Unit as well.
  6. Sep 20, 2020 at 9:04 PM
    TILLY
    Massachusetts
    I stand corrected if those last threads are correct. In all my years as a tech, i never saw an oil gauge that represented normal pressure at the bottom of the gauge. Maybe its a Toyota thing. :notsure:
    Sunnier and FrenchToasty like this.
  7. Sep 20, 2020 at 9:09 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
    Welcome aboard from The Pacific South West.
    270Fan and FrenchToasty like this.
  8. Sep 20, 2020 at 9:13 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    The older 4.7 is fine with anything above 6 psi at idle. The top end doesn’t have lifters or rockers to worry about.
    Sunnier likes this.
  9. Sep 20, 2020 at 9:19 PM
    TILLY
    Massachusetts
    Thanks, that makes sense. Maybe Toyota should have re-calibrated their gauges to prevent concern.
  10. Sep 20, 2020 at 9:26 PM
    empty_lord
    05 rollover special
    its in the manual. 05-06 is slightly higher reading.
    now if it actually drops to 0? houston, we have a problem
    YardBird likes this.
  11. Sep 20, 2020 at 9:55 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
  12. Sep 20, 2020 at 9:58 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Welcome from Nevada
  13. Sep 20, 2020 at 10:01 PM
    TILLY
    Massachusetts
    This is my first Tundra, and have absolutely no experience with first gen trucks. But i still can't wrap my mind around having gauges that don't reflect what we have all previously used as the standard for all this time. Does the first gen also show that when your gas gauge reads a 1/4 tank, that it could actually be a half a tank as normal?
  14. Sep 20, 2020 at 11:13 PM
    270Fan
    270Fan New Member
    2004 Silver Tundra 4x4 DC
    Mine does that, too. It's maddening.
  15. Sep 21, 2020 at 4:15 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    How far down does it go? Here is normal:
  16. Sep 21, 2020 at 4:25 AM
    10TundraSR5
    10TundraSR5 Happy Tundra owner
    Tennessee
    2010 Black Tundra SR5
    Curse you Perry the Platypus!
    Welcome from East TN! Where's the pics?
  17. Sep 21, 2020 at 5:11 AM
    Pucks18
    Pucks18 Fleabit peanut monkey
    2001 Tundra 4x4 Limited trd
    It's normal. Don't let the turd geners tell u other
    bassman417 likes this.
  18. Sep 21, 2020 at 1:09 PM
    bassman417
    bassman417 "Tundra Time". My favorite time of day...
    Paul
    Las Vegas
    2004 DC 2wd Imperial Jade
    20200921_145556.jpg Welcome from Vegas and dont worry about your oil pressure being low at idle. If it does not move when Rpms increase, you have a problem. I believe this is a First Gen thing and forum. Dont listen to TURD gen people (shoo), their trucks are different.
  19. Sep 21, 2020 at 1:24 PM
    Rgross2112
    Rush
    2020 Silver TRD Limited
    Hello Jeff! Welcome from Pennsylvania
  20. Sep 22, 2020 at 2:31 PM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    It's normal, at idle the service manual gives 4-5 psi and at 3000 rpm, 43-85 psi. The gauge is calibrated well for those specs. These are for a v-8 model, v-6 is same at idle but slightly less at 3000 rpm.
  21. Sep 23, 2020 at 5:23 AM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    314,612 is normal?! Yay!
    bassman417 and bmf4069[QUOTED] like this.
