Hewitt-Tech Inc. Plug & Play Secondary Air Injection System Bypass Kit
Discussion in '2nd Gen Tundras (2007-2013)' started by djmichael24951, Jul 11, 2019.
  1. Feb 10, 2021 at 4:58 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I did mine a few months ago on a strictly preventative basis.
    I have had zero issues since the install; of course, I was having zero issues before the install as well.
    I definitely did not improve my mpg.
    I will say that doing the install is waaaaaaaay harder than the video. It was almost impossible for me to work my hands back into the AIP to unplug and plug the connectors. It took me several hours before I finally got it. It was very frustrating, but I finally got it.
  2. Feb 10, 2021 at 6:10 AM
    RyanTundra12
    RyanTundra12 New Member
    Ryan
    2012 Tundra DC 4x4 4.6
    Same here @Doug2000
    In Massachusetts. Even after the tax “savings” I maybe could have squeezed another grand in profit out of the truck, but it needed tires and a full recon to get max money, plus I would be down a vehicle in the interim. Morenof a hassle than it was worth. I paid a $1000 in taxes on the new vehicle by trading in as opposed to nearly $3k if I sold privately.
  3. Aug 26, 2023 at 7:59 AM
    Bam1971
    Bam1971 New Member
    2011 Toyota Tundra 4.6
  4. Aug 26, 2023 at 7:59 AM
    Bam1971
    Bam1971 New Member
    Is it still running well without the plates?
  5. Aug 26, 2023 at 11:23 AM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I didn’t install the block plates either. No issues in over 3 years.
    Filthyphil likes this.
  6. Aug 26, 2023 at 1:40 PM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    So what is it that the actual plates do? Because if the pump it disabled what’s being blocked off?
    Leo's first likes this.
  7. Aug 26, 2023 at 1:47 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    The plates block air from coming in if the switch valves get stuck open…I was fine installing the Hewitt preventively (without the plates) for 4 years, until somehow the valves got stuck open. Unfortunately for me,I was 750 miles away from home when it happened. Truck would go into limp mode, I’d have to pull over to clear codes each time. I pulled over maybe 15-20 times on that trip home to clear the codes. I risked breaking my pressure sensors doing this, but I had no choice but to push on.
    I learned the hard way why Hewitt recommends that you install the block off plates. It’s done now so hopefully I’m good.
    HewittTech01 and Filthyphil like this.
  8. Aug 26, 2023 at 1:56 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
    Sometimes one or both air valves get stuck open if that happens you still get codes and limp mode the plates block the air ports to the exhaust
    If air valves aren't stuck open you don't need blocking plates and the system is bypassed no problem
    Edit: I stand corrected I've never herd of a problem occurring after bypass being installed without blocking plates if valves were not stuck open
    Just noticed you have a 1st gen 4.7 they might be different but the blocking plates weren't that difficult to install on my 5.7
    Filthyphil[QUOTED] likes this.
  9. Jun 8, 2025 at 1:58 PM
    Fisherman
    Fisherman New Member
    I installed the bypass kit and blocker plates on my 2010 4.6 about 2 months ago. Recently on cold starts im hearing some noise from under the manifold some where. One other member kinda described it as a shop vac noise. Mine is similar but with an added rattle or gurgling.. not a liquid gurgling though. Not quite sure how to explain it. Its not throwing codes or in limp mode but im wondering if it has something to do with the block off plates being installed but possibly not needed. Like it's creating back pressure with nowhere to go. Anyone have this similar problem... the sound goes away after the truck is warmed up.
