2001 Toyota Tundra SR5 V6 - oil gauge reads low to none at idle
Discussion in '1st Gen Tundras (2000-2006)' started by chopper, Oct 16, 2018.
  1. Oct 16, 2018 at 9:45 AM
    chopper
    chopper [OP] New Member
    My 2001 Toyota Tundra SR5 V6 mechanical oil gauge drops to near zero at idle. Using 5W-30 full synthetic oil. 68,000 miles runs good.
  2. Oct 16, 2018 at 10:36 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    what does it do when you're driving? have you checked the oil level on the dipstick? the oil gauge simply measures oil pressure, which will be much lower at ice than when the truck is moving.
  3. Oct 16, 2018 at 11:38 AM
    chopper
    Oil level is always full. Does not use any oil between changes. When driving gauge readings vary between just above 1st mark and at 2nd or middle mark. When first started and engine I’d cold gauge reads up to 3rd mark.
    lsaami likes this.
  4. Oct 16, 2018 at 11:45 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    You’re fine. That’s exactly what my dads 02 has always done.
  5. Oct 17, 2018 at 6:26 PM
    billyemerson
    billyemerson New Member
    Bill
    2002 tan Tundra w/access cab
    Mine does the same, it's normal. Here's the info from the owner's manual for the 2002 Tundra.
  6. Oct 17, 2018 at 6:28 PM
    billyemerson
    Bill
    And you can download the owner's manual from Toyota's web site as a .pdf file.
