Hewitt-Tech Inc. Plug & Play Secondary Air Injection System Bypass Kit
Discussion in '2nd Gen Tundras (2007-2013)' started by djmichael24951, Jul 11, 2019.
  1. Jul 11, 2019 at 5:00 AM
    djmichael24951
    djmichael24951 [OP] New Member
    Dave
    2008 Blue Tundra SR5
    None
    Any reviews on the Hewitt-Tech Inc. Plug & Play Secondary Air Injection System Bypass Kit? Is it just a quick temporary fix? There is a lifetime warranty on it. I have the dreaded secondary air injection system problem on my 2008 Tundra 4.7L. I am having trouble deciding whether to replace the parts or put the bypass kit on it. I've always been one for fixing things the right way, but I am a disabled veteran on a fixed income, and this problem is quite pricey. Especially, since we are going on vacation next week. I really do need my truck for that trip. Also, please correct me if I'm wrong, but on my truck, it looks like there are 2 pumps. The pump for the Bank 2 check valve is in the fender well, and, it looks like the pump for the Bank 1 check valve is under the intake. At first I thought this job was gonna be a little simpler, compared to other models and engines, since the check valves are mounted outside the engine. But then I traced the tube coming out the back of the Bank 1 check valve, and it goes around back and under the intake manifold. I just assume there is a pump under there for that valve. I can't seem to find a different part number listed for my model and engine, for that second pump. The Bypass kit for my truck is $395. The cost of the parts to fix it the right way is gonna be about $200 more than that.
  2. Jul 11, 2019 at 5:29 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    There are a few threads regarding this issue on here, but I have the exact same truck specs as you and I installed the Hewitt Kit last October. It essentially bypasses your AIP system so while it's not technically "fixing" the problem, it's keeping that system from turning on so it kind of is fixing it at the same time, if that makes sense. That system is basically only used at cold start up, and is for emissions only. It makes the exhaust burn cleaner, quicker. I had my system replaced once in 2015 under warranty, and then it went out again October 2018. It's a faulty design by Toyota and there is no way of knowing how long it will last if you replace the parts. Some people never have an issue with it, and others such as myself have had it fail twice with no unusual driving.
    I'm not sure where you were looking at parts to replace it at and if you are able to do some of it yourself, but this job at a dealership is $2k-$3k easily. I just couldn't spend that type of money knowing that it could fail again. I would get the Hewitt Kit and call it a day. The kit is super easy to install, and literally is just plug and play.
  3. Jul 11, 2019 at 5:47 AM
    djmichael24951
    Dave
    None
    I am a auto mechanic by trade. So, I am very capable of doing the work. I just haven't done a whole lot of it since I got my disability from the VA. A brake job here and there is about the most I get into anymore. But, I'm sure I can perform the required repair for this particular situation. I was just thrown for a loop, when I found only one pump in my fender well. But with vacation next week. I am leaning more (much more) toward the Plug & Play. For nearly $400, I just wanted to make sure that it would be a permanent fix. Compared to your previous winters, is there any performance difference at cold start up?
  4. Jul 11, 2019 at 5:58 AM
    djmichael24951
    Dave
    None
    And I did research several different threads on this topic, and watched several Youtube videos, but never could find any information on the second pump being under my intake manifold. Without removing the manifold, I can only assume that the second pump is there. I did see a video on a 2006 model 4.7L, and it had a pump and a check valve under the IM. But it seems like there is know information for the 2007 and newer 4.7L models. Correction, there is one video of a man changing his Bank 1 check valve, which he had stated that he had done several times. But, I've seen nothing on performing the entire job for my particular application.
  5. Jul 11, 2019 at 6:23 AM
    parker44
    parker44 New Member
    No I didn't have any differences on start up. When I said cold start up, I also just meant starting in general after sitting a while. I'm in SC, so it doesn't get toooo cold here haha. I had a mechanic also look at replacing mine and he said the pumps he was finding were all about $500 each, so that sounds about right. I would just get the kit and call it a day. They are very knowledgeable about their products and have good service as well. For me, I wouldn't have been able to change them out myself so it was a pretty easy decision on my side. It's just a pain that even by spending the money to replace those pumps, they could go out again in a year.
  6. Jul 11, 2019 at 7:00 AM
    Trident
    Trident New Member
    2007 Tundra DC 4X4
    I installed the Hewitt bypass on my 2007 5.7 a few months ago and have had zero issues since (nearly 4,000 miles). Install was fairly easy & gained nearly 2mpgs to boot. I am seeing only positives.
    Filthyphil and hewitttech like this.
  7. Jul 11, 2019 at 7:31 PM
    EBenke
    EBenke I’m Ready To Go!
    Everett
    2007 Toyota Tundra DC, 5.7, 4x4
    3/2 lift, Icons, 35's, 3" CB's shackles
    DJ - Thanks for your service.
    Filthyphil and flyfisher like this.
  8. Jul 11, 2019 at 8:19 PM
    djmichael24951
    Dave
    None
    Thank you for your support.
    Filthyphil and EBenke[QUOTED] like this.
  9. Jul 23, 2019 at 1:28 PM
    htsiordia
    htsiordia New Member
    I've started a petition on Change.org for Toyota to address this issue. Here's the link: http://chng.it/p5gJY4rp7M
    It saddens me that a company that I've been loyal to for over 30 years has let a problem like this continue at the consumers expense. Please pass this on to anyone you know has had the same problems. My truck is in "limp" mode now and I'm on the 3rd repair for the same problem.
    Bam1971 likes this.
  10. Jul 23, 2019 at 2:02 PM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I signed & donated.
  11. Jul 28, 2019 at 8:06 PM
    Jrpotts01
    Jrpotts01 New Member
    Jody
    2007 tundra SR5 4.7L
  12. Jul 28, 2019 at 10:35 PM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
  13. Jul 29, 2019 at 3:55 AM
    Jrpotts01
    Jody
    That was my thought, if it's operational the the block off plates are not required
  14. Sep 23, 2019 at 11:34 AM
    kmcelroy
    kmcelroy New Member
    Anyone have any problems passing inspection with the hewitt bypass? I've had this problem for months and even after replacing both valves on my 2010 4.6 liter, I'm still in limp mode - and now my inspection sticker is about expired.
  15. Sep 24, 2019 at 4:36 AM
    parker44
    parker44 New Member
    You shouldn't have any issues with it.
  16. Oct 8, 2019 at 1:04 PM
    boboloo
    boboloo New Member
    2006 Sequoia SR5
    New User, hope I am posting in right spot. I have owned 2006 Sequoia since 2008. Bypass system sounds like a shop vac when starting. I can't put block off plates in because everything is rusted and aged together. I am thinking of kinking the lines coming from pump to manifold or cutting and plugging them. Any thoughts? I have not bought a bypass kit yet. I live in Michigan and it is my daily driver. Salt/rust. Not in limp mode yet.
  17. Oct 9, 2019 at 4:50 AM
    Jrpotts01
    Jody
    If your pumps are still currently working and it's not in limp mode then your valves are closed when the truck is not running if you put in the bypass kit it will keep the valves from ever opening and prevent the pumps from running the only time you ever need to block off plates is if the valve has already seized up while open and will not close. The block off plate stops the airflow from going through the stuck open valve. You should be in good shape if you install the bypass without using the block off plates as long as your system is still functioning properly when you install it.
  18. Oct 9, 2019 at 6:18 AM
    boboloo
    boboloo New Member
    2006 Sequoia SR5
    Thank you for the response. **In original post I wrote "Bypass system sounds like shop vac;" I meant to say secondary pump sounds like shop vac." I have not installed bypass yet
    Thank you for the info about the plates. I am leaning toward RuTech.
    Also, I have several lights on including engine. I will stop at my mechanic and get the codes.
  19. Oct 12, 2019 at 8:03 AM
    boboloo
    boboloo New Member
    2006 Sequoia SR5
    I ordered the Hewitt. Should be in today. I chose Hewitt since (if I understand correctly) the secondary system will no longer kick on even if key is on for an extended time. Truck is still not in limp mode. I will not add the block plates.
    Bam1971 and Rph74 like this.
  20. Oct 12, 2019 at 7:16 PM
    Jrpotts01
    Jody
  21. Oct 14, 2019 at 6:58 AM
    boboloo
    boboloo New Member
    2006 Sequoia SR5
    Thank you for the info. The process is a bit over my head. I will be installing the Hewitt soon without using the block plates. Hopefully I caught it in time. The blower sounds like a shop vac at start up but I am not in limp mode yet.
    Tundra802 likes this.
  22. Sep 1, 2020 at 12:27 PM
    Tundra802
    Tundra802 New Member
    Andrew
    2006 Tundra SR5 4.7 Double Cab
    None
    Hi boboloo, just curious how the bypass is holding up without the block off plates? I am in the exact same position as you had. ShopVac noise on start up. No limp mode, so I think my valves are still operational. The studs on the pipe are completely rusted and I already snapped one off (after soaking with PB Blaster for over 48 hours). There is no easy way to drill out and tap those. At that point, I'd be better off paying someone to replace the SAIS system!
    Anyway, I am afraid of traveling far without the block off plates, since the pressure sensor valves can be damaged (if valve is open) and it will then put me into limp mode.
    So just curious if your pressure sensor valves were ever damaged without the block off plates.
  23. Sep 6, 2020 at 9:17 AM
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    So your just plugging in the pig tail since you currently don’t have any CEL’s or troubles? Really interested if you don’t have to install the block off plates if you do it early.
    Tundra2 likes this.
  24. Sep 6, 2020 at 10:34 AM
    Bucks04
    Bucks04 New Member
    2013 TRD Tundra
    Working on it
    Installed kit last year, no problems ,but then I didn't have any when I installed it , but peace of mind now. I did get block off plates and installed them. Wasn't that bad getting them in , I just wanted them in.
    Trusty Rusty and Filthyphil like this.
  25. Sep 7, 2020 at 7:03 PM
    RyanTundra12
    RyanTundra12 New Member
    Ryan
    2012 Tundra DC 4x4 4.6
    Does anyone have any experience with trading in a Tundra with a bypass kit installed? I tried today and I believe the dealer found and and unplugged then plugged back in. It triggered limp mode and they low balled me on a mint condition truck. I can put it back to stock as I bypassed the system in working order. I’ll probably have to do that, but was hoping to do after the deal is made.
  26. Sep 7, 2020 at 7:37 PM
    Filthyphil
    Phil
    Sell it private party and get $5,000 more.
    flyfisher likes this.
  27. Sep 7, 2020 at 9:41 PM
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    This. Tundras sell so well I have no idea why the heck a trade in would be an option.
  28. Sep 8, 2020 at 3:15 AM
    RyanTundra12
    Ryan
    It’s not as if I didn’t think of that myself. There are other problems that come with selling private party, For me anyway. I’m looking for past experiences with trading.
  29. Feb 10, 2021 at 1:27 AM
    Doug2000
    Doug2000 New Member
    London, Ontario, Canada
    2017 Tundra SR5 5.7L DC 4X4
    where I live, the Province of Ontario, you only pay tax on the trade difference. If your trade is worth $20k and your new truck is $30k, you only pay tax on $10k. If you sell your truck privately then you have to pay tax on the full purchase price. Selling private isn’t worth the tax here.
    PaulB84 likes this.
  30. Feb 10, 2021 at 1:28 AM
    Doug2000
    Doug2000 New Member
    What is the newest Tundra that is having issues??? I have a 2017 5.7L
